Question about GE (PSS26MSRSS) Side by Side Refrigerator
Humming sound from GE side by side regrigerator ice-maker
Opem either door -- humming stops
seems related to ice-maker
  • 2 more comments
  • char527580 Dec 22, 2008
    My GE Model..# GSS201EPDWW
    make # GG246623
    And it has been makin a noisy for about 9 months now..and it is getting is so weird...not like the motor..or anything just a humming noisy in the back...
  • jmshepp Jan 09, 2009
    Almost constant humming/whirring sound. It has become very annoying.
    Model # GSL25JPE BS
    Wondering if this is a compressor issue or something else that has been identified.
    Thanks in advance
  • Anonymous Feb 18, 2009
    humming/whining G.E. refridge
  • Tyrone Keys May 11, 2010
    Age of unit? If you may give me the model and serial numbers I may be able to help you. Do you here this noise when the unit turns off to (Thermostat set point reached) ? Note: Try turning off the ice maker to rule this component out, if you still here the sound then it can only be coming from your evaporator fan located in the freezer compartment or the compressor. Keep me informed.
Condenser freezing up
Posted on May 10, 2009
Freezer noise when door closed
Most likely a noise from the freezer fan motor. Possibly the plastic blades are cracked or a piece broke off causing an off balance condition. They could also be rubbing some excess ice back there.
Jun 28, 2015 | Amana Refrigerators
Samsung RS261 humming noise from the freezer
sounds like the bearings of the freezer evaporator fan motor -
Nov 26, 2013 | Refrigerators
GSs 22 wg refrigerator humming noise from freezer. Tech came and replaced defroster heater element but humming remains. What is the likely cause of this? It comes and goes but is mostly on. Fridge...
most likely it's coming from the evap fan motor or the ice maker,try shutting the ice maker off first to see if that's the problem,if not then i'd go with the fan motor,you can try opening the freezer door,this usually turns the fan on,then push in the door switch button and see if the fan stops blowing and if the noise stops too.hope this helps you out.
Jun 12, 2011 | GE Refrigerators
Loud humming noise coming from freezer
I believe what is happening, is your Evap fan has some build-up of ice on it. The reason it stops when you open the door, is the Evap fan cuts off. The Evap fan starts back up when the door is closed. What you'll need to do, is open the freezer door, and remove the back panel of the freezer. This takes some 1/4 inch screws and a couple Phillips I believe. Once you get the panel off you'll be able to see if there is any ice build-up on the Evap fan. If need, be take a hair-dryer on medium or low, and melt the ice off of it. This should solve your problem.
Mar 28, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Humming noise comming from around the ice maker
If you had your water cut off to the ice maker and didn't have the ice maker turned off, it was your ice maker. You turn it off by lifting the wire arm and leaving it in the up position.
Please rate solution
Sep 10, 2009 | Frigidaire FRS26R4A Side by Side...
Side by side humming
that is related to the ice maker everything has to be functioning properly for it to make ice
Aug 29, 2008 | GE Profile PSI23NCR Side by Side...
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Humming in Whirlpool Side by Side Refrigerator
It is probably just your water inlet solenoid being activated. Not to be concerned.
Sep 26, 2007 | Refrigerators
Water Dispencer not working.
check your freezer for ice. do you have alot of ice in your ice maker tray? if so your water line could be frozen. try to self defrost the freezer for about 3hrs to thaw out the water line. check your water valve also. when you call for water do you hear a humming or buzzing noise? on ge fridges ive worked on if you hear a humming noise when calling for water, most likely your water valve is ok. trace the water. meaning where does the water start? at the wall then through a hose then to your valve which is behind fridge on bottom. trace the hoses and you will find the prob
Feb 09, 2007 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
381 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
