Question about Linksys Ultra RangePlus Wireless Routr Router
Can't go no more than 20ft from the router with my laptop
In the same room I can get on line but when I go into a different room the signal gets weak and at 20ft I can't sind on with my laptop
    Genius:
  • 1,269 Answers
What you can do is try changing the router's channel. Follow the steps below:
1. Open Internet Explorer and type 192.168.1.1
2. It will ask for username and password. No username and password is admin
3. Click on Wireless tab. Select Standard for Radio Band and select Channel 11 for Standard Channel. Click on Save settings.
4. Check the signal distance now
Posted on Dec 20, 2008
My laptop is in the living room, my 2WIRE router in the bedroom. When I turn on the MAC it sometimes indicates that I am not connected to the Internet. I then have to fool around with diagnostics to try...
I would boost the signal it can only help I had the same sort of problems but my wireless router quit working properly my iPad wouldn't pick up signal so I had to replace my wireless router hope this helps Merry Christmas
Dec 09, 2017 | 2wire Wireless-G 802.11g ADSL Gateway
A friends iof my gave me this router, but I don't know how to install it so that i can use it with my laptop in my living room. my internet is connect to my computer in my room. My main internet is in...
You have a few options. If you already have a router, set this one up as an Wireless Access point. It pulls signals from the main router and you can connect to this one. BUT your signal could be weak depending on the distance, walls etc. If you can make a cable run, use it as a switch. (Extend your ports, and as a wireless point. Go to Cisco Linksys and download the manual.It is not difficult. Use the main router as a your DHCP and this one as a wireless point. You will need to set up the SSID and security (Securty is optional, but I would do it). Give it a SSID different then your main one and you can setup your device to connect to the one with the strongest signal (Most do this by default.
Dec 18, 2010 | Linksys Wireless-G Broadband Router
I installed a beetel 450TC1 ADSL2 Router 2 days back. It works fine on my workstation PC. Using my laptop from another room (5 meters away), after 2-3 minutes usage, surfing stops, on checking says no...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Oct 09, 2010 | NetGear WGR614 Wireless Router
2.4 phones interfering with my wirerless netgear router. every time the 2.4 phone is in use it kicks me off the internet. how can i fix the problem without replacing the phone
Sep 21, 2010 | NetGear WGR614 Wireless Router
My Belkin N-1 is very weak. Can't get a signal from one room to the next. Is there a fix or does it need repair?
Try changing the channels on your router... Also, if you have a wireless phone near it make sure that they are using different channels or better to move it away from your router... very thick walls also weakens the signal... try placing it first near your laptop just to check that you can connect wirelessly before you move it away... you might just need an range expander or repeater to boost up the signal
Mar 28, 2010 | Belkin (F5D8231-4) Wireless Router...
Not receiving n-type signal from router
Put the laptop next to the router and see what signal you then get. do the following
---- start>control panel>system and maintenance>system>device manager on lefthandside> network adapters click on the +sign>right click on the wifi adapter>properties>now in there there maybe a TAB for advanced which allows you to select the type of signal the adapter is set for - check its not set to G. ----- loss of signal in room, wifi signals can be reduced, if they pass through walls etc - sometimes just a small change in the routers position or aerial alignment can make a big difference ------ download and install - http://www.xirrus.com/library/wifitools.php - you can then monitor on the graph the signal strength and see when it drops off -------- also a change in the wireless channel used on the router can helpp - Use channel 1 or 6 or 11 as they do not overlap - have a look at the other signals being broadcast and what channel they are on - then choose one that is free or also on a very weak signal to minimise interference
Mar 17, 2010 | Broadcom BCM5705 Network Adapter
Have a 2Wire Router from SBC that has recently been causing connection problems with my sons XBox. Low signal roughly 2 bars. Nothin has changed in the house. Have router in main bedroom, Xbox is in son's...
if signal is fading in and out there are a lot of factors. 1 have you installed an other electrical epuiment in the house? emf cause interference. 2 if you move the xbox to the same room as the router how is the signal? d3 do you have a laptop to try next to the xbox where it is at now and see the signal? if it is weak on ther laptop also get a new router.4 if the signal is good on the laptop your xbox is the problem.
Dec 30, 2009 | 2wire HomePortal 100W Router...
Toshiba satellite l505-s6906 will only connect to a linksys g router in the same room as soon as i leave the room it disconnects
Check to make sure the lead are firmly connected to the wireless card. If they are make sure that they are reversed. Also if you have a neighbor next door that has a computer with wireless, see if it picks up your router, that way we can determine if it is a network or computer issue.
Sep 16, 2009 | Computers & Internet
I have a verizon westell 7500 gateway router. Will I be able to use a netgear WG111 2v wireless adapter to get a stronger signal from it for my laptop?
I'm not sure what you are trying to do. Is the signal too weak?
You could use the router to extend the range with the proper configuration. Either that, or purchase a wireless extender that does just that.
You won't get a stronger signal. A router does not boost a signal. It can pick up the signal and rebroadcast it using a different IP.
Jul 23, 2009 | Computers & Internet
Linksys Ultra RangePlus Wireless Routr Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
