Question about Hoover H130E Front Load Washer
L g washer
L g front loading washer. door is locked and will not open.
  • freebigdaddy Jan 15, 2009
    had to replace latch
  • 179 Answers
Is water still in the machine. if so check the pump (the little door at the base of the machine) first use that little tube to drain the water. there is a safety feature on front load washers that does not allow the washer to open if it is full of water
Posted on Dec 20, 2008
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Front load duet washer wont start because the door cant lock and we cant open the door.
You need to replace the door lock/switch. It is quite an easy job but is a tight fit behind the front so a bit tricky to get the old one out and the new one in.
Mar 06, 2012 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Door will not close
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jul 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Can't get the door open
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Door lock light is on door is not locked and
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
The front door is locked and cannot be open.
Look for a thin clear looking line in the soap dispenser. Pull the soap dishes out and look towards the front closest to the door. It looks like fishing line but it is the door lock release. Pull it to get your door open and clothes out. Most common part needed in this situation is a new doorlock assembly (part #22003593). I hope this helped.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front Load washer won't start , door lock light on, not locked
needs new door interlock,( sits behind where the door catches on to) easy to fit normally, make sure you un unplug the washer before starting.
Sep 29, 2009 | Washing Machines
Maytag Neptune front load washer with FL code
The "FL" is indicating that the door has failed to lock or it locked but the control does not sense the door has locked.
It could be caused by:
faulty door lock solenoid
loose wire connection
faulty door lock switch
faulty door lock sense switch
bad control board
I recommend calling a service technician to diagnose and repair your washer.
but try this first just in case....unplug it for 1 minute plug back in and see if the fault code clears.
good luck.
Jan 03, 2018 | Maytag Neptune MAH5500B Front Load Washer
Washer load became imbalanced and forced door open, now cannot close door, lock stuck and washer will not run
Perhaps you have to change your lock, this is a sensitive point & will affect the smooth operation of your machine. Re. the inbalance, you hv to screw up & lock the front 2 legs (with check nut), adjust the front legs (screwed up) only to see if the machine does not move during wash/spin.
Nov 13, 2007 | GE WBVH6240F Front Load Washer
Hoover H130E Front Load Washer Logo
146 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
