Question about Barska Optics Barska 10-40x50 Ir Swat Tactical Riflescope Ac10550
No battery for simmons scope model no. 1057
Can you tell me what size of battery it uses.thank you
    New Friend:
  • 4 Answers
This scope will use a 1.5 volt button battery that is 4.2 mm thick and from 11 to 16 mm wide. A thin rubber washer can be used with a V386 battery or a LR43. Both are 11.6 mm by 4.2. My scope came with a thin 16x12 mm ring made of plastic so that the battery would be held firmly into the center position.
After a close inspection, it is possible that a similar sized battery that is 3.6mm thick/thin might work also, but would have a shorter life due to less capacity.
I hope this is helpful. If not, I would be happy for you to sell me your scope for another gun of mine! :-)
carwhisperer1450@gmail.com
Posted on Sep 08, 2013
Simmons scope 3x10x44. needs size for bulter creek caps
Take the scope to your local gun store. Most will allow you to try the caps until you find the one you need. Alternately use a dial caliper to measure each end of the scope tube.
Nov 28, 2013 | MAG Optics
Simmons 3x10x44 mag, need bulter creek size
Use a caliper to measure the size of the bell you want to purchase the cover for. MidwayUsa has charts on their website. The eyepiece chart is here:
Butler Creek Flip Up Rifle Scope Cover Eyepiece Rear
Repair scope barska
Most likely a 2032. Most common battery used.
Nov 12, 2013 | Simmons Aetec Riflescopes
Does a Simmons model 533940 work on a 7mm Remington
Any scope will work on any gun. Its effectiveness requires your to match capability with need. A rimfire scope is intended for a 50 yard zero. If you expect to do most of your shooting at 50 yards, it will work fine.
Nov 09, 2013 | Simmons Protarget Rimfire Rifle Scope 3-9x...
I have a Simmons Model ATV 4515 rifle scope. other
Your scope has 5 adjustments:
1. Eye piece focus - used to focus on the reticle.
2. windage adjustment - should be on the R side of the scope, adjusts lateral impact point.
3. Vertical adjustment - the top turret. Adjusts vertical point of impact.
4. Power ring - adjusts the magnification of the scope.
5. AO ring - Parralax adjustment - used to focus the scope at specific distances. Most markings are not exact, you should set it at the range you are shooting and fine tune focus when you look through the scope.
Sep 06, 2013 | Optics
Simmons 8x32-44ao rifle scope
Is that the "Prairie Master"? I think Simmons is pretty uniform in that range of scopes--elevation adjustment should be the top dial and windage is on the side. The zoom locking ring should be in front of the eyepiece, with the zoom ring just forward of that.
You can download a generic Simmons scope manual from the Simmons site at this link: http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Mar 31, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
Have a used Simmons telescope (Model 6450) but have no manual
Simmons was purchased by Bushnell a few years ago.
Contact Bushnell at:
United States
Bushnell Corporation
9200 Cody
Overland Park, KS 66214-1734
Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
Hope this helps, Mark the Gunsmith
Dec 26, 2009 | Simmons Optics
Need a manual for a simmons rifle scope model # 1022
When you click on "customer service" on the simmonsoptics.com website, it takes you to the Bushnell customer service web page.
The number for customer service that is given is:
1-888-276-5945
The customer service rep. told me to "go to the Simmons web page".
Which, of course, takes me back to the Bushnell web page. It's a circular race track.......
In my opinion, Simmons/Bushnell has lousy customer service.
I bought a 2nd hand Simmons 3-9X50 scope (model #800479) that needed the screw on caps for the reticle adjustment screws. A small request, I thought.....one that should be easily remedied by calling Simmons/Bushnell customer support.
No dice. Customer support told me to spend $15 to send them the scope, and then they "will have to look around and find something that will fit."
Oh really??? Doesn't Simmons/Bushnell already KNOW the sizes of the parts they have?
Just send me the damn caps. They will cost Simmon/Bushnell no more than a buck apiece.
Then I asked for a user manual for said scope. No dice. The customer support lady told me to find the manual on the Simmons web page.
The Simmons web page doesn't provide user manuals online.
Their customer support needs a lot of improvement.
May 09, 2009 | MAG Simmons 22Mag Rifle Scope 4X 32...
Simmons Prohunter Model 517710 won't shoot a group
You SHOULD send it back. There is something loose inside the scope. Even the worst Simmons scope will get you to 2"-3" group. Also, when you replace it, you might want to consider their (or Nikons) shotgun scopes. They are built to with stand the power of the higher centerfire calibers and magnum shotgun shells.
Jan 23, 2009 | Master Heaters Simmons Master ProHunter...
SIMMONS 3X9X32 BLACK RIFLE SCOPE
check to make sure it hasn't turned in the scope rings. I am sure if it is somewhat new simmions will fix as long as it falls within warranty
Dec 10, 2008 | Prosport Simmons 510483 3-9x32 ProSport...
Barska Optics Barska 10-40x50 Ir Swat Tactical Riflescope Ac10550 Logo
253 people viewed this question
Top Barska Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
xalint1
xalint1
Vladimir Frolov
Are you a Barska Optics Optic Expert? Answer questions, earn points and help others
