FixYa.com
Tags:
Centrios Portable CD Player Carrying Case Personal CD Player
How to Restore a CD?
By Ranny - usenet poster
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2005
Not Rated (0)
maartenw
maartenw - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If a CD or CD-ROM gets scratched, it often becomes unplayable. Don't write off your favorite album or computer game yet, though.
1. Clean your disc so that you can see where the scratches are. Holding the disc by its edges, wash it with mild soap and water and pat it dry (don't rub it or you'll make more scratches). Sometimes this is enough to make a disc playable again.
2. Examine the clean disc carefully under a good light. Scratches that are likely to affect disc play run parallel to the edge of the disc. Vertical scratches that run between the center hole and the edge are usually not a problem.
3. For minor scratches, carefully clean the clear plastic that protects the aluminum inside the disc. Use a soft, damp cloth and a small amount of very mild abrasive cleaner--plain white toothpaste, metal cleaner or plastic cleaner. The key is not to make new scratches. When polishing or cleaning, always rub gently from the inside of the disc to the outside (see illustration). That way, any scratches you make will be the harmless vertical kind.
4. After wiping away a scratch, clean the disc again, let it dry and try playing it again. If it still skips, repeat the process.
5. If your disc is severely scratched, try using a combination abrasion and waxing technique with a commercial disc-repair solution.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Audiovox (DBCE600MP) Personal CD Player GPX CDP3305 Personal CD Player GPX CDP3106 Personal CD Player GPX CDP3107 Personal CD Player GPX CDP-3315SP Personal CD Player GPX C3871 Personal CD Player GPX C-3949BI2 Personal CD Player
Can you Help with these Personal CD Players problems?
Personal CD Players
I cant turn on my cd stereo
just stop it and no work any... Answer This...
Personal CD Players
won't play discs
6 cd changer just keeps loading... Answer This...
Personal CD Players
ERROR
Hi, I have a GPX portable cd... Answer This...
Personal CD Players
f61 error code
i have a ak640 hifi and get the... Answer This...
Centrios Portable CD Player Carrying Case...
Portable cd player can't read...
My daughter has a Philips... Answer This...
Repair Service
Find Personal CD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
