Propane heat stove pops ..
Our 7 year old Vermont casting propane hearth has taken to popping when it goes off. The thermostat goes off ,the the flame dissapears and about 2 seconds later a "Flame Pop" occurs and at an increasingly loud rate and now pops out the pilot as well.
  • 41 Answers
SOURCE: We have a model VP1600E Propane Space Heater
Not sure I can help but will try. Sounds like you have a blockage in the pipe or jet and when it heats up it is choking. Best way to clean Propane and/or Gas heaters is to blow compressed air through the pipe. You may be able to just blow the air down the pilot light and main jet and it could fix the problem and clear the jet.
If not you will need to pull off the covers to expose the piping and look for the pipe going to the jet or pilot and if you can undo the pipe and blow compressed air through it. You may find a bit of dirt or carbon is causing the blockage. If you undo any pipes make sure you tighten them back up. Hope this solves your problem.
regards
Bryan
Posted on Mar 11, 2008
  • 148 Answers
SOURCE: pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
Posted on May 12, 2009
SOURCE: COMFORT GLOW PROPANE HEATER, THE PILOT LIGHT WILL NOT IGNITE
i vacuumed the line out, i taped the angle adapterso there was only a little bit showing and stuck it on the pilot hole for 3 minutes (I turned the gas off) and it fixed it
Posted on Jan 21, 2010
  • 77 Answers
SOURCE: dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Posted on Jan 22, 2010
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
My vermont castings radiance model 2600 lp gas heating stove starts fine then after a few minutes rear flame goes out and flames start coming out bottom of stove
Dangerous! Don't relight until you have qualified person inspect it after they actually take it apart to look for the problem.
Sounds like major gas leak or faulty gas valve. Don't take a chance on it. don-ohio
Jan 22, 2017 | Heating & Cooling
Propane blue flame heater. Why does it flare/pop when the flame shuts off.Lights well ,flame is nice and blue but when the thermostat shuts it off it pops.?
Its just a small explosion from the mixture of propane and the oxygen rite at the time it gets to the percentage of O2-ph. Its safe. An oxy/acetlene set up does the same thing when the mix is to high in O2.
Feb 07, 2015 | Blue Flame Heating & Cooling
Atwood g6a-be lights but goes out in 3-4 min.
mine is pretty new about a 1year in halve to two years old. i light with lighter it lights burns great then acts like propane cutts out then burns low then cuts out kinda acts like propane pressure cuts out in the valve but i can relight 30seconds later same thing. i have checked stove it burns great. is it in the waterheater propane valve. need help pease i need a cheap fix layed off right now. thank you dave
Sep 20, 2012 | RTO Atwood Water Heater - 6 Gal LP
Where can I get a manual for a vermont casting 1982 intrepid 1 non catalytic woodstove?
Since Vermont Castings has gone through 3 different ownerships in the past 10 years, the chances of finding the manual, for your discontinued model are slim and none. Having been a VC dealer up until 5 or 6 years ago, my data base is pretty complete. However, the Model 1982 Intrepid I Non-catalytic Wood Burning Stove doesn't even show up there. If the dealer you purchased you stove from is still in business & is still a VC Dealer, that would be the best place to start. As, his records would go back further than mine. But, I must caution you, many dealer like myself, dropped the Vermont Castings line, during the last part of it's Ownership, by Majestic Fireplace Corp. VC is now owned my Monessen Hearth Hearth Systems.
Hope this helped you some.
Jun 21, 2011 | Heating & Cooling
Find spare and repair manual for intrepid wood stove
Alex, I don't know how old your Vermont Castings Intrepid wood stove is, but the only available Owner's Manual is for their fairly new model Intrepid II wood stove.
A little quick history. Vermont Castings was an independent company 10 years ago, that was bought up by Majestic (FMC) Fireplace Company of Canada. About 5 years ago, Majestic went belly up and the VC line was purchased by Monesson Hearth Products. There have been some improvements to their wood stoves in the past couple of years, so as to meet the new EPA Requirements. So, this manual may show some things your stove doesn't have.
http://literature.mhsc.com/vermont_castings/manuals/2000966_Intrepid_II_30.pdf
Hope this helps you. Please let me know. Thanks.
Jun 02, 2011 | Heating & Cooling
Need a replacement pilot assembly for Vermont Casting radiance 2600
When Majestic Fireplace Co, who owned Vermont Castings bankrupted, Monessen Hearth Sysems purchased VC. Parts are now available from Monessen Hearth System @
.www.monessenhearth.com
Jan 28, 2011 | Stoves Heating & Cooling
Intertherm propane furnace makes popping sound when running
It sounds like you have a possible hole in the heat exchanger. Turn the heat off and turn the fan on. If you feel any air coming back out of the heat exchanger, you have a hole. A yellow flame is not a good sign. I would even consider having a service professional come out and take a look.
Apr 05, 2009 | Intertherm P3RA-048K Air Conditioner
Flame not hot
If the propane tank is full, it could be the pressure regulator. Some regulators have an adjustment screw on the top.
If it's REALLY cold outside, the propane may not be evaporating fast enough to keep the pressure up. Also on a cold or windy day, heat is drawn away from the grill very quickly, and it may be difficult to keep the temperature up inside.
(And Happy Grilling!)
Mar 31, 2008 | Vermont Casting The Extreme VCS5005BI...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
