Question about Maytag MSD2758GEW
Coil is Freezing Up
I have a Maytag Model# MSD2758GEW Side by Side Fridge. The coil keeps freezing up. I had the repairman out who replaced several components but insisted the problem was not low freon. The problem was never fixed & now it's not in warranty. Now it only takes 24 hours to freeze up. I have to remove the cover plate and defrost with a hair dryer. What can I do. The fridge is only 3 years old and I paid 1800.00 for it.
  • 1 more comment
  • Anonymous Oct 17, 2008
    My coil freezes and I have to defrost it with a hair dryer...too frequently.
    Won't buy anothe Maytag. gte612@bellsouth.net
  • baby-popcorn Dec 16, 2008
    same problem here. fridge isnt cool at all. coils are frozen after 2 days after we defrost with a little utility heater. the repairman changed a computer board that was in the upper fridge area. but the problem is still there.
  • lneejr Dec 21, 2008
    in the freezer behind the bottom panle always freezes into a ice block. I have defrosted it before but after about a week it starts to freeze again.
I have this ame problem,refrig temp 55 and the freezer coils freezing,ordered adaptive defrost control board and the defrost heater assembly,
Posted on Jun 04, 2008
    President:
  • 878 Answers
MWKT, did the service tech replace the adaptive defrost board? By your post it sounds like a defrost problem. Check out the pic, this is the adaptive defrost board. I find that the heater and bi-metal usually don't fail on these models and the board is the culprit. Catriver..post back
Posted on Apr 01, 2007
  • carolynlarno
    carolynlarno Sep 03, 2012
    Don't see any pic.
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
Coil freezes
perhaps the drain is plugged in the freezer.
Have you checked this, please let me know what you find and we can go from there to figure this out.
May 12, 2008 | Hotpoint HSS25GFP Side by Side...
The fridge keeps freezing over
The evaporator coil is freezing, there could be a number of reasons.
a) drain line is clogged... defrost the fridge and shoot short bursts of compressed air into the drain to clear the clog
b) the defrost sensor on the evaporator coil is faulty... replace the sensor
c) the freezer is so PACKED as to impede air flow... stop stuffing your freezer
d) the defrost timer, defrost coil, etc. is faulty... replace as required
You could defrost your evaporator coil by turning off the fridge for several hours with the doors open, blow dryer, heat gun, etc... depending on skill level
Feb 27, 2014 | Refrigerators
My fridge side is not cooling,but my freezer is freezing
seems like you have a defrost issue, with this unit, its more than likely the adaptive defrost control found in the upper right hand corner of the fridge. You have to take down the lights and control....
You can find your part on any of the Parts websites for around 75.00..
IMPERITIVE unplug the fridge before replacing the board..
Aug 01, 2012 | Maytag MSD2756G Side by Side Refrigerator
MAYTAG MSD2734GE side-by-side fridge/freezer. The freezer coils on a regular basis (3-6 weeks intervals) will freeze. We will have to remove the coil covers and manually defrost them before it will...
I have written tips pertaining to each of those 2 issues
Drian blocked tip...http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
Evap. coil freezing up tip...http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
i have 2 pictures in the coil freezing up tip and they always for some reason post incorrectly so here they are..oldtech2332_43.jpgoldtech2332_44.jpg
Aug 22, 2011 | Maytag MSD2734GE Side by Side Refrigerator
Coil frozen over, freezer not freezing and fridge inefficient. msd2758gew
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. has one version..to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle. .
Nov 01, 2010 | Maytag MSD2758GEB Side by Side...
The evaportor coil in my side by side fridge keeps freezing up. I use the hair dryer to melt the frost off it. This happens about every 48 hours.
Your defrost circuit has failed. Typical problem is the heating element fails. It is mounted to your coil. Use a meter to check if the heating element is open, if they are, replacing the heating element should solve your problem.
Aug 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator is not very cold. Freezer is not
Our side by side did the same, started because the cooling coils on the bottom (although cleaned regularly), still overworked due to build up of dust and especially pet hair. The heating coil in the freezer compartment which prevents ice buildup in modern (frost-free) units kicks on full time and the compressor can't compensate, thus your perishables start to thaw. Luckily we were still under warranty. hope this helps you at least start diagnosing the problem.
Nov 24, 2009 | Maytag MSD2758GEW
My freezer coil keeps freezing up. I replaced the
In the freezer coil is a defrost heater coil, and a defrost thermostat. You have to expose the freezer coil to find them. If your local dealer can't get parts, I get mine from Repairclinic.com.
Apr 29, 2009 | Kenmore Refrigerators
Freezer keeps frosting up real fast.
Well, the defrosting system is crapped out. Check defrost timer, defrost heater, and defrost thermostat to locate faulty component. Read more about diagnosing defrost system failures.
May 10, 2006 | AEG S70408KG Bottom Freezer Refrigerator
Maytag MSD2758GEW Logo
627 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
