Question about Kenmore 63942 Dryer
How do I get to the inside of my kenmore dryer to repalce vent tubing ?
  • Kenmore Master
  • 2,651 Answers
There should be no reason to get inside the unit to replace hte vent, generally the ventingis replaced form the outlet behind the dryer , the inner span of metal never needs replacing
Posted on Dec 20, 2008
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
I have a front load Kenmore dryer HE2 that seems to be getting very hot...only in the inside. You can really feel it more than normal when you open up the door
Your exhaust is plugged. Start your dryer go outside to the vent and feel for air coming out. If no air or just a little is coming out, check your exhaust tubing. Make sure you check the outside vent.
May 30, 2011 | Kenmore Dryers
My kenmore elite mod. # 110.67062600 keeps flashing af
It is due to low air flow (AF),clean the vent tube out. The easiest thing to do is disconnect the vent and run the dryer, the AF will not be displayed, you can take the back top panel off an on the inside is a sheet with codes and how to take apart your dryer, as you have lint inside the dryer as well and should be cleaned out at least twice a year, varies on usage. Hope this helps Tim
Apr 07, 2011 | Kenmore 67032 Dryer
Dryer takes too long, removed the vent and it works great
Your vent is clogged up. Clean out the vent tube going out the wall and inside the dryer if you are able to.
Nov 22, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Heat does not go on and stay on clothes tumble but are still damp they never completely dry in 70 min.
sounds like a venting problem, check vent tube for restrictions, you can take the tube off and run the dryer, should have hot air blowing out, if you do then it is the vent tube if not then you will have to clean the inside of the dry out with a vacuum. Good Luck Tim
Oct 25, 2010 | Kenmore 73952 Gas Dryer
My Kenmore Elite dryer works except there is no heat to dry.I am looking for suggestions to repair. Thanks
There is a moister sensor in your dryer that detects any lint build up inside the exhaust vents. If any obstruction is inside the exhaust tubes this sensor will put the heat in the check mode. Inspect and clean thoroughly and see if it will heat up again
Aug 03, 2010 | Kenmore Elite HE4 Electric Dryer
Element too hot
if this is a kenmore or whirlpool,roper,kitchenaid dryer than you will only see the element glow if you look inside the dryer.if you see a glow at the vent hose,you nead to shut the dryer down,unglug the dryer and remove the vent hose and clean it out from the dryer to the vent outlet outside.
Oct 20, 2009 | Kenmore 63942 Dryer
Kenmore 800 dryer burning smell and noise.
that doesnt seem right about the connection to anything if you are hearing like a humming noise you have a bad motor  its pretty challanging to fix it if you havent done it before
the bottom panel has two clips in the upper part about 3 inches from each side you have to kind of pry them  if you look at it you'll see exactly how they work once you take that panel off ou'll be able to see the tubing of the inside of the dryer
sorry if i didnt help too much  if got questions please feel free to reply
Jun 06, 2009 | Kenmore 800 6983 Electric Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
