Getting occasional popping sound through speakers. My system consists of preamp, amp, turntable, tuner and cd player. It seems to happen when only using cd player. Hasn't happened when using only tuner or turntable.
  • Marc Wiggins
    Marc Wiggins May 11, 2010
    have you tried another cd player?
  • 24 Answers
Describe your system in greater detail. Does the preamp have a mechanical selector for the tuner/phono/CD or does it have a digital selector that you can operate with a remote? The problem might just be a dirty selector switch that need to be sprayed with Deoxit contact cleaner. It could also be bad cables so try swapping cables with the tuner.
Posted on Dec 28, 2008
I need help with volume and popping and cracking in the speakers. It's a new system and it's only plugged into my record player.
You are most likely going to need a preamp to go between your home theater and record player. The popping and hissing is usually a grounding issue. You will have to ground your system properly to get rid of this.
Dec 21, 2014 | RCA Audio Players & Recorders
What kind of pre amp do i need to operate my parasound HCA-2205A high current power amp
Any preamp should work. A preamp goes into your system between the amp and the other components which plug into it- CD player, FM tuner, Turntable.....etc. It's takes their output signal, processes it as my be Volume, bass, treble... and then send a sufficient signal to the amp to drive the amp to power your speakers. As long as the preamp output is enough for your Amps input any will work as most will be.
Nov 02, 2014 | Audio Players & Recorders
Technics sl ch570
Newer receivers that do not have a phono jack on the back require a preamp adapter between the turntable and amp to boost it before it gets amplified by the receiver.
Apr 27, 2014 | Audio Players & Recorders
I have a phono preamp hooked up to my Yamaha receiver for a turntable. My tall speaker tipped over and knicked the receiver and now my turntable will not produce any sound. Could this have blown the phon...
Let's figure out which hardware is failing. Connect the phono preamp to the CD or tuner input to see if it works there. It should. If it does, your receiver is at fault. Did the front panel controls get damaged?
How did the turntable fare in this accident? As a basic test of its ability to produce sound, hook it directly to the CD input and raise the volume slowly while playing an LP. If it's alive you'll hear a very weak, tinny sound, but I assume you know that or you wouldn't have a phono preamp in the first place and would probably be asking why the TT sounds so poor. :-)
Jan 19, 2010 | Audio Players & Recorders
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
I have been given an old JVC stereo for my son - its all separates though we wont be using the tape deck - anyway I just dont have a clue about what wire goes where and its driving me nuts!!!!!!! Is there...
You don't mention the model number, so this info is generic:
Think of it like water flowing, in one end and out the other. Each patch cord will run from the input to an output. The receiver or amplifier has inputs for the tuner, tape deck(s), turntable (sometimes high & low) and auxiliary, which could be TV or whatever other sound source you have, a cd player, e.g.
The outputs from the various sound players will go to the inputs on the receiver. The tape deck will also have an input - that's for the tape out from the receiver, which sends a signal of other sources to the tape for recording.
If there's a separate amp and preamp, the preamp output will be the amp input.
Use red on right, white on left, and be consistent.
Speaker wires should be connected in phase, i.e. make sure the striped side of the wire is always either plus or minus, but be consistent from speaker to speaker, and do the same on both ends of the connection, from amp(receiver) to speaker.
Here and here are a couple of links to helpful articles for more information.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 25, 2009 | Audio Players & Recorders
Sonance 275 no getting sound to speakers
The Sonamp 275 has Signal LEDs on the front panel, above the Volume pots. If signal is present at the RCA inputs, the Signal LEDs will be blinking.
Most likely, there isn't any line level audio signal coming from the receiver. Hook RCAs to Tape Output or MD output and check system using the Tuner which is an analog signal.
Jan 11, 2009 | Sonance SAT275 2-Channel Amplifier
No sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 16, 2008 | Audio Players & Recorders
Record player works but no sound from speakers
I've had this happen before, and it is caused by your ground wire not being hooked up. Depending on the type and age of turntable, it will have an additional wire (the ground), that needs to be hooked up to either a screw or some sort of opening similar to your speaker wire hookup. That should take care of the problem. If you don't have a ground wire coming out of your turntable, I don't know how to help, other than figure out how to ground the turntable.
Sep 29, 2007 | Audio Players & Recorders
My Emerson NR305TT will not produce sound. Turn table works, CD Player works, FM Tuner Works, everything works except no sound comes from the unit. The on switch and volume seem to work as I hear a faint...
You have one of 3 problems:1) bad solder joints in the amplifier or preamp section 2)defective output transistors/ICs in the power amp or 3)missing or incorrect voltages to the amp section. If the unit has a headphone jack plug in a headset. If you have sound then everything is OK thru the preamp section and your problem is in the power amp. Any competent repair shop should be able to solve this one easily.
Jun 19, 2006 | Emerson NR305TT CD Shelf System
140 people viewed this question
 Grubhead
Grubhead
