Question about Intel D845GVSR Motherboard
My computer stopped suddenly and did not detect hard disk
After booting cpu did not detect the hard disk
I opened bios setup to set bios to detect hard disk automatically
but failed Hi i am also having the same problem. i cannot even detect my hard disk in my bios menu. but i checked thorougly my connections inside the CPU, it is all correct what can i do?
  • 1 more comment
  • killersmile Dec 28, 2008
    Hi guys I'm also experiencing the same problem.
    In my PC it states that:
    Primary Master: None
    Primary Slave:
    Secondary Master: None
    Secondary Slave: None
    Primary slave hard disk fail
    Guys can anyone help me to solve this problem. I really needed my computer.
    It's very functional before and never encountered this problem just now.
    Any response will be appreciated.
    Thank you
  • Anonymous Jan 03, 2009
    cpu didnot detect hard disk. it shown
    primary slave = none
    primary master = none
    secondary slave = none
    secondary master = none
    Pls. help me how can i solve this.
  • Anonymous Apr 29, 2009
    My CPU cannot detect the hard disk in my bios menu.
    Problem Solver:
  • 17 Answers
Restart your cmos by removing the battery on your motherboard and if that doesn't work update your bios.
Posted on Dec 20, 2008
  • 24 Answers
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
111
Posted on Mar 13, 2009
I have a w3622 and put in a new hard drive and tried to use the OS disk that came with the computer. what I get is PXE-E61: media test failure. check cable. Disk boot failure.insert system disk.
Sorry to hear about the trouble you are having. Try the following tips and lets see if we can get it up and running.
-Set the boot order in BIOS to boot from the disk drive first. In order to get to the BIOS, you will need to select BIOS option or Settings when the machine is booting up.
Most often, the above error is caused due to incorrect BIOS settings or a faulty hardware, such as hard disk. Sometimes, the error may also occur if the computer tries to boot from a device, on which it cannot find the required boot files. An improperly connected hard disk is also known to cause the same type of issue.
You should follow the below steps sequentially in order to isolate the cause and solve the issue:
  • Verify all the cable connections of the hard disk. An improper or loose connection is likely to be the reason, in case the hard disk has been recently installed or moved.
  • Check if no other storage device is connected to the computer. If it is, remove it.
  • Enter the BIOS setup when trying to start the computer and see if hard disk has been correctly setup and detected in BIOS. If the hard disk cannot be detected due to any reason, you should consider the next suggestion as it might be physical failure.
Regards,
G33k
May 09, 2011 | E-Machines eMachines Desktop PC
Will not reboot
did u by chance change any settings in the bios.... if yes please change the settings.... if u donno hw to chnge the bios settings... please ask me...
Jun 07, 2008 | Compaq Presario 5000 PC Desktop
I can't boot up. it display error 2100: Hard disk drive initialzation error.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive.
Try this:
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Boot from either your emergency repair disk, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
If the above fails:
Verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
If all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Let us know how it works out.
Jan 11, 2011 | Lenovo T410 Notebook
The COMPAQ splash screen displays, with F1-Setup and F10 system recovery option, but then displays 'DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER'. This is my sisters computer, and she says there...
You may be able to purchase a system disk from Compaq, otherwise, try any generic XP disk. It won't have any Compaq drivers, but at least you can reformat the C: drive and get XP on it.
Nov 27, 2009 | Compaq Presario S6300NX PC Desktop
After two years of use, no BIOS beep and nothing on screen.
Open cpu cabinet Reattch all connection to harddisk power cable and sata or Ide cable.
Then Pull cmos cell from motherbord chipset for 10 minutes so all bios settings are defaults.then Power up the computer press "del" or F1 or F2 to ente rin bios then check your harddisk is detected or not.
arddisk must detercted in bios for boot.
Also set first boot device as your harddisk.
then save settings and exit.
Aug 15, 2009 | Computers & Internet
Hello Everyone, I have an old PC windows98 with maxtor 90840D5 hard drive. Sometime back I've removed the hard drive and attched it to the new PC, so as to access the old files.Today when I try reattach...
you need to detect your harddisk in bios setup.
For that when you power up the computer press "del" key to enter in bios.
Then check your harddisk is detected in bios.
If not cxheck power cable and ide or sata cable connected to harddisk.
Reconect both connection to harddisk then check.
Aug 01, 2009 | Maxtor DiamondMax 3400 (90840D5) 8.4 GB...
System failure to boot
  1. Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
  2. Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
    - Floppy drive
    - CD drive
    - Hard drive
  3. Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Feb 03, 2009 | HP Compaq Presario V2000 Notebook
I shut my laptop and next time i tried to switch on, it say operating system not found
your hard disk is not detected in bios setup.
for ente rin bios press del or F2 or enter for enter in bios.
thenn check in ide configuration yoour hard disk is detected.
then go to boot option set your hard disk as first boot device there.thne save settings.
then check.
if problem occurs then reset all defauls settings of bios but first try to detect your hard disk.
Nov 27, 2008 | IBM ThinkPad T20 2647 Notebook
CPU BIOS and Config error.
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
 - Floppy drive
 - CD drive
 - Hard drive
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Oct 29, 2007 | AcerPower Sn PC Desktop
Hard drive stops booting
Hi, If your computer stops booting from the hard drive and is asking for a boot disk, then: 1. The motherboard/PC is no longer recognizing the hard disk; 1.1 Go to your CMOS/BIOS setup and manually detect the hard disk, save & exit. 2. The CMOS/BIOS is set to boot from other devices such as CD, FDD or USB but not from the HD. If after configuring the CMOS/BIOS and the hard disk is not recognized, then it is probably defective and therefore need to be replaced. If the hard disk is recognized but will not boot, then some files of your OS needed to boot are missing, corrupt or overwritten. You would need to re-install your OS and opt for a "repair". Hope this be of some help/idea. Post back how things stand or should you need additional information. good luck and kind regards.
Oct 01, 2007 | Fantom Drives EXT HD 80GB| MTT80 RTL Hard...
Intel D845GVSR Motherboard Logo
153 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
