Question about Logitech Cordless TrackMan Optical Trackball
Cursor sliding off screen
If the mouse is left unused for a few seconds the cursor removes itself to one side of the screen, sometimes then behaving like a snooker ball and bouncing back across the screen. Cleaning the ball and the optical window does not help. Order is restored only by clicking the left mouse button repeatedly, and then only for a few seconds.
  • Anonymous May 17, 2009
    Basically the same problem of the drifting cursor, but I also have a touchscreen and touchstick. They are also unable to regain control of the cursor. I'll try the uninstall driver solution. Thanks!
  • 624 Answers
I?ve had this problem in several Logitech mice. In every one of my cases the problem was resolved by uninstalling the driver and reinstalling the latest OR just using the default Windows driver. In some cases with USB mice I had to shut down the PC, remove the original mouse and replace with a standard PS2 mouse, remove and reinstall the driver and then reattach the USB mouse without rebooting. After a successful test you can shutdown the PC and remove the PS2 mouse. Let us know if that works and if you have any other questions and thanks in advance for rating this post.
Posted on Apr 01, 2007
Cannot ee startup menu
Sometimes it gets minimized to just a single row of pixels. Try moving your mouse to the center of each screen edge in turn, and seeing if the mouse changes from the standard cursor to a sort of double-arrow cursor. If so, hold it there, click and hold the left mouse button, and drag away from the edge of the screen, letting go of the mouse button when you have the start bar where you want it.
Aug 15, 2014 | Computers & Internet
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
The cursor moves randomly while I use the trackball
this problem is caused by a defective mouse, replace it.
Sep 09, 2009 | Logitech Marble Mouse Trackball
VAIO laptop cursor moves by itself
Sometimes the surface the mouse is on can make the curs or seem to have mind of its own. Does it behave this way all the time or just here and there.?
Mar 20, 2009 | Sony VAIO VGN-C140G/B Notebook
Cursor jumps around
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
Aug 14, 2008 | Computers & Internet
My cursor slides off of the screen (by itself) when I click & drag!
Seems there is something internally wrong in your mouse or you use the mouse on a very strange material base. I have heard that optical mouses can have strange behavior when used on glass tables or thick woolen carpets, a mouse pad would solve it. If that does not work and it's still under warranty, just ask for replacement or repair.
Jul 22, 2008 | Logitech Cordless Mouse
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Trouble pairing my bluetooth Macally BT micro mouse
Logitech Cordless TrackMan Optical Trackball Logo
764 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
