Question about Panasonic DVD-C220 Multi-disc DVD Player
Player will shut down and wont turn back on.
Sometimes after unplugging the unit and plugging it back in it turned back on. I was able to do this the past few months and got it to work in between. Now I can't get it to turn on at all. When I hit the power button the lights for the disk numbers will flash real lightly but it wont turn back on. Any ideas what could be causing the problem? Also this player doens't seem to like some of the newer dvd's. It tells you that it cannot play them but if you keep changing disks and come back to that dvd they will play. Is there anyway to change settings or make the player more compatable with newer formats?
    Top Expert:
  • Panasonic Master
  • 76,016 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Apr 12, 2017
SOURCE: stuck in 'set 1'
Had this same problem and found the solution elsewhere on the net. Hold down the "1" button and the "Enter" button for aprox 10 seconds while pointing at the player. This "resets" the remote. I was skeptical when I first read this solution but it worked for me!
Posted on Jan 22, 2008
nokurajesh
  • 101 Answers
SOURCE: dmr ez25eb
clean the lense and try otherwise you have to replace the lense..
Posted on Aug 03, 2008
SOURCE: Cannot unlock ratings on my Panasonic DMR-ES20!
Apparently it is caused by power outages.
Here's the fix: Put in DVD mode.
• While the disc tray is open, press and hold [* REC] and [PLAY/x1.3] on the main unit at the same time for 5 or more seconds. Press until you see INIT on front screen of unit.
Posted on Mar 09, 2009
SOURCE: I have a Panasonic combo
Hold down the "1" and the "Enter" buttons together for about 10 seconds. This worked for me.
Posted on Mar 18, 2009
  • 586 Answers
SOURCE: Panasonic DVD-S35 Player H02 problem
    This problem is related to OPTICAL BLOCK ASSEMBLY. Two things are involved in this situation.
1- sleg motor start malfunctioning.
2- Optical Lens problem.
In both situations you have to replace the OPTICAL LENS BLOCK.
Therefore your DVD need lens replacement. And it would work fine again.
Thanks for using fixya.
Posted on May 31, 2009
Yamaha Receiver won't turn on after USB plugin in. Help!
Unit is in protect mode. Sometimes an ipod draws too much current through the usb jack and causes the unit to shut down due to an abnormal voltage being detectected. Press and hold the 'info' and 'tone control' buttons and push power. This should turn the unit on. Turn it back off and turn it on again and should power up normally. If the ipod continues to make the unit shut down when plugged in, try and make sure it is fully charged before plugging it into the receiver - this may help.
Apr 13, 2014 | Yamaha RX-V375
Started a new wash, started to fill with water then shut down. Now it sometimes turns on but shuts down after about 30 seconnds.
it sounds like there may be a problem with either the control board or the drain pump itself... is it giving you any fault codes at all... you may want to check drain pump on this unit which is located on the front side and requires removing lower panel of unit...check for any obstructions as if unit cannot drain or pump will shut down control assembly... if that looks good then the control board may be faulty unplug unit for a couple of minutes and plug back in sometimes this will reset controller.... repost if anymore questions one of us will be glad to help you out....
Jan 08, 2011 | LG WM-0532HW Front Load Washer
Air condition wont turn on
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Jul 07, 2010 | Fedders A6Y18F7BCOM Air Conditioner
Will not read disc or eject disc
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
When i unplug my tv and plug it back it wont turn on, and after many tries of plugging and unplugging sometimes it turns on
Do you have a wall switch on that receptacle , maybe , just maybe, somebody is playing games with ya ...lol...
Oct 12, 2008 | Panasonic PT-53WX54 53" Rear Projection...
I have an Omnitech OT-535BL paper shredder. It got a jam, I cleaned the paper out but it still wont work. It sounds like it is turning on when I plug it back in but it wont go.
This unit can also overheat and automatically shuts down when it does; to be thorough--simply unplug, empty the wastebasket, turn upside down, remove any remaining paper from blades, plug back in, and leave it alone for 30-60 minutes. Try again.
It's not an industrial shredder and has a low daily capacity, designed only for small office use.
May 02, 2008 | Computers & Internet
Shuts down when I put a disc in
Possible cause is the spindle motor.
Mar 20, 2008 | Panasonic DVD-S27 DVD Player
Shut off and wont trun back on
Hmm, this seems to have happened to me as well. Only, the screen is dimly lit, though black, so mine is not officially off; just not operating.
Feb 15, 2008 | SanDisk Sansa e260 MP3 Player
No sound.
Disconnect speakers one by one and reset the unit each time. If the speaker is blown, or the wires are frayed, it will shut down the internal amp. Also check the fuse in the back of the radio first, it should be near the wire harness. Power cycle the unit as well, unplug it from the power source, plug it back in. Hope this helps.
Aug 16, 2007 | Clarion M475 CD Player
Panasonic DVD-C220 Multi-disc DVD Player Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
