Question about Cobra 29 LTD CB Radio
No antenna lite when transmitting
It seems when iam in the ohio area i don't get an antenna lite when trans mitting. i had one when i was in the tennesee area or down in that area, but when i was in the pa. area or when i got back to the ohio area, i lost the antenna lite when i transmitted. this could be just a fluke, but i want to find out how to calibrate the swr on the radio. is it something in the radio that i have to adjust, like how i calibrate it on the cal button, or is it something with the antennas. the antennas were on the truck. it is a freightliner antenna setup. i think one antenna is a fire stick and the other is a k40 with 2500 watts capibility. ican adjust the top of the k40. i am not sure about the fire stick. can you help me understand and learn to fix this problem myself? thanks for your help. steve
  • 14 Answers
Antenna light should be a warning indicator for high VSWR..... simple rule of thumb for CB antenna.... the lower the frequency "channel" the longer the antenna length, higher the frequency "channel" the shorter the antenna length. Your vehicle is a ground plane, where you mount the antenna will also affect its operation and tuning. A properly tuned antenna will have lower reflection on the midband channels and gradually rise as you near the upper and lower end of the band. Some base loaded antennas will be noticably narrow in bandwidth, if you have that problem then tune it for the channel you use most!
K40 has always been good for easy tuning and band coverage, center it on the vehicle top for good omni coverage!
PS... always make sure your connectors are secure, a loose shield will ruin your day when adjusting SWR!
Posted on Dec 22, 2008
    President:
  • 986 Answers
Freightliner uses mutiplex
Posted on Oct 18, 2009
  • 3 Answers
Both antanas should be the same (matched) read mfg instruction on how to set swr make sure ant. cable is not kinked mashed nicked or coiled up
Posted on Dec 24, 2008
Furnace won't lite
Look at the code explanation either on the inside of the door or thru a peephole in the panel. It will tell you what 5 flashes means.
don-ohio (:^)
Dec 21, 2016 | Heating & Cooling
What is the problem with my 92ford f150
I suppose you've checked the fluid level while hot and idling? Could be a bad solenoid pack. Have Ford run the codes if it's not low tranny fluid. don-ohio (:^)
Nov 27, 2016 | Ford F-150 Cars & Trucks
2008 F250super duty have a leak by the transmission for the shift lever is internal seal extra
I always try a transmission stop leak additive before I tear something down,UNLESS it can be accessed from the outside of the trans housing. You have to know how many quarts of trans fluid it has,and buy enough additive to treat that amount.FOLLOW DIRECTIONS on the bottle.
Worth a try. don-ohio (:^)
Nov 15, 2016 | Cars & Trucks
The gear selector on my 2004 town car 4.6L is very loose. It has a lot of play and its not the 2 torx screws that you tube videos show. A lot of times its real hard to shift out of park.
The shift tube can crack(gets looser and looser) or the pin break on some cars. Not a fun job to work in that area. Watch out for airbag also. Unhook battery cables and let sit several minutes before working on steering column.
May be best to take to good mechanic.
Also, you might just have a bad bushing at the trans lever area.
don-ohio (:^)
Nov 12, 2016 | 2004 Lincoln Town Car
2003 mits eclipse automatic does not shift into gear. shifter works but no engagement, no reverse, drive
Check that the shifter cable is fully moving/engaging the linkage on trans other than that check fluid and check electronic plug connection
Jan 05, 2013 | 2003 Mitsubishi Eclipse Spyder GT
Very bad am radio reception, how do i fix?
If it's interference from the high tension wires,you probably need new spark plug wires with good resistor type plugs.
Now,also a bad antenna or a poor match of frequency to the antenna from the rec eiver can cause weak reception.Anyone who knows electronics can match the antenna to the receiver. don-ohio
Sep 14, 2011 | 2005 Dodge Magnum
I have a 1999 chevy malibu 3.1 V-6 automatic trans. that I drove from new york to tennesee and about half way back I stopped to get fuel and then noticed that reverse wouldn't work and it seemed to slip...
I would change trans fluid and filter. That's a maintenance item that's most overlooked. It should be done every 50k (30k if you tow a trailer) It sounds like you've caught it early enough that your trans should be ok, but don't put it off -- "they don't fix themselves"
Jan 05, 2011 | Chevrolet Malibu Cars & Trucks
1995 mitsubishi galant will not engage in any gear but park does keep it from rolling. Would this be because of the torque converter?
You have a 7th generation mit galant. These are great cars but they have one major weakness; the auto transmision dies. Generally you have to have the trans rebuilt or many owners swap ion a manual trans. There is a great web site for owner's of the mits galant. http://www.thegalantcenter.net/ lots of great information about galants to include hwo to swap the auto trans for a manual. You want to go to http://www.thegalantcenter.net/forum.php and scroll down to 7 generation section of the forum Galants are great cars; I own 4 of them, all 7g
Feb 10, 2010 | 2002 Mitsubishi Galant
I don have sound in my laptop mode mit lyn01
Go to this page and scroll down to Sound. Download the Soundmax AD1986 driver for your OS and install it.
Note: Although the page I linked to is not your model it uses the same driver as yours...
Mar 31, 2009 | Computers & Internet
Cobra 29 LTD CB Radio Logo
449 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
