Question about Cozy (W352E) Heater
Where is the pilot in a gas furnace. The heater stop working
The heater stop working and I'm trying to figure out where is the pilot. I don't see a flame anywhere.
    Problem Solver:
  • 6 Answers
Most of them are at the bottom of the heater, two wing nuts hold on the sight glass to the heat exchanger.. losen one of the wing nuts and swing out the first layer of metal.. then you can see the pilot.... read your owners manual on proper ighting procedure.. should be on the unit aswell somewhere
Posted on Jan 15, 2009
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
I have a Bryant furnace model #340AAV036080ABSA and it's the auto ignite pilot, but pilot won't light. Gas is on to it, blower is working just no hot air so I figure pilot not lighting
Is the thermocouple burnt out.? A bad one of these will not allow the pilot to function . The thermocouple is the outfit that the pilot heats up when it tries to start up. A lot of the time this is the problem when the furnaces won't light up.
Nov 14, 2014 | Heating & Cooling
Old anthes gas furnace with pilot light. burners will not light.blows cold air
Have to think that the thermocouple has failed if the pilot is on but the furnace main burner doesn't ignite
Apr 05, 2014 | Cozy (W352E) Heater
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
Gas is going to cooking stove in camper. Stove lights. But can't get pilot to light for hot water heater. Don't smell gas coming to pilot area. Furnace is not turning on, but worked fine when...
Chances are good that the thermocouple is bad. It is a small probe that the pilot light keep hot. Take it out and get one at HDepot or at a RV store.
May 27, 2011 | Heating & Cooling
Cant figure out how to relite my furnace
on the bottom of the unit there is an access door remove it and behind it you will find a gas valve and a pilot find the piolot......turn off the gas valve and move the selector to piolot depress the switch and at the same time place the flame from a log lighter onto the pilot light after this lights turn the gas valve to run and the burner should light.
Mar 03, 2011 | Empire Direct Vent Wall Furnace;...
My pilot stopped working on my gas furnace. I changed the filter but that wasn't too dirty. The click goes but nothing happens.
WHEN A PILOT STOPS WORKING, A BIG PERCENTAGE OF THE TIME IT IS THE THERMOCOUPLE, WHICH TELLS THE FURNACE TO ONLY RELEASE GAS INTO THE BURNER WHEN THE PILOT LIGHT IS LIT.
I'D START WITH REPLACING THIS THERMOCOUPLE FIRST. IT IS NOT A VERY EXPENSIVE PART. ITS A SILVER COLORED CORD LEADING TO A SENSOR ABOUT THE SIZE OF A SHORT PENCIL ON THE END. THE OTHER END HAS A BRASS FITTING TO SCREW INTO THE CONTROL UNIT. THE SENSOR IS NEXT TO THE PILOT LIGHT IN THE PILOT LIGHT AREA.
Feb 20, 2011 | Heating & Cooling
Relatively new wall furnace suddenly stopped working.
if you are by passing stat at the gas valve and it is still not working,i would assume a bad control valve.
Jan 13, 2010 | Heating & Cooling
Cozy (W352E) Heater Logo
37 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
