Question about Kenmore 24 in. 15932 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
The dishwasher is a Kenmore Ultra Wash Quiet guard 3 (white) I started, thought it washed and completed a the cycle but when I went to get the dishes out. The dished had not been washed and the light on the panel was blinking clean. I am not sure if someone had opened it to put something in it and didn't close it all the way or what. I tried canceling it and such and nothing would work and clean light would continue to blink. I even tried shutting of the breaker for an extended period of time but the clean button still bllinks.
  • 16 more comments
  • scott adams Apr 01, 2007
    Catriver -
    Thanks for responding but on my model I dont have those options.
    I have the following cycle buttons:
    Pots/Pans - Normal Wash - Light Wash - Quick Rinse
    I have the following option buttons:
    HI Temp Wash - Heated Dry - Delay Hour
    and of course the Cancel and Start buttons
    It looks like that did it. Thanks you are da man!
  • SCHECK Nov 17, 2007
    I have only owned this Kenmore Elite Ultra Wash for 1 week and had these same issues. I googled and found this site...and after reading the solutions my blood pressure is back to normal. BUT, I used ALL the sequences that are suggested. It seemed that each sequence fixed something different for me. So, now my dishwasher is running and cleaning AGAIN! Try All of the suggested sequences. Instead of air dry I just pressed my heated dry. Now for the leaking water out of the bottom center...
    THIS SITE IS AWESOME!!!!!!!!!
  • Mary5719 Jan 03, 2008
    We have a Kenmore Ultra wash quite guard 4 and the clean light just blinks and blinks. I also tried resetting the breaker, twice, with no sucess.
    I'm hacked
  • Anonymous Jan 19, 2008
    light keeps blinking machine wont work
  • Anonymous Feb 04, 2008
    Kenmore Ultra Quiet - green "clean" light keeps blinking - if I push all the right buttons to start a new cycle, the dishwasher will not start a new cycle. Instead the clean light just keeps blinking
  • nibs2 Mar 18, 2008
    I have the same problem and it seems the same model as puppa,blinking clean light and the only button that works is the cancel/drain button but there is obviously nothing to drain-please help as I HATE to do dishes by hand! Thanx
  • shadewilson Mar 30, 2008
    I have learned the buttons that re-set it all. The only way I can get it through a whole cylce is to put it on normal wash and with no heat... Do I need a new element?
  • Jenna78 Mar 31, 2008
    Clean light keeps blinking on my kenmore quiet guard 3!!!!!!!!!!!!!!!!
  • scommfiber Sep 02, 2008
    The clean light keeps blinking and I cannot get the dishwasher to do anything.
  • rtouchstone Sep 04, 2008
    clean light keeps beeping after I turned it to light wash. I'dont think it finisihed
  • Anonymous Sep 30, 2008
    We have a Kenmore 24" built in dishwasher. We ran a load as usual, then it started blinking the green "Clean" light, and wouldn't run.
    I followed the button sequence suggested, and it works just fine.
    THANKS! to all who helped!
  • dorisryan Nov 09, 2008
    Clean light is blinking green and cannot start dishwasher. It is Kenmore Quiet Guard3
  • ectax Dec 04, 2008
    I had the same problem. The key here is after pushing the appropriate buttons (in my case, hi-temp, heated dry, several times) and all the lights come on, WAIT and let it do it's diagnostic thing. I think mine is now fixed. A repair person was going to charge me almost $400 to replace the heater, thermostat and control panel! Why doesn't the user's manual tell the consumer to try this?
  • FranciscoATL Apr 10, 2009
    Kenmore Elite quiteguard4
  • lexilulu May 11, 2010
    I kind of have same problem except a blinking washing light tried hi temp wash heated dry buttons but didn't work?
  • Fred Moraga Aug 10, 2013
    All I can say is THANK YOU!!! The high temp , heated dry
  • Anonymous Mar 16, 2014
    The clean light continually blinks when we did try to run a cycle the start button blinked 4 times and nothing happened.
Clean blinking and nothing works
The solution works 100%
HI TEMP HEATED DRY
HI TEMP HEATED DRY
for ultra-wash quietguard3 Kenmore
Love you all of you
Posted on Feb 11, 2008
  • Susy Warren
    Susy Warren Jan 03, 2014
    Worked for my Kitchen Aid KUDI02FR ... Thanks!!
    President:
  • 878 Answers
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Posted on Apr 01, 2007
  • Ron Marek
    Ron Marek Apr 01, 2007
    Puppa, then the key dance will be high temp wash-heated dry-high temp wash-heated dry. Cativer..post back
  • Ron Marek
    Right on, if it keeps happening, it could be the heater. Just make sure to run the hot water before starting the dishwasher. Catriver.
Okay, on my D/W it was Hi temp/Normal, Hi temp/Normal. I turned up the temp on my hot water tank and that worked for about 6 months or so. Then it got louder and louder and I’m back to the green blinking light. Now it fills, Goes through some of its cycles, I hear a loud popping sound, and then it drains. I think the heating element or motor is gone, Any suggestion??
Posted on Feb 07, 2008
I had the same problem: a blinking "Clean" light on a Kenmore dishwasher. Actually it would blink 7 times, then pause and repeat. Your trick to put the machine in maintenance mode worked!! The sequence I used was: Hi Temp Wash, Heated Dry; Hi Temp Wash, Heated Dry. It did as you said, cycled through and did its thing for about 4 minutes or so, then finally cleared the blinking green light. It is running now. Thanks catriver!! bsharpandc
Posted on Jun 27, 2007
    I have a Kenmor Ultra Wash Model#665.13572k700 I have
Kenmore Ultra Wash Mod 665, 1603
HI TEMP HEATED DRY
HI TEMP HEATED DRY
It works! Thanks
Posted on Nov 10, 2008
Just saved myself $200 from the advice on this problem, plus a visit from the repairman NINE DAYS LATER....THANK YOUUUUUU!!!
Posted on Sep 01, 2008
ALRIGHT!!! You all just saved me $200  THANK YOU!!!!!!!!!!!!!
Posted on Oct 12, 2007
My solution
Posted on Oct 07, 2008
THANK YOU!!!
I just surfed in looking for a solution to my blinking green light!
HI TEMP WASH+ HEATED DRY+HI TEMP WASH+ HEATED DRY= NO BLINKING GREEN LIGHT!!
Posted on Apr 30, 2008
Thanks to all of you. With your help I found the solution to the same problem for Kenmore Limited Edition: High Temp Scrub - Air Dry - High Tem Scrub - Air Dry. (This model doesn't have Heated Dry).
Posted on Sep 24, 2007
We tried this and the dishwasher starts running again, but stops before it reaches the heat-dry cycle. Initially we were told to press "normal wash - heated dry " twice....but after reading the above we tried "hi temp wash - heated dry" which seemed to have the same effect. What happens is this: all the lights go on for a few seconds, then it starts into the wash cycle but stops at the heat-dry cycle. Any ideas?
Posted on Sep 19, 2007
I did the same thing - hi temp wash, heated dry, hi temp wash, heated dry. It worked well - thanks.
Posted on Sep 03, 2007
3 Suggested Answers
  • 423 Answers
SOURCE: Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
Posted on May 04, 2009
  • 338 Answers
SOURCE: Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Posted on Nov 25, 2008
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Clean light is blinking. Services manual says:
No all you do is press
Normal-Wash, Heat Dry, Normal-Wash, Heat Dry,Normal Wash, Heat Dry, Normal Wash, Heat Dry
Then all the bottons light up
Don't press anything wait a few minutes and it will work again
I know because today we just had this problem and did this from looking it up online,
Nov 22, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Nov 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore Dishwasher displays the number "98"
I have a very similar problem. When I push a wash selection, every light on the panel shows up...and when I push Start, nothing happens. When I push cancel, it trys to drain, even tho no water is in there any more. Have you ever had an answer to your problem?
Feb 06, 2008 | Kenmore 16872 Built-in Dishwasher
Quiet guard 3 dishwaher
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Sep 23, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
2,509 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
