Epson Stylus C60 InkJet Printer Logo
Tom Simpson Posted on Apr 01, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson C60 inkjet Epson Printer Utility
My C60 printer doesn't display in the Epson Printer Utility, my Epson 1280 does. The C60 is printing but I can't tell what my ink cartridges are or clean the hwads etc.
Inky Fingers
Level 3:
  • Epson Master 705 Answers
  • Posted on Apr 02, 2007
Inky Fingers
Epson Master
Level 3:
Answers
705
Questions
0
Helped
433525
Points
1443
Try downloading the latest version of the status monitor from the Epson web site. This should sort your dilema.
2answers
Have just put in a two new cartridges and it won't print black?
try using some cleaning alchol on the ends of your cartridge it might help get the ink flowing
I'm trying to resurrect an old Epson 1280 Photo Stylus. I've changed ink cartridges, and run the head cleaning/nozzle check utility numerous times, but nothing prints out on any test pages, nor on any...
It's time to "cut your losses"; either the electronics that tells the inkjets when to shoot ink is screwy, or the inkjets are totally plugged, despite the "cleaning" cycles.
Responsibly recycle the printer, and buy a new printer.
Maybe, try to find another Epson that accepts the same ink-cartridges that you recently inserted into the old printer.
I can't seem to find a way to clean my Epson C60 ink nozzles. I'm running Mac OS 10.5.6 Thanks. -Bill Carter
Hi Bill
Go to the C60 online manual at:
http://support.epson-europe.com/onlineguides/en/sc60/index.htm
and select How To, Maintenance, Cleaning the Print Head.
This explains very well how to clean the print head etc using either the printer software or the printer control panel, for both Windows and the Mac.
2answers
EPSON C60 PRINT BLACK
If you are running windows go to Control Panel, Printers, Select Printer Preferences and turn on either print in Grayscale or Print in Black only.557e203.jpg
3helpful
4answers
Epson c60 printer not compatable with windows vista need a driver but have no idea where to download it
The driver for the Epson C60 printer is included with Vista - all you need to do is connect the printer to the computer with Vista running and turn it on. If you have already done this and the printer does not work properly (but see the info about the Status Monitor below), turn the printer off, uninstall the printer using the Control Panel-Programs and Features-Epson Printer Software, then reboot the computer. Once Vista is running, turn the printer on and it should then install OK.
HOWEVER, the printer Status Monitor (SM) is not included in this process and if you try to install the XP version of the SM, it will not work. Epson appears to have no intention of remedying this problem. This means you have no means of monitoring your ink levels, nor of changing the cartridges, cleaning the heads etc via the computer, although some of these tasks can be carried out via the printer control panel (see your hand book on how to do this).
A good solution is to use the free SSC utility as your SM - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C60), then close the ssc window. Now right click the ssc icon in the sytem tray and choose the SM function you wish to use.
If you have any further queries on this, please post a new comment.
Hi: epson printer c60
If you still have this problem, please post a new comment, otherwise we will assume it's solved.
Epson c60 not compatable with windows vista
I have an Epson C60 and Vista has the neccessary drivers in box. When Vista is running just connect your C60 and it will do the rest.
I have so far had no problems. The only thing that I can see is missing is the option to preview via the printer software.
Not printing.tried everything i think
Sounds like print head issue; have it serviced or u can try this :
How to Unclog Epson Print Heads
1helpful
2answers
Printer paper won't feed
Dear Queenbee1
plz visit following website for details:
http://www.epson.com/cgi-bin/Store/support/supDetail.
Cant get my printer to print from the computer...
just re-install your printer driver to fix the problem
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
