Question about Garmin nuvi 200W GPS Receiver
European maps wont work
My new nuvi 200W works well in US but now I am in Europe and my brand new SD card with european maps refuses to work.
Thanks for response, problem is solved. Someone else advised me to be little more patient with exposig my unit to the satellites outside of the building.
Regards.
Posted on Dec 20, 2008
I bought the europe sd card. If I insert it will I lose all the US data?
No, the US data is on the unit itself. Adding an SD card with maps only increases the number of maps your unit can handle, it doesn't replace existing maps. You'll have to go into settings to change the view to European maps.
Sep 18, 2011 | Garmin nuvi 350 GPS Receiver
Can we download European maps onto our Garmin 200W for travelling with motorhome
If you bought the satnav in the USA it won't work in Europe. If you bought it in Europe you can download the maps but the full map of Europe won't fit on it. You can fit Western Europe or add and remove countries as you need them. It's probably not a satisfactory solution when traveling with a motor home. You can put the map on an SD card but the nuvi 200W has problems reading maps from SD cards of 2 Gb or more. The map of Europe would take a 4 Gb card to hold it all.
You would probably be better to buy a cheap satnav of Europe. You can get them from http://www.pixmania.ie/ie/uk/xx/617/xx/1914/23/criteresn.html?sSortInfo=Prix-ASC
if you want to buy on line or Halfords shops if you prefer to deal with someone face to face. Some of them cost less than €100 and would be near the same price as buying the map of Europe.
Or if you want a satnav that covers both the USA and Europe and will work in both the Garmin nuvi 1370 or the 2370 would do the job but costs a bit more.
I hope this answers your question.
Jun 07, 2011 | Garmin nuvi 200W GPS Receiver
I am traveling ion europe and have purchased a set of european maps for my nuvi 1300. i need to transfer the maps from the sd card to the nuvi 1300
If you bought your satnav in the USA don't transfer the maps to your satnav. The USA version of the satnav won't work in Europe. If you bought the satnav in Europe you should only have to plug the SD card into the satnav for it to work.
Jun 06, 2011 | Garmin nuvi 1300 Car GPS Receiver
I have inserted micro SD card for Europe but have no recognition on the 1490T. Do the European maps only appear when in Europe ?
When adding maps via the SD card slot they will automatically be activated, to see this go to Tools > System > Maps > "Map Info" from here you will be able to see what mapping you have on your unit.
Hope this helps!
Apr 06, 2011 | Garmin nuvi 1490T GPS Receiver
I have a Garmin Nuvi 260 and I just purchased a City Navigator Europe N/T data card. I inserted the card and didn't see anything that showed it was added. Do I need to be in Europe for it to work or do I...
As long as you can see the software on the list of Maps, you'll be fine. It wont show any maps right now because there are no European maps for your present location, you need to be in Europe for the maps to show on the screen.
Sep 19, 2009 | Garmin Nuvi 660 GPS Receiver
USA Garmin nuvi 200. Can I download Ireland map?
You will have to buy a version of European maps. After you download them into your Garmin it will work just like in the US.
Here is a link I found for you. It looks like you need to buy all of Europe but there may be a way to just buy individual countries. Best wishes on your trip.
Wide and way cool, nüvi 200W shows you the way with detailed maps on a bright ... Garmin Garage" vehicles compatible (download car-shaped icons to your device ): yes ... nuvi 200W, Eastern Europe, 010-00656-25. nüvi 200W, Italy, Greece ...
https://buy.garmin.com/shop/shop.do?pID=9122
Aug 17, 2009 | Garmin nuviĀ® 200 Car GPS Receiver
How to upload maps in garmin 200w from sd card
on menu touch tools, maps, map info, tick the box, you may need unit I.D. and serial number.
Regards.
Mar 21, 2009 | Garmin Nuvi 660 GPS Receiver
Add Europe sd card to Garmin 660
No. When you plug in the SD card, the Nuvi will load the map from your SD card. Once you get to the main menu, select the wrench symbol, then the map symbol and then "map info". You should see both the US and Europe map. Make sure the Europe map is checked. You can uncheck the US map. This is how you switch between maps. The reason why you have to have the extra map on the SD card is because the Nuvi can only have one map on it's internal drive, one at a time.
However, backing up your US map is a good idea.
Good luck,
- Jim
Nov 21, 2008 | Garmin Nuvi 660 GPS Receiver
Europe SD card wont work
tap on the wrench, tap on map, tap on about map, there you should see the base map checked, and the Europe map unchecked, uncheck the us map and check the europe map by tapping on the check box. leave the menu.
May 27, 2008 | Garmin nuvi 250W GPS Receiver
Nuvi 660 MapSource
Henry,
You cannot replace American maps with European maps.  Garmin does this in order to protect the European retailers.  The European SD card eliminates the need to load the maps into the 660, however, if you need to use the card slot to store extra data such as MP3s then you might be better off buying the 670.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
130 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
