Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Top broiler unit will not turn off. Breaker switch has to be switched off to cut power to oven. When breaker is turned back on, the broiler unit begins heating again. What is wrong with it?
  • 71 Answers
The main controller board has a stuck relay replace the controller board
Posted on Dec 20, 2008
  • Klugh Sorrells Sep 30, 2013
    I thought this was FIXya not REPLACEya
Oven locked with door open how do I reset it?
my first thought is if the oven is standard 220 three or four prong electric, for safety, go to breaker switch panel,"in House or outside of house", open pannel door and find the breaker switch marked for "oven" or "kitchen utility" . it will be a double switch of 20 to 25 amp ,"each". or it will b One breaker switch of 45-50 amp. ,switch it to off. then see that the oven has no power, the stove top as well as the lights and the oven .try to unlock it now. by lever or button ? then if not unlocking turn the breaker back on and try it again. hope it works for you.
Mar 29, 2015 | Ovens
Why oven not heating
Bad element, bad switch or other electrical problem. You could double check switch by turning on broiler element to see if that
gets hot. If so then either oven thermostat, or element. Did the circuit breaker pop off and then you reset? So there is a short somewhere, especially if it happens again. The above test with broiler element could verify power to oven. If it pops the
circuit breaker again. You need a service technician. Usually the oven requires a dedicated wire to the oven. Don't use the oven again until the problem is resolved. There's a slim possibility
that the circuit breaker needs to be replaced. How long did you use the oven? If a long time circuit breaker is more likely because
when they begin to fail they get too hot and therefore pop. You will need an electrician to change the circuit breaker if that is the problem.
Feb 13, 2015 | GE JKP90 Electric Double Oven
Oven does not heat
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Apr 18, 2014 | Frigidaire Ovens
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Frigidaire Gallery ES340 electric range, burners will not turn on
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Broiler unit in oven will not turn off
I woiuld suspect that the Heating element is shorted to ground and thats causing the heater the have i hot and one path for the electricity to go to. You are going to have to call a searvice company to do the repairs. Merry Christmas
Dec 20, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
check your house connections to the stove turn the breaker off first then reply to me
Jun 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Oven won't turn off!
it probably needed to reset computer/electroics
but i would call customer service for the brand it is a dangerous thing to play with.
make sure there were no recalls also.
Apr 05, 2017 | Maytag CWE5800A Electric Double Oven
Oven will not work
I had same problem, My solution was to turn off the breaker switch off (disconnect the power) I kept it off for 1 minute turned it back on and it now flames.
Sep 08, 2007 | Maytag CWG3100A Gas Single Oven
Oven/Broiler fails th heat
Sounds like a bimetal switch is blown. first I would check SWITCH LIMIT BIMETAL next the LIMIT SWITCH-UPPER(LOCK) Too check them first trip the breaker so you don't have power to the oven, then you will have to take the oven out of the remove the top cover. then in the center-front there are two round bimetal switchs with two wires coming out of them..remove the wires and check them with an ohm meter both should have continuity across them ...if no continuity you have a bad switch. let me know what you find out..
Aug 26, 2007 | GE Profile JT915 Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
111 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
