Question about Maytag Atlantis MAV8551 Top Load Washer
Washing machine wont fill
I have a Maytag Atlantis MAV8551, and when I turn it on all I hear is a humming comming from it and no water (hot or cold). I have done basics such as checking the water lines etc.. I was wondering what it could be? (water inlet valve?) Thanks Brov
    President:
  • 1,462 Answers
The humming noise is usually the inlet valve energised but no water there to come in. i appreciate you have checked. the other possibility is that the appliance has not pumped out completely and the noise you hear is the drain pump energised but stuck due to perhaps a foreign object in it. fault is unlikely to be inlet valve
Posted on Apr 04, 2007
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
Water when filling has slowed down cold water is very slow hot is ok
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Will fill with cold water but not hot
the hot water inlet valve is shot replace it
Apr 27, 2010 | Maytag Atlantis MAV7551 Top Load Washer
WATER KEEPS FILLING, doesn't recognize various level setting and keeps filling until it overflows
If it is filling with just water then your problem is probably in the solenoid valve body that is located right where the hoses hookup.There probably is dirt underneath the valve and it won't close properly. Or it just plain went bad and will not close.
Try replacing it.
Mar 28, 2010 | Maytag Atlantis MAV8551 Top Load Washer
Matag alantis no cold water
check to see if you have power to the fill valve when the cold water should be going in;(reverse the connectors on the fill valve) i.e. hot now will not go in... replace the fill valve: (buy it at an appliance parts store) (inexpensive) it's an easy replacement job
Jun 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis top load washer that wont' let cold water cycle through. Water is always hot or luke warm. checked screens on hoses. Any suggestions?
ok just a touch of help for ,,onthejob...i need you to start at a cycle and put unit on cold cold,,ok...now i want you to put your hand on back of unit where the inlet vavle and the hose meet at unit...do you feel a vibebration,,or here it humming,,now if hot water comes though,,all you have to do is reverse the hoses there on wrong,,im here onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Turn on cold wash and no water will run.
It sounds like your cold water celenoid is going out. You have to replace the whole water valve. it should be around 30 bucks. your local parts store should have it in stock, Just take your model # with you.
Nov 21, 2008 | Maytag Atlantis MAV8551 Top Load Washer
No hot water
Make sure your hot water supply valve is on first. If so then try reversing the hot and cold water feed lines and see if you get hot water when asking for cold. The water valve for the hot water side could be bad. Are you familiar with a voltage meter or know someone that can see if you valve coil is getting 120V when the machine is trying to fill with hot water. If not the control unit is faulty. If you do have the 120Vac on the solinoid coil and no water the either the coil is open circuit(bad) or the inlet is plugged. Most generally the problem is in the control knob unit.
Feb 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV8551 Top Load Washer Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
