Question about Frigidaire FGF337 Dual Fuel (Electric and Gas) Kitchen Range
Fridgedaire stove fgf337ebd f10 code
F 10 code came up want to know why
  • 750 Answers
Hello
Welcome ,
F10 Runaway Temperature.
(F10 only) Check *RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
You will need a professional diagnoses to determine the extent of this damage
Thank You Huum
Please remember to leave a solved rating before you sign off!
Posted on Dec 20, 2008
Kenmore stove
This is the link to the instructions for troubleshooting the error on your stove. You may need to replace a part.
http://www.applianceblog.com/mainforums/threads/34276-F10-Error-when-using-bake-or-self-cleaning-seems-to-work-fine-when-using-broil
Nov 29, 2013 | managemylife.com
F-10 error code on stove
What Kind Of Stove? The following is for troubleshooting an F-10 error on a Kenmore stove:
Crosley oven dont work f 10 gas
The "F10" oven error code means "Runaway temperature"
try this link http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/70424-what-does-f10-error-code-mean.html#ixzz2VTV50IJ4
Jun 06, 2013 | Ovens
What does it mean when the oven beep and F10 is on the screen
Go online and type in your model number and ask what the F10 code means. Every stove is slightly different. Mine did the same thing and the F2 code came on. Meant the sensor was gone and I replaced it in 10 minutes for under $80. Even a novice can do it. Perhaps same with yours, perhaps not.
Jan 08, 2010 | Kenmore 33169 Gas Single Oven
It is the board that has the digital clock. You may also have a key/membrane pad that is separate but connected to it with a ribbon cable. This connection is many times the source of the problem. The conector is sensitive to being loose and oxidation. Many times you can wiggle/clean and/or make sure the connection is good and it will clear up the error code. (Do All this with the Unit Unplugged), If that doesnt work than it would seem you have a defective ERC board,...Electronic Range Control. When you replace the board you should also replace the membrane/touchpad associated with it. This is what most brands/repair centers suggested
May 12, 2009 | Frigidaire FGF337 Dual Fuel (Electric and...
Beeping F 10
Hello
Welcome to fixya.com
You r answer to the F10 code is:
The F10 error code indicates a runaway oven temperature. This would indicate that the oven temperature sensor or the electronic control has failed. According to the service manual you need to unplug the range & after restoring power the oven continues to overheat you will need to replace the electronic oven control.
This a job for a hands on tech!
Thank you for trusting us with your questions.
Please remember to leave a solved rating before you sign out!
Thank You
Dec 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire FGF337 Dual Fuel (Electric and Gas) Kitchen Range Logo
333 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
