My machine worked fine yesterday, but today it wont fill , dry or anything. the lights to the delay timer, extra spin and red light under the padlock are all flashing. ive checked the filter and it wasnt blocked and i cant see anything wrong with the door. id really appreciate any advice
SOURCE: indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Posted on Sep 25, 2007
SOURCE: Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
Posted on Dec 17, 2007
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Posted on Jan 11, 2008
SOURCE: Indesit WIL143S flashing lights
hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
Posted on Jan 20, 2008
SOURCE: Whirlpool LHW0050P won't fill water or spin
I SAY REPLACE WATER INLET SOLENOID
Posted on Jan 31, 2008
Mar 24, 2017 | Washing Machines
Mar 17, 2014 | Washing Machines
Aug 12, 2011 | Washing Machines
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Nov 22, 2010 | Washing Machines
Feb 21, 2009 | Indesit WA 125 Front Load Washer
Dec 01, 2008 | Indesit W 123 Front Load Washer
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Apr 24, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Apr 19, 2018 | Candy Washing Machines
47 people viewed this question
