Question about IBM ThinkPad T21 Notebook
Thinkpad T21 Boot Problems Problems
I recently replaced a bad fan that was causing the laptop to heat up and a LCD screen display that was no good. However, when I turned on the laptop turns on, you can see the lights go on, the LCD screen doesn't turn on but, the fan works now and after about 27 seconds the laptop beeps twice and shuts off automatically. Any ideas what that may be. Thx!!
  • 55 Answers
This is caused by a system board failure. Take the laptop apart again and check all of your connections. Also make sure the ram and processor are seated correctly. You can also try hooking up an external monitor to see if any errors display. This may be an indication that the video cable connected to the system board is not fully connected.
From IBM website:
Two short beeps - System board failure
Posted on Dec 20, 2008
IBM Thinkpad T21 will not boot, worked fine 30 minutes ago...
| | Installing this wireless adapter couldn't have fried the motherboard, right? ||I would not have thought so .. the software may have caused an issue --- as the PC boots tap F8 you should get a menu - choose "last known good configuration" ---- if that does not work, reboot and again tap F8 as it boots and this time choose safemode - then see if you can restore start>programs>accessories>system tools>system restore> choose a date to before the data you installed the wireless adapter software
Mar 20, 2010 | IBM ThinkPad T21 2647 Notebook
IBM t40 intermittent
Try to re install the operating system..
Sep 17, 2009 | IBM ThinkPad T40 2373 Notebook
How to remove the display on IBM T21 laptop
The laptop screen is secured to the laptop with screws at the hinges.
There are usually two screws per hinge. The LCD screen has one ribbon cable and possibly a power connector for the back lighting attached to the motherboard near the hinges. Disconnect these before you lift the LCD off the base, they are under the plastic panel above the function keys next to the hinges.
Feb 03, 2009 | IBM ThinkPad T21 Notebook
Thinkpad t21 screen stopped working
If the computer seems to boot up just fine, but is not displaying a picture, take a flashlight and shine it at an angle on the screen, and see if you can see a very faint image of what should be displayed. If this is the case then the backlight bulb in your LCD panel has burned out. If you do not see anything on the screen at all even under a flashlight, then this could be indicative of a larger problem.
Hook the laptop up to an external monitor to make sure that you get a proper image on there first before you proceed. (Make sure that you try to change the laptop from internal video mode to external video mode if nothing shows up immediately. I have to press the Fn + F7 buttons on my T40p to tell it to use an external video monitor) If nothing shows up on the external monitor, then odds are that something else is wrong. Start by removing sticks of memory one at a time to see if they are causing the system to not boot up. (If memory is the problem, you should hear a series of beeps on startup though). Other complete video failure causes ussually have something to do with the Motherboard, orsome subsystem of it.
If you can see video on the external monitor, then either the LCD panel has gone bad, or the video cable has come unplugged. You can check this on most thinkpads by removing the keyboard and making sure that the video ribbon cable is securely in place.
Jan 11, 2009 | IBM ThinkPad T21 Notebook
Back light on ibm t21
This is an known problem I think you must replace the backlight:
look for example ebay partnr: 260327530145
only for example if this is your problem.
PRODUCTS ITEMS
LCD CCFL BACKLIGHT LAMP IBM THINKPAD T20 T21 14.1" SCREEN
LAPTOP & MONITOR LCD SCREEN PROBLEMS
SOME COMMON SYMPTOMS FOR BACKLIGHT LAMP REPLACEMENT
- Flickering, red or pinkish hue to display and even total darkness. These symptoms are a result of a failed or ageing backlight or a failed, damaged. This is caused by the defective backlight lamp and all you need to do is replace the backlight.
DESCRIPTION
Our high brightness LCD cold cathode lamp (CCFL) with long life, it is more than 50000 hours, with Japanese new cathode, phosphor, glass, and other materials, they are perfect for all LCD backlight application and other purpose, such as instrumentation, medical devices, and all type devices.
COMPATIBLE MODELS
Suit for
Any 14.1” LCD Screen (2.0mm in diameter and 290mm Length) and (2.0mm in diameter and 292mm Length)
CUSTOMER SERVICE / CONTACT US
Email: mkproco@gmail.com (12 Hours Response Time)
Oct 14, 2008 | IBM ThinkPad T21 Notebook
IBM thinkpad T21 overheating?
Does the battery get very hot? If so try running the laptop with it removed! This problem might also caused by a faulty heat sensor on the motherboard. Given the current cost of new laptops I wouldn't spend a lot of money on any repair options, but you could invest in a "laptop cooler" or chill mat see this link
http://www.quadcooler.com/
Aug 19, 2008 | IBM ThinkPad T21 Notebook
ThinkPad T21 and S-Video Output
the lcd display screen has to be set to 1024x768 60hz refresh rate 1st to be able to send the signal to a tv.
then try the function/monitor on keyboard or boot with it connected.
Apr 13, 2008 | Lenovo ThinkPad T21 2647 Notebook
Nothing appear on the screen
Remove any devices connected and power it on by itslef, either on battery or power source, if it doesnt work, it may have bad processor, When they go bad most laptops wont boot period.
Feb 18, 2008 | IBM ThinkPad T21 Notebook
T21 Thinkpad will not boot up
you can boot it in safe mode (F8) then change the driver for the display adapter. If you give me a model and type #, I will locate these for you. Will look like 1234-UH7 on the bottom.
STP162
Nov 19, 2007 | IBM ThinkPad T21 2648 Notebook
IBM ThinkPad T21 Notebook Logo
168 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
