Question about Rackmount 19in 16 port KVM Screen / Keyboard / Touch Pad KVM Switch
I own a Tripp Lite 16-port KVM with 19-inch LCD. The power in our building went out twice and now I cannot get the KVM touchpad and buttons to work. Video and keyboard are working fine.
I guess FixYa is not the place to go if you need something fixed. It should be renamed IgnorYa!
Tripp Lite website has no solution as well. What a POS this KVM is...was!!! Off to buy a Belkin!!
Posted on Nov 25, 2009
I know it has been a long time, but I just experienced this same problem did you ever find a solution???
Posted on Nov 16, 2009
My tripp lite smart1000 lcd don't want to charge
Wait for the power to come back on. If it's already back on, unplug the unit from the wall, unplug all devices from the unit. Plug the unit in, turn it on, let it sit for an hour before reconnecting devices to it.
Oct 19, 2014 | Tripp Lite Computers & Internet
UPS shuts down without any power issues in the building. Once power is restored, there is a
Tripp Lite says the batteries are bad and need to be replaced. Holding down the speaker button on the front panel will run a self test and let you know whats wrong.
Jul 13, 2012 | Tripp Lite HTRL15UPS (Audio/Video...
I need a manual for Tripp lite omniplus 1000 lcd
Changing the battery
If your Tripp LIte Omni 1000 LCD display a fault icon and beeps after changing the battery, try the advice given by the buzzerman which worked perfect in this case:
1. Turn the UPS on. Press and hold the ON/OFF button for one second.
2. Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until beeps several times). The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound. At the end of this process the fault icon and the beeping turned off.
Feb 15, 2012 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
The LCD display no longer works on my Tripp Lite Omni 1000 LCD. Also, half of the power outlets on the back of the unit no longer work.
Be aware.
My Tripp LIte Omni 1000 LCD almost caught on fire.
I had been experiencing a spike in my power bill to the tune of 1000 Watts an hour for everything running - 24x7. I started the survey of all my equipment; TV 162 Watts; Fridge 228, etc. but none of these devices are on all day and night. I finally mapped out all the outlets and lights and was about to begin the survey. Other than the flickering lights, one big clue was that my TL's lcd was displaying a spike in voltage DOWN to 95 or so, the relay would click, etc.
I decided to begin my survey and use my second TL to help me see which circuit was faulty. When I looked at the LCD, it was blank. I pushed the ON button and all the devices plugged in went OFF and then I saw smoke coming out of the back. I quickly unplugged everything and then watched my meter. When this UPS was plugged in, there was about 1000W used per hour; I monitored it for 10 hours; 400W were used (total).
So... not only was it a fire hazard, but it sucked up 900W or so an hour.
Nov 28, 2010 | Tripp Lite (OMNI1000LCD) UPS System
How do you switch between ports on a tripp-lite two port ps2 swi
usually you tap the <SCROLL LOCK> key twice then either hit the <backspace> key or the left or right arrow keys.
Oct 10, 2009 | Tripp Lite (B034-002-R) (B034002R) 2-port...
Tripp Lite KVM monitor light doesn't come on anymore .....
The switch may be the problem but it also may be the monitors internal power supply. To check you can open the case by the little switch and remove the plunger ( the little pin that moves up and down) If you get a picture back then the switch is the problem and you will have to bend the flat spring up to give it a little more movement. I would be if the monitor is about 2-3 years old that the problem is in the power supply board. After a few years many LCD monitors have issues with the power boards blowing capacitors. It happens on desktop monitors and rack mount units too. If you have an external power adapter for the monitor check the voltage output and replace if it is not steady. If the power supply is internal to the monitor then you will need to open the case and check the capacitors for heat damage. Check our site at:
www.ccl-la.com/badcaps.htm for pictures of what to look for. Replace any that look like the pictures and you should be back going again. The values that you will need are going to be marked on the sides of the bad caps. Be sure to use a high temp replacement or the problem will be back in a month or two. If yo don't want to do the repair yourself we do offer a repair service of the monitor for $40 plus return shipping. If you have any questions just let me know.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 22, 2009 | Tripp Lite Lite 16-Port 1U Rackmount...
Tripp Lite B034-002-R 2-port
press numlock twice. There may be other hotkeys, but that's the one that I use. Occasionally mine gets confused (because of reboots and hibernation) and I need to unplug the usb cables from each PC and then plug them back in. Then it works again.
Jun 25, 2008 | Tripp Lite B034-002-R 2-port KVM Switch
Mouse not working KVM Switch
First question, jatraczyk - have you tried a different mouse?
Mar 04, 2008 | Computers & Internet
Rackmount 19in 16 port KVM Screen / Keyboard / Touch Pad  KVM Switch Logo
143 people viewed this question
Top Rackmount Computers & Internet Experts
David Payne
David Payne
Are you a Rackmount Computer and Internet Expert? Answer questions, earn points and help others
