Question about GE Spectra JBP78 Electric Kitchen Range
Oven heat on even with all knobs turned off.
The Oven has not been used for two days. Before using the oven or surface units, the heating elements seem to be on "warm". I cut off the house breaker for the oven/stove & the heat was going away.
  • Anonymous May 23, 2009
    I have a ge electric spectra stove and when i turn on the stove it goes into self cleaning mode, locks the oven and cannot open it and it cleans until I turn off the breaker. and the oven part automatically turns on and will not go off, so i have to flip the breaker to turn it off.
  • Anonymous Mar 27, 2014
    all knobs are in off position but oven light comes on with oven heating up then cuts off
All I did was to turn "off" the Breaker, wait 2-3 minutes, then turn the Breaker back :on". It seems that cycling power did the trick. I guess the the "Brain" was out of sync.
Posted on Dec 21, 2008
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
I Have a whirlpool gold accurate system microwave /oven combo Self cleaning and broiler is not working . Regular oven works . There are no error messages . What is causing this
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
Dec 30, 2015 | Whirlpool Ovens
This morning, I went to turn the oven on to preheat. The oven light came on, but when I passed 250 degrees, it went back off. I turned the knob around to broil, the light came on again. But the oven never...
Check the breaker pannel or fuse box. The elements work on 220 volts the lights on 120 volts. If this doesn't help repost and well try again
Hope This helps
Please leave feed back
Nov 29, 2009 | Kitchen Ranges
Oven not heating properly
Hello. You have done an excellent job of explaining your problem. Read over the info. below as it sounds like your top element is not working.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
  • May 26, 2009 | Kitchen Ranges
    Oven elements just stopped working
    If I understand your use correctly, you were using the oven to heat the space? Or for baking?
    Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
    Jan 23, 2009 | Ovens
    Display is blank, no heat no bake
    The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
    Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
    GE Spectra JBP78 Electric Kitchen Range Logo
    100 people viewed this question
    Top Kitchen Ranges Experts
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Sal De
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
