My Power went off last week and when I turned my computer back on when my power came back on the clock on my computer was worng. And I wasjust wondering how to set it back to Victoria.
  • 679 Answers
Click on the time on the bottom right, that will bring up the applet with the time day date and teh selection of your time zone, good luck, it should be easy
Posted on Dec 20, 2008
Car lost all power when using emergency brake - stopped using it and everything was OK - a week later went to start car and when turning key was totally dead - friend went to give me boost and when he...
Welcome to
Check for a drain remove the positive side battery connect a test light clamp end to the battery wire and the pointed end to battery post light will be on. Pull one fuse at a time. When test light :light goes out that is the circuit draining the battery
Regards, Lee Davidian
Thank you for using FixYa,com.
Oct 21, 2010 | 1999 Oldsmobile Alero
My bose wave radio wont turn on. It has no power
I have the exact same AWR1-1W model for repair last week. I am assuming you have a meter and you also have soldering skills here.
You might want to check the Q4 transistor (2SC3792) for a short on the two outide pins. With the power disconnected, measure with a multimeter the resistance between the two outside pins of the Q4 transistor. If you measure anything between 0-3 ohms it is shorted. Replace this part with a similar part or you could replace it with the new Bose recommended part - 2SD438F-MP-E but it is very hard to obtain. I have used an 2SC2655 instead and had no problems so far with the radio. This radio also came in totally dead with no display nor the radio working.
Jun 06, 2010 | Bose Wave Radio
Trouble turning tv on.
U know basic electronics and soldering?Go to the power supply board.Searches all around the power supply board for these capacitors it have electrolite gases leakages capaciotors.These capacitors usally or alway have bulges up or puff up on it top.Replaced these capacitors will return ur power function back to normal.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Apr 27, 2010 | Samsung LN40B750 40 in. LCD HDTV
Power went out last week. Can't print. The jobs
OK try this Remove Power Cord from Printer, remove USB cable from PC. Reboot PC. Wait 10 mins, then connect, the Power again to printer. Turn OFF PC. While OFF plug in the USB cable TO any other USB other than the one used before. Turn PC ON. After a bit you should hopefully have a working printer. If that doesn't work, Unplug USB, reboot & then using your DVD re-install it all again.
Feb 15, 2010 | HP Photosmart C7280 Printer
Panasonic SA-AK27 Bookshelf Stereo - Setting The Clock
Have you put on the eco mode? try this: power on the unit, click on the eco button, until the unit will display "normal"
Jul 07, 2009 | Panasonic SC-AK27 Shelf System
My toshiba laptop will not turn on...
This could be a few things. It could be a bad power cord not charging the battery or the machine. But it could also be various other things. The cheapest and easiest thing to try is a new power adapter.
May 26, 2009 | Toshiba Satellite A60 Notebook
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
DEH 245 Lights
Try Turning the Power off holding down the clock button till the clock display flashes then use the volume and tuner keys to set the time.
Dec 17, 2007 | Pioneer DEH-245 CD Changer
Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Nov 09, 2007 | Dacor Millennia MOV130 Electric Single...
Computers & Internet Logo
David Payne
David Payne
