Question about Samsung SyncMaster 173T (Black) 17" LCD Monitor
It shuts down and stays off
It shuts down all of a sudden and stays off, it doesn't respond to a move of the mouse or a key pressed to bring it back to say it shutdown for idle reasons. I have plugged into several different towers and the same result will eventually come: a black screen with no back light on, the only thing that is on is the little square green light on the lower right of the casing of the monitor. I can flip the toggle switch in the back of the monitor and it will respond by showing a dimmed picture with the analog box in the center, but usually when the analog box goes away so does the picture. I just now experiences a different shut down when the analog goes a way the screen stays by getting brighter but in 3-4 sec it will shutdown like before. Also the monitor and or computer doesn't have to be on long for this to occur; as in i just woke up this morning and turned the comp on and 30sec later the screen shutdown, while all yesterday i ran the screen fine with no problems. what is causing this? and where can i find a free schematic to try and fix?
  • Anonymous Dec 10, 2007
    My Presario monitor suddenly shut off. I have tried plugging it in different outlets and reinstalling to my desktop but the power source isn't recognized. My my computer works fine but I think I need a new monitor. Help!
  • Anonymous Mar 25, 2009
    My monitor (173T) does somrthing close. It started blacking out and then yesterday it went off and stayed off, but my old monitor still works OK.
SOURCE: Screen goes blank when I move the mouse
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of http://www.datapro.net/techinfo/dvi_info.html.
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
Posted on Mar 10, 2008
  • 24 Answers
SOURCE: Screen goes black after 2 seconds
Simplest solution may be the screen resolution settings are set higher than the monitor's capabilities. Try lowering the screen resolution and refresh rate in the display properties or try booting to safe mode (press F8 when the Windows splash screen first appears) and see if the LCD will display the windows desktop. It that works, check your video drivers and the screen resolution and refresh rate settings.
If the monitor has the problem in safe mode and/or if lowering the screen resolution and refresh rate don't help then I suspect the a problem similar to one some Dell 17inch LCDs have. On the Dells It is usually caused by a defective voltage regulator transistor in the backlight inverter circuit. Troubleshooting that problem should only be attempted if you have experience at repairing electronic circuitry since it will involve testing individual components and soldering.
Posted on Jun 15, 2008
SOURCE: Flickers on start up and very slow going to normal viewing colors and lighting
Had the same problem here !
C110 and C111 on the power supply unit are busted.
I replaced then with 2 ELCO's from 1000 picofahrad 25 V.
Voila!! runs like new.
Posted on Jan 30, 2009
  • 1684 Answers
SOURCE: My computer is on and working, but the monitor is
The power supply in the monitor is blown. We have a step by step repair guide posted on our web site at: www.ccl-la.com/badcaps.htm The guide shows you how to open the monitor and replace the defective capacitors and get back going.
Check it out. I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 21, 2009
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Posted on Oct 27, 2009
I powered my computer on but the sceen does not bring the programs
take the battery out and unplug the power cord..... now hold down the power button. put the power lead on and power up pressing the power button the screen should go fuzzy and clear up. no when the operating system comes on put the battery back in without un pluging the power cord. leave for a few minutes then restart the laptop should be fine if not repeat up to 3 times if it dont work then the mother board or the screen has failed.
Jun 19, 2013 | Office Equipment & Supplies
New Toshiba labtop. Computer went into sleeping mode How do I bring back desktop screen?
Try to move your mouse/touchpad or press any key on the keyboard. If the machine doesn't wake up, push the POWER button to wake it up.
Jun 13, 2011 | Computers & Internet
I cannot move the mouse on screen- what do I do?
Make sure there is nothing plugged into any USB ports, restart the computer (or manually shut it down by pressing the button) and turn it back on. If that doesn't fix it, try plugging in a USB wireless (or wired) mouse and see if that works.
May 21, 2011 | Computers & Internet
Optical Mouse cursor not moving in my Dell Desktop. It got stuck all of a sudden. Kindly advice the possible causes and troubleshooting if any.
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please reseat the mouse connection or try plugging it in to an alternate usb port
if still issue persists try the below steps
please restart the system and tap the F8 key on initial system logo.
in the advanced menu select the safe mode option.
login as an administrator
if the mouse works in safe mode, then perform the below
click start...in the search box type system restore
in the window that appears, restore computer to earlier date and time and click next
select a date may be a week or 2 back when system was running fine and click next
follow the onscreen steps
the system restore should reverse any changes to the system that might have caused the issue to occour.
let me know in case issue persists.
Nov 19, 2010 | Dell XPS 600 PC Desktop
Won't work after replacing batteries
sounds like the batteries might be in backwards. Please remove the batteries and then put them back in insuring that they go in correctly.
Oct 30, 2009 | Computers & Internet
All of a sudden I lost control of my mouse pad. The indicater will move around but it will not respond. I did add a wireless mouse and it still does the same Dell computer
Try restarting your computer, and while its booting up, tap f8..
then choose last known good configuration..
If that doesnt work for you, try using the keyboard to navigate to system restore..
The first step is pressing the windows key on the keyboard, and then by using the tab key and enter and the up and down arrows, navigate to
all programs, accessories, system tools, system restore..
Then perform a system restore to a time before this issue started
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
I am 56 years old computers are not my generation. just got a new computer. and am trying to close it but it would not close . what I did is close the the monitor. and then pressed the button off of the...
You have to click the Start button and choose "Shut Down " and click the mouse on that. If that does not work, try pressing Ctrl + Alt+ delete simultaneously. What they call the task manager will come up. choose Shut down and click on it. It should shut down
Nov 08, 2008 | Acer Computers & Internet
It's not working right....
The BenQ M310 mouse needs to "sync" with the USB receiver. Need to push the two buttons at the same time, or maybe the one in the mouse first then push the button in the USB receive so the two can "sync" to each other. This may solve this problem. Good luck!
Feb 16, 2008 | BenQ M310 Wireless Mini Optical Mouse
P200-RT3 Toshiba Note Book - Windows Vista
Yes, there is a way to shut down without touchpad. Look to see if you have a key on bottom left corner of keypad that looks like a little MS Windows icon (kinda like a 4-piece "crooked flag"). If you do, you are in luck. Press that key ONCE and let go and the start menu will "expand" and show you programs, settings and SHUT DOWN. Now just hit the UP arrow key (on bottom right side of keyboard) and the menu moves up one notch, to SHUT DOWN. No press ENTER and the shut down menu appears Move the arrow key again, until it says "SHUT DOWN and press ENTER again. That is it.
If you have no windows key (many laptops don't) then try pressing ALT and F keys. Sometimes this works. If it does raise the menu, then 5the instructions are the same thereafter (arrows and enter).
Another way to shut down is press CTR ALT and DEL (DELETE) together, all three keys simultaneously (but only ONE time). Then wait a second. This brings up a process window that has tabs for shut down (arrows and enter will work there too).
Now, when you restart, look for an icon in bottom right hand corner for "synaptics touch pad". or some other brand touch pad. There you can change your touchpad settings back to "tapping" for mouse clicking. You can also allow "click and drag" but I think that is dangerous, since you can accidentally "bury" files and folders.
Hit the solved/Fix Ya key on the way out. :)
Nov 11, 2007 | Compaq Presario Notebook
Samsung SyncMaster 173T (Black) 17" LCD Monitor Logo
44 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
