Question about Abit AV8 Motherboard
Computer wont turn on trys to but keeps restarting itself
On the abit mother board there is a numer that appears 9.f ,i believe this is a fault ,but i cannot find it any where online
  • 679 Answers
83 - 96 - 9E (for a **** second)-9F
on the post code definition display on the mobo.
When it hits 9E it has shutdown and reads 9F when totally powered off.
I have read on other newsgroups that the power supply might be at fault
I took this from an overclocking forum, I hope it helps
Posted on Dec 20, 2008
  • George Bill
    George Bill Dec 20, 2008
    Robert I have seen this a lot when it comes to that board here is another post from a forum, it seems that board has a lot of problems from what I am seeing. Boot failure is the problem, I would try unpluging the power supply and g
    Man, did you get lucky with that ABIT motherboard!!
    I've seen Code 9F more times than I've seen a politician lie.
    I still had sporadic shut downs, ocasionally failed to reboot.
    Bought a new 22" widescreen monitor, would not work on the DVI port (was doing SolidWorks and AutoCad homework on it). Used it on VGA port for about 2 months then the system shut down - never to restart (code 9f).
    I have it another shot, but it may be gone, here is another post.
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
My sony kv-36xbr450 wont come on. When I plug it in I hera a clicking noise and once I press the power button the picture flashes to come on but doesnt and turns off by itself
the main strike relay is turning on the power board but the tube relay is detecting a fault when it trys to ingage the unit needs to be fixed by a lic pro there is no easy fix to this fault
hope this helps
Jan 03, 2011 | Sony KV-36XBR450 36" TV
Computer wont restart
try booting up in safe mode and run Disk Clean up, and run a Virus scan, and anti-spyware scan, update all system drivers. and scan for disk fragment faults
Jun 23, 2010 | Alcatel Speed Touch USB (3EC18607GA) Modem
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
I have just built my own computer tower with a abit va10 mother board,which i have just installed.The problem is i need a manaul for a ABIT VA1O A SOCKET 462 PIN MOTHER BOARD to set the board to the...
Here is a web page with direct links to download the manual for this motherboard:
http://www.abit.com.tw/page/en/download/download_manual_detail.php?pFILE_TYPE=Manual&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=VA-10&pSOCKET_TYPE=Socket%20A
Sep 02, 2009 | Abit VA-10 333MHz FSB VIA VT8378 Chipset...
Have a Abit A17 mother board that posting a 25 or 5D error code
I picked this up from an abit forum, It appears that it is quite common, look here, http://forums.hexus.net/abit-care-hexus/104674-abit-ab9-pro-code-25-error.html
Dec 21, 2008 | Abit A17 Guru Motherboard
ABIT SR-71 Mother board manual online?
i ask you bro. do you have mobo driver? because my mobo problem is driver same to you ABIT...thanks
Feb 08, 2008 | Computers & Internet
Abit AV8 Motherboard Logo
372 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Dapid Candra
Dapid Candra
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
