Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer
When the washer goes into the first drain and spin mode the inside drum appears to be off balance as it spins unevenly and sounds like it is hitting the sides. It wobbles terribly and this happens even when the dryer that sits on top has been removed. The spin is not smooth. The washer is level as that has been checked. The drum inside just seems to be unbalanced as it goes into the first major spin.Is not the cabinet itself as that stays firm, it is just the inside drum that does not spin smoothly.
    President:
  • 878 Answers
Dc, drop the front bottom panel and make sure the 4 shocks are connected to the tub and bottom panel, then check the front and rear counterweights. They may have loosened up. Remove back panel or top to check the rear counterweight. The top removes by removing the 3 screws in back and it slides off. If all this checks ok then I would suspect the rear bearing wollowing out. Catriver..post back.
Posted on Apr 02, 2007
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 28 Answers
Had a similar problem, what solved most of my problem was leveling the machine. I found the jam nuts on the feet had loosened and worked their way down letting the feet move. I also found a corrugated type hose on the right side of the machine banging on one of the side stiffeners, I insulated it and that took care of it.
Posted on Jun 17, 2009
A similar thing happened to me. I found a broken counterweight in the rear. I've temporarily removed the loose section and tightened the remaining. This works until I can get the replacement which I expect will take a few weeks (no one has them in stock)
Posted on Jan 24, 2008
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
My whirlpool Duet 9750 takes a long time to spin out and has a difficult time trying to balance
I owned a Whirlpool Duet and had spin/balance problems when I washed heavy and light items together. During a deep freeze my drain hose froze. Did everything I could think of until I ran hot water through washer. It took awhile to thaw. If your floor is weak, you will have a lot of vibration and walking. Hope this helps.
Dec 28, 2011 | Whirlpool LSW9750 Front Load Washer
Balance, washer shakes and walks across floor
Have you checked to make sure the supports are OK? Is your washer making loud noises during spinning? If so, the basket drive may be broke.
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer...after problem with it getting out of balance due to not draining and trying to spin with a heavy load, I have since noticed if I place my hand inside the tub..it will spin freely...
Your original problem is likely to have damaged the bearings and the spin tub shaft... the shocks can fail, but that would not affect the fitment of the shaft and bearings.
Apr 21, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin
These front loaders are have sensores for load balance.. If th load is uneven at the time of spin - it will not spin.. Try it with nothing in it.. If it spins - that was the issue..
Good luck ;o)
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
874 people viewed this question
Dan Webster
Dan Webster
Sal De
