Question about RCA T13208 13 in. TV/VCR Combo
Changing the Recording speed from SP to EP on TV/VCR Combo using universal remote?
I have a Sanyo DS13TVR90 TV/VCR Combo that I need to change the recording speed. I am using a universal remote for it which works for everything else on the set. I just can't figure out how to change the speed. Help! Oh the remote is a Zenith Universal Remote Control...Maybe the model number for this is ZN311?
    President:
  • 3,130 Answers
I am sorry to have to tell you this, but the only way to change the recording speed is with an original remote. If you look on the original replacement remote link I posted here you will see the SP/EP selector, this is to change the recording speed. Good Luck. http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS13TVR90&brand_pn=FISHER_DS13TVR90&mode=large&uid=11755283300930
Posted on Apr 02, 2007
SOURCE:
I cannot find my manual what is the speed to record on the vcr for 8 hours
Unfortunately, most VCR recorders/tapes don't have an 8 hour option. It is 2 hours on SP (standard), LP for 4 hours or EP (SLP, depending on the unit) for 6 hours. (The slower recording speed usually gives poorer video quality.)
You would need a non-standard VCR cassette to get 8 hour recording. If you do have a tape that would hold 3 hours at SP, then use an EP setting to get 8 hours of recording on your VCR. I don't think I've seen any tapes that do that recording length even when VCRs were popular.
I wish that I had better news.
Jan 28, 2012 | Sansui COM311AD 13 in. Combo
I bought a tv/vcr combo from a guy no remote no manual i have a universal remote for it i am trying to run the tape in ep mode but i cant get it to change over i see the option for it in the menu i can...
sometimes a universal remote will lack certain functions like that or label them differently if possible put it on the vcr controls and try to scroll down to the ep input alot of the time it will be in between 99-01 unfortunately you may need to contact the manufacturer and see about downloading a manual for it if you would like us to please just leave the model number and make of both tv and remote and we can run a compatibility test to ensure you should be getting full function
Robb
Apr 29, 2010 | GE 13TVR62 Combo
Sony - SLV-685HF -vcr using universal remote one for all 3021 can't change recording from sp to ep so I can record more on tape. vcr says auto, or 180 in speed setting always records sp. I just want to pop...
I solved it myself by selecting guide on the remote, then the tv screen said enter plus code. ijust type in all 0's for each space given (0000000) then the setting instantly changrd to EP from SP. I pushed set on the universal remote , that was it.
It was necessary to use the power button to turn vcr off like tthe TV screen said because I was just setting the timer. You can just go to menu or whatever next.
I didn't appreciate FixYa trying to sell me a membership before even
attempting to offer a solution. They could have at least faked trying to find a solution. Instant response we would like to offer our premium services ....
Jan 18, 2010 | Sony Televison & Video
Change VCR settings from SP to LP or EP
Hi;
I have a Panasonic VCR with a different, but I know how to 'fix' your problem on my m/c. The remote for my m/c has a "REC MODE" button; operating that button changes from SP to EP etc. Check it with the "Program" button on your TV screen.
harrisonmx3
Apr 27, 2009 | Panasonic Televison & Video
Vcr recording speeds
Yes. SP is "Standard Play" and LP is "Long Play", while EP/SLP are short for Extended Play/Super Long Play respectively.
Jan 19, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Rca tv/vcr combo model T13208
Recording speed is the last item on the timer programming. SP or SLP. Some remotes have a button that will allow you to change the speed, when recording manually.
Sep 12, 2008 | RCA T13208 13 in. TV/VCR Combo
Mitsubishi U54 VCR Recording Speed
If you have a remote, there should be a button labeled "SP/EP" or "RECORDING SPEED." Otherwise, I might try looking in the VCR's main menu.
Aug 09, 2008 | Mitsubishi HS-U540 VHS VCR
Changing to ep
Hi, Try push (Menu) button on VCR Recorder to see Tape speed. Then follow instructions on TV to change speed of tape........Crazyred94
Jun 28, 2008 | Emerson EWV403 VHS VCR
Changing from sp to ep
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
May 01, 2008 | Sharp VC-A560U VHS VCR
RCA T13208 13 in. TV/VCR Combo Logo
525 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
