Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
How do you unlock the keypad?
The locked light remains lit on the keypad and the other options cannot be initiated. We just need to know how to unlock this options since there is no lock or key button on our machine, model #KUDD03DTSS.
thank you for your quick reply
We had this problem with ours, It is the 'control lock' that is on, a child safety 'feature' that can be turned off by holding the air dry or pro dry button for four seconds.
Posted on Jan 05, 2009
How do i fix nokia E63-1 display light automatic glow after some time?
Your set need to be casing keypad require clean-up
Dec 15, 2013 | Cell Phones
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Don't know how to set key pad lock
Before locking the keypad first remember if the keypad lock is assigned with a security code.
Default value of the security code is normally 0000.
1. To lock the keypad first press the option key, then select the LOCK KEYPAD.
2. To unlock the keypad press the option key then press the "C" button.
You can check more lock/unlock optoons in the users manual, downloadable from this link. Read page 63 and on.
http://dl-www.sonyericsson.com/cws/download/1/150/669/1192984731/J230i__UG_R1a_EN.pdf
Sep 04, 2011 | Sony Ericsson J230i Cellular Phone
I forgot my samsung cell phone keypad and now i dont know how to unlock it??
Hi Friends,
Press the menu button and * you phone keypad is open. the mention instruction how to use phone keypad lock.
  1. From the standby screen, press Menu
  2. Press Settings
  3. Press Phone
  4. Press Security
  5. From the Lock Phone section press one of the folllowing:
    • On- The phone locks immediately and stays locked until you enter the correct lock code
    • Off- The phone remains unlocked
Sep 03, 2011 | Samsung Cell Phones
I have a Lynx system with a 5828 wireless keypad that I have connected a 5v transformer to it to keep the keypad lit always. The keypad does not stay lit always and it keeps going to sleep after 10...
It sounds like your 5V transformer isn't working. It could be the outlet it is plugged into isn't working, or the outlet is on a light switch that is turned off, or there is a problem with the keypad itself. The user manual says:
"AC-Powered Operation: When powered by the
optional AC adapter, the keypad remains active at all
times. If AC power is lost, the keypad reverts to
battery-powered operation until AC power is restored
On AC powered units you can get the status by viewing
the display."
The only way I know of to keep it active is by using the transformer.
Hope this helps.
Mar 22, 2011 | Ademco 5828 Wireless Keypad Lynx / Vista...
My motorola razr phone keypad is locked how do you reset the phone
hi,Reset all options except unlock code,
security code, and lifetime timer:
Settings > Initial Setup > Master Reset
To reset all options, you need to enter the
Security Code (000000)."
cheers
May 28, 2010 | Motorola Mobility RAZR V3
I have a sears dishwasher, lock light is lit but
Press and hold the 'Heated Dry' button for 4 seconds then let go
Apr 24, 2010 | Kenmore Dishwashers
How do I lock the keypad?
You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
K530i To manually lock the keypad:
  1. From standby, press the * key.
  2. Select 'Lock keys'.
To activate automatic keylock:
  1. From standby, select 'Menu' > Settings.
  2. In the General (tab), select Security.
  3. Select Automatic keylock > On.
To unlock the keypad:
  2. Select 'Unlock'.
Mar 31, 2009 | Sony Ericsson K530i Cellular Phone
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Control Lock light remains on
Vince, press and hold the keypad next to the lock symbol. (heated dry?) see if the lock light goes out. Catriver..post back
Mar 19, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
569 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
