Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
All pro 115k
I have the all pro 115,00 btu heater. If I turn it on first time of the day, runs for about 5 minutes and then shuts off. Unplug and and wait 30 seconds, plug it in again and fires up for 1 minute and shuts off. Also everytime I turn it on (first thing of the day or every other time), it takes about 30 seconds before it ignites. I like this heater and wanna fix it! PLEASE HELP!!!!
  • glennhut6 Dec 29, 2008
    I used the all pro heater 6 times. It cuts off after two minutes. I wait five minutes then restart . It will run about two minutes then cut off again.
  • caustelot Jan 29, 2009
    I have the same problem but every once in a while it will run for about 20 minutes and then shut off.
  • 193 Answers
Check pump pressure,check black plastic filter end cover for small cracks or warpage
Posted on Sep 25, 2009
  • franktalk Sep 29, 2009
    Check the inline fuel filter first.Also, remove the rear black plastic filter cover and check for hair line cracks
    Genius:
  • 1,199 Answers
This sounds like you will need to replace the thermostat!
That should fix this common problem!
Posted on Dec 20, 2008
4 Suggested Answers
  • 288 Answers
SOURCE: all pro heater runs for a couple of minutes.then
it only shuts down because of an overheating condition or the lack of fuel. if you have an ohm or multimeter, check the ohms on the fan and see if you have any resistance. If you do the fan is good but may still not be putting enough air across the heat exchanger to safely alloww the heater to run without causing a fire.
Posted on Dec 19, 2009
heatman101
  • 43501 Answers
SOURCE: all pro 170T dual fuel heater starts and runs for
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 16, 2011
  • 4736 Answers
SOURCE: I have an allpro 115000 btu torpedo heater.
According to the Owners Manual Trouble Shooting Guide (Page 8), there are 9 different things that could be causing the problem you have. Fortunately, there are 9 solutions to finding and fixing the problem.
Below is a link to your Owners Manual (in case you have misplaced yours) that you can download and print for now and future reference.
http://www.desatech.com/manuals/Construction%20Heaters/113282-01.pdf
This should get your heater fired back up.
Posted on Mar 07, 2011
Pilot turns on and so will unit for about. 5 minutes...pilot flickers as if there were air blowing into it...any suggestions? It is. A Pro-com MD100TBA
the flame confirmation thermocouple might need looking at biased on your description , this item sits inside a stainless steel metal tube that's about 1.5 inches long an is someplace around the edge of the heater , this item confirms that the main flame has lit and shuts off the pilot most times too . this is why I believe it is not working
Jan 18, 2016 | Procom 10K BTU, Vent Free, 2 Plaque...
Have a Reddy Heater 55,000 BTU unit, when plugged in it will run for about 5 minutes or so and then shut off.
heatman101
Jan 11, 2011 | Reddy Heater-30-55,000 BTU Variable
I have a 100,000 btu reddy heater, and every time I turn it on, it runs for about 5 minutes, then stops, then I have to push the reset button and start it again. Can you tell me where to start? thanx
If it actually ignites and burns but shuts off either the flame sensor is bad (or dirty) or the control is bad. I would verify the flame sensor is clean and had good electrical connections to the controller for starters.
Feb 10, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Heaters runs for a few minutes then shuts off.
was working fine refilled it and now it will run 5sec. and kick the breaker on it.It's an old 80's model 35,000 B.T.U. I cleand the photo eye with a cloth no change. Any solution's
Jan 29, 2010 | Reddy Heater-30-55,000 BTU Variable
Kerosene heater cuts off after a few seconds
Photo celll rarely goes out, but time to remove the gum out!---or OVERHAUL TIME!
Dec 18, 2009 | Heating & Cooling
Heater shuts off unexpectedly
I would suspect that either the reset (HA3003 Safety Control) or the photocell (HA3019) is bad. For test purposes only bypass them one at a time- see if the unit ron OK.
Troubleshooting tips
hA3003
Apr 18, 2009 | Heating & Cooling
Runs for about 15 minutes then shuts off .
I believe the pump setting is 6.0 for the 155 BTU model. I will know more after tonight, we are using a Reddy Heater 155 unit tonight at church. I will look on the side panel and see what the PSI should be for the pump pressure and respond either tonight or tomorrow.
Feb 04, 2009 | Reddy Heater-30-55,000 BTU Variable
Heater runs for 20 minutes then shuts off
These heaters have built in thermostats. Sometimes they are adjustable sometimes they are not, check to see if your is adjustable and see if this fixes your problem. Also check to see if there is any air restrictions possibly causing the heater to over heat.
Dec 03, 2008 | All-Pro Forced Air Kerosene Space Heater...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
197 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
T bone 1963
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
