Question about Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Is A Dell Dimension 2400 PC Desktop CPU Fan Suppose To **** Air In Or Blow It Out?
  • JDTec
    JDTec May 11, 2010
    It suppose to take the air in to cool the CPU
  • 34 Answers
The CPU takes in the air from the front side of the PC and blows the air out to the back. It works both ways. It's just like air conditioning for a house. Air has to come in first in order to go out. Usually from front through the back. So that us users don't feel the hot air of a CPU.
Posted on Dec 21, 2008
    Genius:
  • 1,061 Answers
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Posted on Dec 20, 2008
How do I remove and replace a CPU cooling fan on my Dell Dimension 2400
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
Nov 08, 2014 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 Keeps Shutting Off
its smps problem...if u want clean ur cpu read ur dell guider ....
Jul 24, 2012 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 fan replacement
it is very easy just remove the plastic cover from the fan & lose the screw and replace the fan with the new one
Feb 27, 2012 | Dell Dimension 2400 PC Desktop
The black screw on housing that holds the CPU fan broke and the fan is dislodged. Can I get a replacement?
I would go down to the nearest 'Mom and Pop' computer shop, and see if they have a compatible screw. Take the old one with you for comparison.
[ 'Mom and Pop' computer store. The small computer shops that are doing it for pleasure, and not trying to make a 'killing'. More friendly ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 03, 2011 | Dell Dimension 2400 PC Desktop
I have had my Dell Dimension 2400 PC for several years now and the problem is I will turn it on and it only runs for like 5 minutes and then screen goes black and the power light turns orange ( turns off)
blow out dell with air compresser is u have one or can of air,,,get that at walmart,,usally dust is why,,or also pop off fan and heatsink ,thats the siver thing under fan,over the top of processer,,,clean fan,,and heatsink,,clean top of processer with rubbing alcolhol,,get a tube of thermal compound from radio shack,,,wipe a little of that over top of procesesr,,b4 u put fan and heatsink back on,,,that jus keeps it cool,,the themal compound does,,,but u can just blow out first and see what that does ,,but that will fix it,,ive had that a million times on numerous computers,,if u take all that off processer,,make sure u got it tight over top when u reinstall,,jus as it was ,,do not take processers out,,leave it where it is,,to hard not to mess up,,if never handled one,,goodluck
Nov 04, 2010 | Dell Dimension 2400 PC Desktop
HOW IS THE WIRING SET UP IN MY DELL DEMENSION 2400 DESK TOP// I AM TRYING TO PUT BACK TOGETHER THE IINSIDE OF THE TOWER NOT SURE HOW IT IS SUPPOSE TO LOOK
Most of the connections only fit in one place ...
Here is the Service Manaul for the 2400 Dimension.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/index.htm
Jun 13, 2009 | Dell Dimension 2400 PC Desktop
Screen freezes often
check the CPU fan if it is working fine
clean the dust on cpu fan
try cleaning the ram
after trying all above then also if u face the same problem try checking the power supply connectors which connect your motherboard
and the last 2 options will be your motherboard or processor
Dec 27, 2008 | Dell Dimension 2400 PC Desktop
Dell dimension 2400
Click this link:
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm
It contains the list of the beep codes for dell dimension 2400.
There is also a guide on how and what to troubleshoot. Motherboards use beep codes to indicate what error might caused the system to malfunction.
Dec 17, 2007 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
498 people viewed this question
Clive
Clive
Alun Cox
