Question about Sony VAIO VGC-LS30E 1.73GHz Pentium Dual Core 2GB RAM 250GB hard drive - 19in. Display PC Desktop
How to wall mount a All-in-One Desktop SONY PC VGC-LS30E
I need to wall mount a all-in-one Desktop SONY PC VGC-LS30E.  Is it VESA compatible if so what standard?
Thanks
  • Anonymous Mar 06, 2009
    Same here - I just got one and from looking at it, I really don't think it has any wall mounting capability. I don't see any mountpoints at all.
  • 111 Answers
SOURCE: Does Sony VAIO VGC-RC110G PC Desktop has digital tv
no computers are digital anyways
Posted on Dec 21, 2008
  • 707 Answers
SOURCE: My Sony VAIO VGC-LS21N PC Desktop or pcg 252L
Check to see if your RAM Module(s) are seated properly
Posted on Oct 15, 2010
  • 165 Answers
SOURCE: I need the assembly and
Hi Friend, Please follow the link :
http://www.generalmanual.com/Desktop-PC/Sony-VGC-LS30E-VAIO-All-in-One-Desktop-PC.htm
you will find the User guide on the left side somewhere near to the bottom of the page.
Posted on Dec 08, 2010
  • 57 Answers
SOURCE: How do you remove the back off the Sony VGC-V617G
A requirements check before begining technical expertise
1. Acquirre an area space where the computer system would be placed during the technicality
2. Acquire a toolbox kit, examples of required tools are screw drivers of various size denominations.
3. Acquire an assistant
The procedures during technical expertise
Important notes
The fan is located at back of computer attached to the motherboard.
Perform an observation of the placement of the system unit on work floor area
Precautions before starting technical expertise
1.Power off device from all energy outlets
2. disconnect every peripheral devices, examples faxes, printers
3. disconnect every wiring cables
4. the only remaining device would be the system unit.
placing the system device on the space area where the technicality would be performed
1. acquire assistance in gripping,
2. carefully observe the screws hinging of component lids.
a. unscrew every hinge loosening entirey, though carefully preventing least damage to any components.
b. Snap open each closure lids to the system units by applying pressure towards any indications of directional dislogdement.
Precautions
1.The lid component parts upon removal exposes the motherboard of circuits.
2. The motherboard is hinged onto the last remaining frame. so long as the fan has been exposed, discontinue dislogding any parts.
3. The fan is situated on the motherboard grpped together by tiny screws.
a. retrieve to unscrew directly the fan from the board. After which instance should require snapping the fan out of its brackets.
Cautions
1. Retain component parts to the device.
2. prevent foreign obstacles from compromising the exposed system circuits.
3. keeping a visual memory of events during technciallity should contribute towards reinstallation of parts once acquire.
Posted on Dec 20, 2010
  • 8909 Answers
SOURCE: SONY SAID I NEED A
The part number will be printed oo the board or on a label stuck to the motherboard. Usually in a prominant possition.
Posted on Mar 28, 2011
WHERE IS THE LOCATION OF THE INVERTER FOR MY Sony VAIO VGC-LS30E Desktop PC
The inverter on a laptop is located at the bottom of the LCD screen behind the plastic bezel between the laptop hinges.
Apr 11, 2012 | Sony VAIO VGC-LS30E Desktop PC
I have a Sony Vaio VGC-LS30E. Since yesterday its monitor put on black and following it turns off inmeddiately. Today when I try to turn it on, it has many colors. I want to know if you know what happen...
The video chip failed. Since its soldered on the motherboard the entire board will have to be replaced - a complicated and expensive job that only a repair shop should do.
Sep 05, 2011 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
SONY SAID I NEED A NEW MOTHERBOARD FOR MY VGC-LS30E BUT THEY WOULDN'T GIVE ME THE MODEL # HOW DO I LOOK IT UP
Mar 28, 2011 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
I need a wall mount bracket
Most if not all tv's are VESA compatible. All wall mounts are VESA compatible, meaning you can buy any wall mount you see fit to mount your tv.
I'd look into Sanus brand mounts, they're pretty decent.
Mar 08, 2011 | Emerson LC320EM8 32 in. LCD TV
Turned on my VGC LS30E and get the message "operating system not present". I can get to bios but not sure what to do. I have the system recovery DVD's but when I follow the directions (put in disk, turn...
You need to boot from them to launch the recovery process. The key to press to select boot device is in the first screen that appears. Press it, select the cd/dvd unit and follow the instructions on the screen.
Sep 02, 2010 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
Screen is blanksony vaio vgc-ls35e
Sometimes there are 2 video cards in your computer. One built into the motherboard and one seperate. Make sure you are plugged into the right one.
Jan 22, 2010 | Sony VAIO VGC-LS30E Desktop PC
My hard drive just crashed on my Sony Vaio VGC-LS30e so I replaced the hard drive with a WD SATA HD and the computer is not recognizing it, neither is BIOS. Any suggestions? I went to put the old HD in as...
A bit of research revealed that the system came with a 250GB SATA drive, and the BIOS should have recognized either drive. Check the cable from the Hard Drive to the Mother Board if possible, including the Power connectors.
Sep 21, 2009 | Sony VAIO VGC-LS30E Desktop PC
Problem with TV functionality on Sony VAIO VGC-LS30E
Sony VGC-LS30E NVIDIA Display Drivers for Vista Home Premium -
http://sony.driversdown.com/Download.asp?ID=91768&Url=ftp://download.sony.com/US/pc/NVDVID-12674100-US.EXE
Jan 04, 2009 | Sony VAIO VGC-LS30E Desktop PC
Sony VAIO VGC-LS30E 1.73GHz Pentium Dual Core 2GB RAM 250GB hard drive - 19in. Display PC Desktop Logo
143 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
