Question about Hitachi P42H401 42 in. Plasma HDTV
Loss of selected video input when power is turned off with remote
I have a Hitachi plasma tv model 42hdf52 and was purchased new in august of 2005. If I turn the tv off with the remote or use the tv's on/off button on the front panel and I leave the tv off for a few minutes and then turn it back on it will lose its selected input and the monitor will go to sleep. Each time i turn the tv back on I must also select the proper input to watch the only source i have connected which is a directv receiver that is never turned off.....it stays on. I do not have this problem if i only turn the tv off for a minute or two. I have the unit connected with the blue,red,green seperate video cables. Seems like there would be a default input you could select................right now it always defaults to the worst possible......the composite input!!! This sucks! I have a macro remote but it cannot be 100% effective because if the tv is only off for a minute.......the macro sends the wrong number of commands to make my tv land on the proper input!!! please help if you can
  • Pat2021 Dec 20, 2008
    Hitachi 42 inch plasma tv changes the selected video output to analog every time the tv is shut off
  • Anonymous Jan 16, 2009
    Hitachi 42pd6600l connected to skyhd box. whenever I turn it on I have to select input 6, is there no way to make it remember which input it needs?
LEAVE THE TV ON ALL THE TIME. JUST TURN ON THE CABLE AND TURN OFF THE CABLE. LEAVE THE TV ON ALL THE TIME. IT WORKS FOR ME. 4.11.10
Posted on Apr 11, 2010
  • robertl1 Dec 27, 2010
    Running the plasma tv is like running a hair dryer. Quite expensive to let run on continusiously.
Hitachi 42HDF52 powers on then shutsdown with a yellow light
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 10, 2017 | Hitachi 42HDF52 Television
My tv has sound, but no picture. When I turn it on the blue light blinks eight times and the screen is black. What is wrong?
Hi Tammy,
Please check the INPUT of your TV by pressing INPUT, SOURCE or TV/VIDEO on your TV remote. Once you press one of those ( that was on your TV remote ) you should have INPUT lists on your TV screen. All you have to do is select each one on the list until you get a picture ( normally input is TV ). Hope it helps.
May 05, 2014 | Hitachi UltraVision 55HDS69 55 in. Plasma...
Can't select inputs from remote or on tv after trying to use photo input to view pictures
memory / software issue i expect. should clear if you power off at plug leave 15 seconds and power on again
Jan 11, 2013 | Hitachi 55HDT52 Plasma Television
Lost remote for hitachi 42HDF52. Can not acess dtv for channel selections
Either go the route of seeing if available from Hitachi or GOOGLE the model number with remote after it.
You want to get an original remote---not a universal.
Mar 19, 2012 | Hitachi Televison & Video
Inputs will not change with remote with my Harmont reomte
Hello
It will be difficult to match any other universal remote with this model Hitachi set. You have to get the original remote control to select all the functions with this TV. If your original remote control doesn't work at all, just buy a new one. You can get it from the authorised service center for Hitachi at your town. OK.
Nov 04, 2011 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi TV turns on but cannot get channels.The blue light and power lite comes on. Changed batteries in remote, still no channels
sounds like a simple input problem, find the input button on the remote or the tv and change the source input until you get a picture,
May 28, 2011 | Hitachi 42 in. Plasma TV
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Jan 29, 2009 | Hitachi 42HDF52 Television
Hitachi Plasma will not remember what input to watch tv on
TURN THE TV OFF AND LEAVE OFF. TURN THE CABLE ON AND TURN THE CABLE OFF. LEAVE THE TV ON.
Dec 20, 2008 | Hitachi 42HDF52 Television
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi P42H401 42 in. Plasma HDTV Logo
219 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
