Question about Aprilaire 700 Humidifier
No water I have water to the solenoid, but it doesn't pass thru
  • 2 more comments
  • GP09 Jan 11, 2009
    I have the same issue, and no I don't seem to have power to it. I cannot hear it turn on.
  • Anonymous Jan 29, 2009
    Mine had a similar problem. Fan was running, but no water was flowing. I turned off unit then banged on the solenoid a couple of times and wiggled all wires, then turned to test mode, heard click and water flowed. But when I dialed off of test mode and set to setting #5, water shut off and when dialed back to test mode a second time, no water flowed and no click was heard. I even turned off the whole furnace and the humidified controller, then turned furnace back on, waited and turned controller to test mode, but nothing...Now it get no water and no click when I turn it to test mode.
  • rp0826 Feb 21, 2009
    Water is flowing from the water heater to the solenoid (disconnected line and verified). Water is able to flow through the outlet tube (I've verified there is no obstruction). Hear click when I turn up the humidistat, but no water flows. Turn it down and it clicks again so I know it's cycling correctly. No water is flowing through the solenoid.
  • Stephen Evans May 11, 2010
    You have no voltage to the soleniod valve. do you hear the humidistat click when you turn it? Steve
    Champion:
  • 244 Answers
Could also be a clogged filter or orifice. take input line off solonoid and check.clean filter, blow thru orifice. clean with small needle or buy new one.
Posted on Jan 15, 2009
No water flow
No water flow thru solenoid valve? or thru the drain?
Jan 15, 2013 | Honeywell 4500 Sq. Ft. Whole-House...
Humidifier doesn't work
Hello, if there is water to the solenoid valve but not passing through it than the solenoid valve is malfunctioning and must be replaced. However, if there is no water at the solenoid valve then either the saddle valve or supply line is clogged with sediment. A easy way to chek the solenoid valve is apply power directy to the solenoid valve from the transformer, if it does not open then replace it.
Nov 17, 2011 | General Filters 1099-LH Humidifier
There is no water going into the humidifier, make: Generalaire 1042
Hello, first thing is check is the strainer going into the solenoid valve for sediment, if there is clean the strainer and reinstall. If the strainer in clean the check if you are getting 24 volts to the solenoid valve, if you have voltage and the solenoid does not let the water thru replace the solenod valve.
Apr 09, 2011 | General Filters 1042-LH Humidifier
There is no water getting to the unit and the water line is ok
Hello, first check the strainer on the inlet side of the solenoid valve, if there is sediment built up clean it and reinstall, if the strainer is clean and you are getting 24 volts to the solenoid valve and it is not allowing water thru replace it.
Mar 31, 2011 | Aprilaire 550 Humidifier
Our humidifier is not kicking in and operating. after inspecting the filter which i changed out last August, it does not look like it has been operating at all and the house has been dry. I loosed the...
Hello, if you have 24 volts to the solenoid and the valve does not click open then it must be replaced. Also you can aplly power directly to the solenoid from the transformer and see if it will click open to let the water thru. either way looks like you solenoid is bad.
Mar 05, 2011 | Aprilaire 600 Humidifier
Will the water only come on going thru the water solenoid only when it calls for water? Or is it suppose to come on at all times when furnace comes on?
The water should come thru the solenoid valve when the furnace's blower motor turns on, and turn off when the blower motor turns off.
Jan 04, 2011 | Aprilaire 600 Humidifier
Solenoid on Aprilaire whole house humidifier
the solenoid allows water to flow to jet that then runs down the pad the solenoid is control by the stat
Feb 23, 2010 | Aprilaire 700 Humidifier
Testing a Aprilaire Humidifier 600 Controller
if it works in the test mode then it should be okay but you can get a humidity gauge from radio shack and set in the house to see how high or low its is. the humidifier is only going to give a max of 45% humidity
Nov 27, 2009 | Aprilaire 600 Humidifier
It's getting water from supply but not putting it thru to the pad.
the orifice after the solenoid is plugged. Shut water off remove line after the solenoid valve and clean orifice. This should do the trick.
Nov 03, 2009 | Aprilaire 550 Humidifier
He220a water not going thru solenoid
trace thre copper tube backwards to where it connects to main water line if there is a valve there open and close it if your not sure whats open or closed try it both ways there is also a little restriction device either on inlet or outlet of solenoid that may be clogged
Feb 05, 2009 | Honeywell HE220A1019 Whole House...
Aprilaire 700 Humidifier Logo
209 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
1STHVACMAN
Doug
Level 1 Expert
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
