Question about Kenmore 63942 Dryer
Dryer vent replacement
Can't get the back off my kenmore dryer to replace vent hose
  • 640 Answers
You dont have to take the back off unless you bent the hole back in..standard 4 inch sleeve and slide it on add 4 inch clamp and your good,
Posted on Dec 26, 2008
Kenmore Dryer 700S Check Vent is on and sometimes the letters AF appear in the iMessage remaining Box. The Vent has been checked and vacuumed, but light remains on
that code mean low air flow u clean vent hose did you check an make sure that there no lint build up the vent coming out of the back dryer were bent hose connect to back of dryer are if this a house are a apartment vent hose could be to long cause .
May 28, 2017 | Kenmore Dryers
MY DRYER QUIT HEATING AND THE TIMER WOULD NOT CUTOFF THE LAST FEW MINUTES AT THE SAME TIME. REPLACED THE ELEMENT AND THERMOSTATS AND FUSE. ELEMENT HAD OBVIOUS BREAK IN COIL. REPLACED THE TIMER AND THE
Have you reached into the back the dryer's vent port? Most will just replace the hose but fail to clean out the dryer's internal vent tube from the internal blower.
Re-check the fuse, a clogged internal vent tube will blow the fuse again.
Mar 31, 2014 | Kenmore Dryers
Kenmore Elite Clothes Dryer working but not drying
First take dryer vent hose off and check for a plugged vent, clean it all out. There is either a clamp on the hoses you take off by prying or with a screwdriver, should be two one at the dryer and one at the vent to exit the house, also make sure that there is nothing blocking the door on the vent that exits the house sometime animal like to build nests there. If this does not fix the problem it could be the heating element in the dryer, sometimes it is cheaper to just replace the dryer than the element
May 21, 2012 | Kenmore Dryers
I have a kenmore 697267 I have to run the dryer 2-3 times before clothes will dry, the cotton cycle doesn't work, the vent hose has been cleaned out and the cycle knob has been replaced. How do I fix...
check your vent 99% of all dryer problems are caused by the vent, Make sure you do not have too many turns in the vent hose and ithe lenght is as short as possible
Jul 20, 2011 | Kenmore 700 6972 Dryer
I have a 27 inch Kenmore Elite gas dryer model 110-73032101. After about 5 mins. the burner shuts off and won't reignite. Is this a problem with the thermostat or sensor
Hi, Check your vent hose in the back. Where it comes off the dryer, it must go straight to the wall outlet with no bends or curves. Check your vent outside, and clean if necessary. Last if this fails to correct problem, thermostats need to be replaced. Hope this helps.
Jan 17, 2011 | Kenmore Dryers
Slow drying time
very simple, do this test, take your vent hose off the back of your dryer, now dry a load of clothes, if it still takes a long time to dry, then you may need to replace your thermastats, if it works better, your vent hose was pushed in, or smashed or the vent from the wall to the outside is clogged.
thanks Whites appliance repair
Sep 07, 2009 | Kenmore 659 Electric Dryer
Dryer is hot, clothes arnt getting dry. blower? less that 1 year old Kenmore
Remove the vent hose from the dryer and dry a load of clothes . If they dry , then dryer is pushed too far back , kinking vent hose , or the vent from the dryer to the outside is blocked somewhere . A dryer either heats or doesn't heat (except for maytag associated dryers ) in which the blower wheel could be stripped out . But Kenmores don't have blower problems .
Aug 09, 2009 | Kenmore 600 7965 Dryer
Kenmore Electric Dryer Can't replace heating unit
I removed the deflector and duct from outside the house, disconnected the hose, attached the hose to the dryer, passed the hose through the wall as the dryer went back in, then reattached the hose to the duct/deflector and reinstalled the duct/deflector
Feb 09, 2009 | Kenmore 659 Electric Dryer
Replace dryer vent hose
The vent hose connection protrudes from the rear bottom center of the dryer.
Nothing needs to be removed to connect a new vent.
Jan 17, 2009 | Kenmore 63012 Electric Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore 63942 Dryer Logo
62 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
