Question about Venturer PVS62911 Car Video Player
Where can I purchace a car charger for my venturer?
I am assuming that the power cord has gone bad because there is no power to either unit. This is only a year old.
  • johnphel Dec 27, 2008
    No power, last time had hard time car charger staying connected. Now no power.
    Champion:
  • 303 Answers
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for VENTURER PVS62911
Posted on Jun 03, 2009
  • 3 Answers
Is this a dvd player if so on screw the tip of the charger and check the fuse if thats good try diffrent car cig lighter
Posted on Dec 20, 2008
I have lost manual for clarke 4000 jump start having never used it since purchacing,how do i charge it up,is it with the start switch turned on or off.i would be grateful for any help or can i download a...
The manual for the Clarke 4000 is available here: http://www.clarkeservice.co.uk/manuals/jumpstart/jumpstart4000.pdf .
You can charge the unit either with the 230V DC adapter plugged into your wall outlet or by using the 12V adapter plugged into the cigarette lighter (assuming the battery is good) of your vehicle.
If you are using the wall outlet, plug the end of the power cord into the charger then plug it into the wall outlet. Then turn on the charger. Disconnect when the red charging LED goes out. (If you press the TEST button, you can find out the state of the battery. After a number of charge/discharge cycles (even when unused), the battery will need to be replaced every few years.)
I hope this helps.
Sep 21, 2011 | Garden
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
How do you change a battery in a 1999 chevy venture van
Assuming you have a battery charger. Do not plug charger in until after it is connected.
1. Open hood & locate battery.
2. Identify the positive terminal of the battery (usyally has a red cover or red marking.
The battery has side terminals (not posts like nonGM batteries)
4. Connect the + red clamp the the positive terminal wiggle it a little to get good connection.
5. Connect the negative black clamp to the engine block, a handy bracket on engine or the negative terminal on the battery. DO NOT CONNECT TO ALTERNATOR
6. Be sure connections are secure.
7. Plug in charger it should show charging. Leave it over night
8. Before disconnecting charger disconnect power to the charger.
THE FUMES OF A BATTERY ARE EXPLOSIVE DO NOT USE FLAMES NEAR BATTERY
DO NOT ALLOW SPARKS NEAR BATTERY!
Dec 08, 2010 | 1999 Chevrolet Venture
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
Car Charger and home charger
my car dvd melted around the edge while it was plugged to recharge in car bmathis7643@bellsouth.net
Feb 04, 2008 | Venturer PVS177W Portable DVD Player
Venturer PVS62911 Car Video Player Logo
775 people viewed this question
Top Venturer Car Audio & Video Experts
Hjalmer Lamminen
Hjalmer Lamminen
Marvin
Marvin
seankane89
Level 1 Expert
Are you a Venturer Car Audio and Video Expert? Answer questions, earn points and help others
