Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
Blank Screen Problem
Hi! I bought my DLP (HLP6163W) in 2003 (it is out of warranty now) and I got the dreaded three flashing lights and so bought a new lamp and set that up and everything was working fine for about 15 days and then two days ago while watching cable the screen turned blank (black). The TV is on (like watching a dark room with very little light in a movie) as I can see a glow throughout the screen so I presume that the lamp is still working, there are no lights (led's) flashing or on in the front on the TV, I can also hear the fans working so I am not sure what's going on. Thanks Sarosh
  • bry_welsh Oct 24, 2008
    I have a few issues. Fisrt off, the TV will shutdown and display the three blinking lights. I've noticed that I can turn it on and it will stay on for a few minutes, come back turn it on again and it will stay on a little longer and then eventually will stay on for quite a long time. Second, if I'm watching something through component or hdmi/dvi connections, the picture will go black but I'll still have sound. Once in awhile it will say that it has no signal. Then the picture will come back. I've also noticed a faint white spot in the lower edge of the screen right in the middle. It's more noticeable if the backgound behind it is dark. I'm considering getting a new lamp to start but am wondering if I should be looking elsewhere (PCB assy, power supply, ballast)? Any advice would be appreciated.
    Novelist:
  • 192 Answers
Does the menu come up? If it does, then, the source could be the problem, such as the cable or DVD player. If the source is not the issue, then, the problem would be in the Digital or Analog PCBs. If the menu does not come on, then, the problem is more than likely the DMD. If it is not the source then call a local authorized Samsung servicer in your area. Contact 1-800-Samsung. Hope this helps.
Posted on Apr 01, 2007
Blank screen, led lights flashes for a while and thn all three flash. also cannot turn off at tv or with remote. have to unplug
Samsung HL67A750A1F red DLP LED failure repair ...
? 10:35
https://www.youtube.com/watch?v=xHE1knzJSfQ
Jul 21, 2011 - Uploaded by daveshelbygt
Samsung PHLA... ... Samsung HL67A750A1F red DLP LED failure repair .... tv only works when plugged in. black screen, any suggestions?.
HL67A750A1F Blank Screen, And The LED Lights Are On ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsFeb 24, 2011 - Click here if the screen is blank and one or more of the LED lights on the front of the TV are on or are flashing.
Samsung HL67A750A1FXZA Repair Success Stories ...
Jan 19, 2016 | Samsung HL67A750 67 in. TV
Samsung hlp6163w dlp tv not working, new lamp, new ballast, still three blinking lights
If color wheel does not run lamp will not fire----with lamp removed have you looked at the wheel----if not running it will cause almost instant shutdown of lamp and the set.
If the DMD board is bad time for a new set as it is well over 500 .
Mar 28, 2012 | Samsung HLP6163W 61" Rear Projection...
The screen on my Samsung DLP tv turned off with the volume still playing. The lamp light started flashing. We replaced the lamp and it doesn't seem to have fixed anything. What could be wrong?
Lamp Fan could be defective or the Ballast Board ,it is what powers Lamp.
Encompass Parts Distrubution 1-800-638-3328
Go to this website and type in your Model# for list of Parts /Prices
Oct 07, 2010 | Samsung HLP6163W 61" Rear Projection...
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
Heard a pop and screen went blank - won't come back on.
Your Lcd Projector Lamp/DLP Television Lamp went out
its about $165-$200 to replace if not under warranty
Nov 28, 2008 | Hitachi Televison & Video
Samsung HLP6163W wont turn on
I went to sleep my tv was play i woke up and don't work so i turn it on popping crack sound and it shut down what do nowno tv
Sep 13, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Shadow down left hand side of screen
Is it an LCD or DLP? The Model below suggests it is an DLP. Sounds as if you have the dreaded light tunnel collapse common to all LG DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps. Good Luck.
Jul 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
