Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refridgerator door doesn't close good
The door on the refridge side just all at once doesn't want to close, seems like the magnets not holding. Worked fine until today.
  • 86 Answers
Hi there check that the door hasn't been pushed open too hard and stressed the hinge area,and if so try carefully tapping the hinges back.hope this helps.
Posted on Dec 23, 2008
I have a canon ir 400n series. the white plastic part tht hold the magnet for the door broke off and now the magnet will not stay in, resulting in the door not closing - and LOTS OF TAPE FOR US TO TRY TO...
here is a easy fix..... take the magnet from the other side and put it in it's place..... one side of the door really needs the magnet to hold the door closed..... Good Luck
Jul 29, 2011 | Canon imageRUNNER 400S Copier
Door wont close right on my side by side
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Aug 12, 2010 | Hotpoint Refrigerators
Door doesn't self close on Kitchenaid Superba frig
Jul 11, 2010 | KitchenAid Superba Architect KSCS25INSS...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
REFRIDG DOOR OPENS A LITTLE WHEN I CLOSE THE FREEZER
Yes I think it's the door closing cam broken and worn away.To replace, Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips. Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Aug 30, 2009 | KitchenAid KSCS25FKSS Side by Side...
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
Door not closing properly
Hi: The Kitchenaid refs. us a gravity close along with the magnets in the door seals. Magnets getting weak seals getting old and what you told me you checked can cause this. The easy fix is to raise the front of the fridge by lowering the front wheels. Pull the grill off the front and find the leveling screws (usually labeled.) Raise the front of the fridge until the doors swing shut with a gentle push. Before you replace the grill make sure the fridge dosn't rock side to side as you want it even. This is what they call leveling a fridge. Not cabinet level. Just sturdy. Hope I helped, Jeff
May 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Door keeps popping open
You don't say what kind of refrigerator you have, so this will be a generic answer. You need to replace the door closing cams, which are located at the bottom hinges.
The cams provide a sloping surface or v-shaped notch to lift the door slightly as you open it. The cam's sloping surface causes the door's own weight to hold it closed. If the cam has broken, it can fall out or turn with the door, allowing the door to come open.
The magnetic gasket is only supposed to ensure a good seal, not hold the door closed. You don't need to replace it.
Mar 15, 2009 | Refrigerators
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Kenmore Elite side-by-side (1999 model--don't have #)
Evaporator is probably overiced as a result od door not being completly closed at some time recently, turn off and defrost overnight with the doors open, turn on the next day and it should work ok within 24hrs. Regards Advisor
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
95 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
