Question about NEC (SPPL1063) Projector Lamp for MT600, MT80
Won't keep up with power point
I'm basically trying to find drivers for this "hand-me-down" projector. I was able to get it work work with a borrowed laptop that was older (but it had the drivers for it) and I can't seem to find them [drivers] The projector is a NEC MultiSync MT600 and their website only gives me a PDF of their instruction manual. I can get the projector to work with the borrow because we could lower the refresh rate to 56hz but when my laptop ran it at 60hz it would bring up the first slide and that's it. we could change slides on the laptop and nothing would happen with the projector. I tried to lower my laptop to 56 hz but it wouldn't give me an option. Any help is appreciated!
djproaudio
  • 515 Answers
SOURCE: 60hz to 50 hz
No need to worry about that. The direct drive on these turntables will adjust for hz setting automatically.
Posted on Feb 24, 2008
vicer
  • 32 Answers
SOURCE: Problem with NEC Multisync MT830
Check to see if the fan is running on the bottom of the unit. If it senses no rpm from the fan, if will shut down to protect the unit.
Posted on Mar 16, 2008
JulesPCaut
  • 702 Answers
SOURCE: operating at a slower than recommended refresh rate
The refresh rate can be configured in Windows in the display properties. It does require that your monitor has been identified or configured, otherwise it can limit the refresh rate.
You can overrule the setting to not limit the refresh rate to compatible devices only, but be careful to not configure it too high as it can break your monitor!
Posted on May 25, 2009
Partstore
  • 34 Answers
SOURCE: Lamp and user's manual for a NEC Multisynch MT Projector
The manual can be downloaded here: http://safemanuals.com/user-guide-instructions-owner-manual/NEC/MT600
The part number for the replacement lamp is MTLAMP600/800 and it may be ordered from www.partstore.com
Posted on Jul 30, 2009
  • 109 Answers
SOURCE: Too much screen flickering @ 1024x768 (60hz)
setup your monitor driver supplied with the monitor, you will get more options. Thanks
Posted on Oct 29, 2009
When i try to run power point from toshiba satellite pro (to sony projector) I get frequency out of range. IT geek man has had it working in ffice by switching projector on first then lap top, but I cant...
are you using vga out on notebook ?
are you using vga in on projector ?
Turn on projector
hold down function key on notebook when turned on - FN button and press F5 - cycle through each mode by releasing f5 and pressing F5 again till you get CRT or CRT + LCD (while keeping FN pressed )
on data projector input source should be computer or vga
Jul 07, 2017 | Toshiba Satellite Pro L300 Notebook
Proper PC Adjustment Parameters?
Hello,Instead of replicating your laptops desktop can you please try extending the desktop. This way your laptop can keep its native resolution and so can the projector. Let me know how it goes.
Nov 17, 2011 | Sanyo Office Equipment & Supplies
Our remote went missing so I'm trying to use the other remote that came with the projector. This remote is model number RM-PJ2. Should I be able to click and move forward with the slides on Power...
Make sure the USB cable is run from the projector to the computer. You might also want to open device manager (right click my computer>properties>hardware>device manager) and make sure the projector does not have a yellow triangle with an ! on it. You can also try unhooking the USB cord, deleting the projector from device manager, then hooking the USB cord in again to reinstall the drivers. It should all be stock drivers, so you shouldn't need to download anything extra. Also be sure that the batteries in the remote are good and working. Sometimes you can point an infrared remote at a digital camera and see the light on it (I've never gotten it to work though) to verify that it's working.
Jun 16, 2011 | Sony VPL CX4 Multimedia Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
SANYO PRO xtrax MULTIVERSE PROJECTOR
Likely the projector has seem some hours on it before being sold second hand to you. A worn out metal arc lamp will wink out like this when it is at END OF LIFE. As the lamp operates, pressures build from high voltage arc current passing through the pressurized bulb. More and more voltage is required to keep the arc struck and operating as temperature rises. As the bulb ages, it requires more power to maintain the arc in the glass envelope bulb. It can rise to a point where it overruns the ability for the power supply in the projector to safely maintain the arc and it winks off, only the fan is left running. When the unit cools, the arc re-strikes and illuminates the lamp.
In short - replace the bulb, but buy TWO of them. One to fix the projector, the other as a spare on hand while awaiting another replacement bulb down the road. These metal-arc lamps typically run anywhere from 50 to 100 hours depending on power supply design and cooling ability of the projector as a whole.
May 10, 2010 | Sanyo PLC XU35 Multimedia Projector
Problem with power point
These devices get hot when they work. they need cooling. if the cooling system get dirty and fan cant turn clearly then it stops itself for protection.  it need to be cleaned.
hope it works
May 28, 2009 | Toshiba TDP-T90 Multimedia Projector
Using a Sanyo PLC WXU30 Multiverse Projector
should be able to download manual online, you cant just use a flash drive must be connected to laptop via vga cable, also I am not too sure about the mac, as i use a cheaper type laptop, but the display must be set for dual.
on windows this is done by right click, properties, advanced menu
Dec 16, 2008 | Sanyo PLC-WXU30 Projector
MY MONITOR NOt WORK WHEN I USE MY NVIDIA PCI CARD ?
Most monitors made in the last decade will put some kind of warning on the screen if they are not receiving a video signal so if you get no on-screen display at all, regardless of whether the system is on or off, you probably have a monitor failure.
Try to borrow a monitor temporarily so you can try the following:
- If the borrowed monitor also shows nothing; your card has failed. - If it does give you a normal display, go to the Control Panel, open theSystem folder, select Hardware, then Device Manager. If there is no 'X' next to the Display adaptors, expand that entry and delete the monitor shown. Then go to the Monitor entry, if there is no 'X' next to the entry, expand it and delete the monitor listing.
- Power down the system.  - Disconnect the borrowed monitor and reconnect yours.  Make sure the standby or power LED is on your monitor. - Restart the system
If Windows has simply trashed the driver, it should 'find' a 'new device' and install some kind of basic driver.
If nothing has worked; then the card is dead. If it worked with the borrowed monitor, then your monitor is dead.
BTW; if you really have had the card only 'weeks,' it will still be covered by the manufacturer's warranty; most Palit cards I saw when searching had at least a one year warranty.
Nov 24, 2008 | Palit Microsystems PalitDaytona GeForce2...
Projector lamp wil not turn on.
NEVER BEFORE OFFER ON DELL DLP PROJECTOR 2400MP
3000 Lumens Brightness, XGA Resolution, 2100:1 Contrast Ratio
Sony, Sharp, Hitachi, Toshiba, NEC, Benq, Acer, Epson All Are Above Rs 60000/-
Great Offer from Dell Pay Rs 42000/- And You Get
Two Years Warranty +
One Additional Lamp Worth Rs 15000/- +
One Projection Screen 6 by 8 with Tripod Stand worth Rs 7000/- Absolutely Free.
Limited Period Offer.
Please contact at
It gear. In
Shop no 14, Sakhai plaza,
Nr. Kothrud Tel. Exchange,
Kothrud, Pune, India. Land mark- Shree Shivaji Statue. Telephone -020-66021475, Hand Phone - 9850557001.
Contact person- Ketan
www.itgear.in
Jun 05, 2008 | Toshiba TLP 261 Multimedia Projector
PJ-TX100 Projector won´t start up out of Stand-By
Hi Mario
If there is no response on the Projector it normally means that the Mainboard is faulty.
Check if your machine is still under warranty because this quite expensive to replace.
As far as the schematics are concerned - I'm unfortunately not able to help you out with that.
Apr 02, 2008 | Hitachi PJTX100 Multimedia Projector
24 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
