Question about Bosch Dishwashers
I have a nine year old aqua sensor dishwasher - it has just developed the following - it will not complete the washing cycle - just keeps going until it turn it off
    Sergeant:
    Novelist:
  • 327 Answers
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Posted on Dec 20, 2008
I have read about problems with the cycle not advancing or getting stuck on an SHU303 Bosh dishwasher. I have this problem intermittently. Usually when the dial is at the 6pm position, and lately during...
Hello Brien, First let me start by apologizing for the difficulty you've had here at FixYa. It is unfortunate the assistance (or lack of) was not helpful or specific to your inquiry, but I'd like to attempt to make amends. I am quite familiar with your model and in fact have serviced Bosch for around 15yrs. When you receive the timer (It is very rare to need one in a Bosch, more likely stat on the inside door panel) I'd be more than willing to guide you through the process and I will even send you a complimentary service manual if you provide an email address. I will understand if you have closed the door on any further input from "experts" here at FixYa but will do what I can to help if you're open. Sorry once again and good luck going forward. Regards, Macmarkus :)
May 20, 2011 | Bosch 23 in. SHU303 Built-in Dishwasher
Have a shu 4322 dishwasher it fills with water and drains but the spray arms do not spray. have not tried anything yet.this dishwasher is not hooked up. it was given to me by a friend who replaced all his...
Welcome to FixYa.
There was indeed a recall involving the control replacement nearly two years ago now if I recall.
As for checking into the present issue ( it doesn`t sound like anything to do with the control based on your description ) it sounds like the pump impeller may have become stuck. Did the dishwasher sit idle or in storage unused for a period of time ?
I have a service bulletin I could send you via email regarding remedying that issue of stuck impeller if you contact me at macmarkus@live.ca
I`d suggest you run the dishwasher through a diagnostic, but either procedure will require hooking it up.
To do this test/diagnostic on the SHU4322 series machine, it is as follows...
To start test program, press and hold both REGULAR WASH and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ "20" = version 0 without jumper).
When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone).
Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start button is pressed.
To start testing, press both the REGULAR WASH and RINSE & HOLD buttons a second time.
When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ "6" = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
2 = Heating fault
4 = Filling fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
i.e.
If water level switch has failed (opened), display will show fault code "4" and unit will continually fill and drain where testing won't be completed. If flow switch has failed (opened), display will show "0", water won't heat (to 150?F) and water won't stop circulating. If NTC probe has failed (opened), display will show fault code "8" immediately and testing will end shortly after water has started circulating.
What needs to be done to solve the problem will depend on the results/findings of the dianostic, so let me know what you find and we can go from there.
Either way keep me in the loop and I`ll assist you the best I can. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Oct 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Du1100xtpq7 has had the touch pad replaced along with the circuit board that goes behind it and yet it just keeps repeating the wash cycle and goes for hours
i would guess that you are having a problem with the optical sensor inside the pump housing. it is suppose to sense when the water is clean or dirty and allow the unit to continue washing or advance to the next cycle.
i have seen these test good but be just out of calibration enough to cause long run times.
you can try to change it yourself or have the service company try that instead of a new board and panel.
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Bosch dishwasher model: SGS56E02 will not complete a cycle.
Hi, The dishwasher must get to 70c to advance thru the heating cycle.. check to see if the heater is coming on( lots of steam coming out when you open the door )..not getting hot then you could have a heater problem. if you are getting hot then you have a Thermo ... the thermo holds the the dishwasher until the temp reaches 70c before it will let it go into the next cycle...the thermo is under the dishwasher at the right side, white with two wires .. it screws into the tub...hope it helps it not let me know and I can help you more...
Sep 27, 2009 | Bosch Dishwashers
3 year old GE dishwasher dead!
Buy a different brand of washing machine. I suggest a front loading one because they use so little water and they are cost effective and actually pay for themselves.
Jun 09, 2017 | GE Dishwashers
Smeg dishwasher
my hotpoint dish washer aquarius is 4 years old leaves a sandy grit all over dishes water not spraying the top,done all the usual stuff run out of ideas
Mar 09, 2008 | Dishwashers
Bosch dishwasher shu4322 has code 1 aqua sensor what is the sensor do and where is it located
Most of the dishwasher has a Thermal hold period in which the machine will not advance to the next cycle until the water temperature reaches a specific degree. it is possible that your aqwa sensor/or heater is bad OR as in most of the cases, the Timer relay that is responsible in turning the heater on is stuck open, in this case you need a new timer. So,Check Timer/Aqua sensor/Heater
Nov 21, 2006 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwashers Logo
50 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
