Question about Epson Stylus C82 InkJet Printer
I have two computers, both of which cannot print on my printer when it printed fine before
I have an Epson Stylus C82 printer and have used it for a long time. I replaced three of the four cartridges recently and can only get print response from the one not replaced. It is a color so only get response on it when on color print setting. I have gone through the mfgr trouble shooting to no avail. Any ideas? I am not wanting to invest in a new printer if not needed.
  • 1 more comment
  • jim deforest Apr 01, 2007
    follow up to this: I have not messed with the green chip in the cartridges.
  • jim deforest Apr 03, 2007
    thanks for the try Inky I have gone through all the obvious but still think something simple is involved.....still looking but soon to give up and invest in a new printor :o(
  • jim deforest Apr 16, 2007
    here is an update: using the very complete solution I got from INKY I was able to get one more color but still no black. I have about used up the ink but it did clear up and gave me another color. W/o black it is a problem though.
    Brigadier General:
  • 6,966 Answers
Hi all, pretty good detailed step by step Inky, my compliments. If I may add, you might also want to try the SSC Service Utility downloadable from http://www.ssclg.com/epsone.shtml
Posted on Apr 10, 2007
  • Epson Master
  • 691 Answers
Hey Confuzed1 Just a simple to start you off. If you are using those horrible compatible cartridges instead of the genuine ones, check taht you have torn off any strips of plastic that need to be removed to uncover the air holes. If not the ink can not get out of the carts. If you have removed the strips or are using the genuine carts, it may be that you have a split in the tube that runs from the pump cap or that the pipe that deposits ink to the waste pads is blocked. Both of these errors usually result in a total loss of print. Have you ran the head clean function?
Posted on Apr 02, 2007
  • Inky Fingers
    Inky Fingers Apr 09, 2007
    Hey Confuzed
    Shall we try a manual head clean on your machine?
    Here goes. This is a copy of post I did relating to a C64 but the principle is the same:
    You can do a manual cleaning using some kitchen paper and a little solvent and a small plastic bag.
    The first thing we need to do is get the head away from its parking position. Switch on the machine and when the head has moved away from its park position, remove the power lead.
    With the top of the machine open, you should be able to move the print head carriage by hand.
    Look to the right where the head carriage is normally parked and you should see the pump cap area. It will be a black looking spongy pad covered in ink.
    Now take a piece of kitchen paper and fold it over a couple times to make a pad approx 3"x1". Now lay this pad over the top of the pump cap and fold the left edge down toward the base of the machine as in image one (the tissue is the yellow bit in the image)
    Now take a syringe or similar and put some solvent into it. The solvent I use is JR Ink Jet Cartridge flush as seen on eBay and the like. If you have any ammoniated window cleaner like Windex you can use this. Put the solvent onto the tissue making it quite damp, but not totally soaked.
    Manually move the print head GENTLY back to its park position. The pump cap will try to raise up to meet the bottom of the print head as you move it back. Be careful no to force it or you may break something.
    What we are trying to do is bring the solvent dampened pad into contact with the print head. Once located, leave the pad for anything from 5 or 10 minutes to 24 hours whilst the solvent does its trick.
    Now move the head away from park - again being gentle. You should now see the pad is a horrible black lump of mush. Pick it out and put it in the plastic bag ? where a glove or use tweezers or pliers.
    Repeat the process again but this time let it to soak for just about few minutes. You should now see the individual ink colours soaking into the pad. If the pad is still black, repeat the process a couple more times.
    Once you have some evidence of the individual colours you can run a head clean via the driver or printer control panel.
    Then print a nozzle check sheet and if all has gone according to plan you should have a full complement of lines.
    This method is applicable ONLY for loss of a few lines on the nozzle check sheet. If you have loss of all the lines in a single or multiple colours, you need to investigate further. It is possible that the pump has failed, the pipes are clogged or something else is causing the problem.
    If that does not sort it out, try using a syringe to put a couple of drops of solvent into the wick. That is the black plastic spike that sticks up and goes into the bottom of the ink cart when it is installed. Put a couple of drops in, put the cart back in and leave it for about 10 minutes. Then re-try 2 or 3 head cleans using the driver/status monitor.
    There is another possibility after this which relates to a hardware problem but this generally causes a loss of all ink. If you think this may be relevant to you try the documents available from http://www.tradebit.com/filedetail.php/1...
    If you need a service manual for this machine, get in touch with the folks over athttp://www.TheServiceManualShop.com
New ink but want print letters printer type epson c82
Hi there follow the steps below.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope thats start working , if no luck then un install the printer driver & restart the PC & Printer both again. NOw install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
May 24, 2010 | Epson Stylus C82 InkJet Printer
Handles paper fine but nothing prints. Carriage moves normally as though printing. No ink on paper. Cartridges are partially full.
It sounds as if your print heads are clogged. First try performing a deep cleaning from the Service menu. If this fails to clear your problem you can try to manually clean the heads but you may want to use Q-Tip's and Alcohol to clean the cartidge print head before you go to that expense.
Oct 31, 2009 | Epson Stylus C82 InkJet Printer
I have windows 7 and my printer won't print. it moves like its printing but it doesnt
You may need to download an updated driver from the Epson site. Another ugly thought; if your printer has been off for a while, it may not print at all anymore. The brand is great for hard use, lousy for only occasional use. The ceramic printhead will clog and print no more.
Oct 30, 2009 | Epson Stylus C82 InkJet Printer
I AM TRYING TO INSTALL MY PRINTER (EPSON STYLUS C82) BUT I DON'T HAVE THE CD-RPM THAT CAME WITH IT
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-C82/Drivers-Support?supportLandingPage=true
Oct 16, 2009 | Epson Stylus C82 InkJet Printer
Epson Stylus C82 InkJet Printer not printing
In view of the original poster's lack of interest in this problem, I think we can post it as "Solved by Poster"
Nov 16, 2008 | Epson Stylus C82 InkJet Printer
Printing
If you have tried cleaning the nozzles from the maintance/utility on the printers driver then chances are you are having an issue on the printhead, probably clogged. Two things, have it serviced or call Epson for support at 562-276-1300.
Jun 15, 2008 | Epson Stylus C82 InkJet Printer
Printing
change 1 cart - if it doesn't work : change printer
Jun 14, 2008 | Epson Stylus C82 InkJet Printer
Printing problem
>go to printers & faxes
>right-click on the printer icon and select Properties
>click on the Print Test Page button
>windows test page will print - if issue still persists : uninstall driver from the XP Control Panel -> Add & Remove Programs -> EPSON Printer Software
>reboot computer
>re install printer driver
Dec 31, 2007 | Epson Stylus C82 InkJet Printer
PRINT
Should be option on print driver ie Control panel/printer and fax's right lick on epson driver, properties.
Still needs a colour cart installed.
Nov 16, 2007 | Epson Stylus C82 InkJet Printer
Trying to print black only document
the problem with this printer is that all the inks have to be at a usable ink level, if any one of them are below the acceptable amount it will not print in any colour at all not even black.
Jun 25, 2007 | Epson Stylus C82 InkJet Printer
Epson Stylus C82 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
