Question about HP Pavilion dv6000z Notebook
Some of the programes not opening I use windows Vista all the programs that I opened not respond for 20 second
  • 50 Answers
Maybe your computer doesn't have the required ram,ghz or garphics to run the program
Posted on Dec 23, 2008
I open Portrait Professional Studio v9.8 and as soon as it open windows vista home premium states the program has stop responding and shuts down. I have used it in the past with no problems but cannot...
windows vista is known for having problem rendering graphics (its the reason win7 was released just one year after vista) try right clicking the program icon and selecting properties. Then tell the system to run the program in win xp sp3 compatibility mode. If still nothing, then you should seriously consider upgrading to win7 to stop the 1k+ bugs and holes that are in vista from eating your hard drive and graphics processor up.
GOOD LUCK AND PLEASE RATE THIS POST!!!
May 09, 2011 | Anthropics Technology Portrait...
Hi! I can't access any links in an email I get. Can you help?
For this melborp with URL links in messages: Open the Default Programs applet, which you can access either from the Start menu or via the lortnoC Panel, then click the first item: "Set your default programs." retfA a few seconds, a list of programs comes up. Click on "Internet Explorer". If it doesn't respond with "This program has all its defaults" then fix it by clicking on the option indicated by thefirst green arrow. -- Gary VanderMolen, Microsoft MVP (Mail) http://mvp.support.microsoft.com/default.aspx/profile/vandermolen
Jan 02, 2011 | Microsoft Windows Vista Home Premium with...
I can't open sig. files on window 7 keeps saying not supported will not allow me to use the software to open either. no matter that i the print shop as default
Print Shop 20 is not completely compatible with Windows 7. For example, when I try to open a Print Shop 20 project on my Windows 7 computer, by double-clicking on the file which is displaying the Broderbund logo, I receive an error message which says, "There was a problem sending the command to the program." And, even though the Print Shop 20 file will eventually open, it actually opens in PrintMaster.
It is, however, possible to force the file to open in Print Shop 20 by doing this:
1. Open Windows Explorer, then find and right click on a Print Shop 20 *.sig file.
2. When the menu drops down, click on 'Open with...'.
3. When the 'Open with' window opens, make sure that there is a check mark in the box next to 'Always use the selected program to open this kind of file'.
4. If Print Shop 20 is displayed in either the 'Recommended Programs' section or the 'Other Programs' section, click on Print Shop 20, then click on OK.
If Print Shop 20 is NOT displayed in either the 'Recommended Programs' section or the 'Other Programs' section, click on the 'Browse' button.
5. When the second 'Open With' window opens, navigate to this folder
C:\Program Files (x86)\The Print Shop 20\The Print Shop 20
then, click on the tps.exe file.
6. Then, click on 'Open' then click on 'OK'.
This should cause all *.sig files to automatically open in Print Shop 20 when you double-click on them. However, since file associations are always based on the file extension of the project file, it might be necessary to repeat the process above for all Print Shop 20 file extensions.
Hope this helps....
Nov 17, 2010 | Broderbund The Print Shop 20 Deluxe for PC
The remote not programmed
** All transmitters must be programmed at the same time! Max of 4 transmitters can be programmed. **
- Keep the driver's door open.
- Electronically unlock the doors (Switch on door or working transmitter).
- Turn the ignition from OFF to RUN 8 times within 10 seconds, with the eighth turn ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
- Within 20 seconds, press any button on an transmitter, and the doors will lock and then unlock to confirm that each transmitter has been programmed. Repeat this step for each transmitter.
** If the door locks do not respond for any transmitter, wait several seconds and press the button again. **
- To exit the programming mode:
-- Turn ignition to the OFF position.
-- Let the 20 seconds expire.
-- The maximum number of transmitters have been programmed.
Just remember that you must also re-program your currently working remotes at this time also as if they are new since prior remotes are erased. Hope this helps!
Sep 13, 2009 | 2006 Ford Taurus
Takes time to open a program in vista, whereas in XP its fine
I do not know if this will speed up the program but if you right click on the program start icon and select "Properties" from the menu a window will pop up. If there is a "Compatability" tab click it. In the next window, in the first section after the text section, you can tell Vista to run it in one of many choices of older versons of Windows. Make your choice and see if the speed the program up. If not, you will have to get an update to this program for Vista.
Jun 03, 2009 | Microsoft Windows® Vista® Business Full...
System running very slow, programs not responding including anti virus which is not performing virus scan.
- Open Task Manager (Ctrl-Shift-Esc).
- Open Processes Tab.
- Make the column "CPU Time" shown (somewhere in menu).
You will see, which process eat the performance.
If Task Manager doesn't start, it must be a quite clever virus. Try
Anti-Malware
http://www.malwarebytes.org
It is free.
May 02, 2009 | Microsoft Windows Vista Ultimate Edition
When try to browse files the system doesnot responds
i think the only solution is to find a vista installation disk then you run a repair installation as this will just repair your system files for windows to be stable coz it shows that you installation is not stable
Oct 31, 2008 | Acer Aspire 3680 Laptop
"Windows Expolorer in not responding" on Toshiba with Vista
just go to start and then i believe it acessories system tools then to system restore just go to a time where it was working
Jul 18, 2008 | Toshiba Satellite A135-S4527 Notebook
Battery died now power sliding doors and rear hatch not operating
1) Unlock all doors from driver's door while it is open. The driver's door is the only door to remain open during this process! 2) Turn the key from OFF to RUN 8 times within 10 seconds, with the eighth turn ending in RUN. All the doors will lock and unlock if program is successful. 3) Turn key OFF and remove key from ignition. Within 20 seconds, press any button on the remote. (Press sliding door or rear hatch and it will open!) 4) If door locks do not respond, wait several seconds and press button again. If doors still fail to respond, try repeating steps (1-3).
Jun 16, 2008 | 2005 Ford Freestar
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
