Question about Electrical Supplies
Spark Plug Cap is Broken
Out in the woods here and my generator has run into a small problem. Spark plug cap has has broken off (the part that wraps around the plug is attached to the plug. It still works but is not running well. As a temp. fix could I stuff some tinfoil in there to make a better connection or is that asking for trouble?
  • 211 Answers
Hi freedom
Use a pair of pliers to crimp the plug wire terminal so it fits snugly on the sparkplug.
best regards savunihai71
Posted on Dec 20, 2008
Number 1 cylinder not firing. why not?
Space bar broken?
Can only be a few things.
incorrectly gapped spark plug.
faulty or worn out plug.
broken or damaged ignition lead
worn out distributer cap
bad coil pack
Listed in likely order which is also lowest to highest cost.
First though, try this. In pitch darkness, run the vehicle, Look around the ignition and see if you see arcing sparks to the number 1 cylinder. Have seen that before with a faulty lead and with a faulty spark plug cap.
Dec 10, 2015 | Vehicle Parts & Accessories
1999 ds 80 with light or no spark at all to spark plug
Bad or broken spark plug cap or coil wire,,, check them closely
also the end of the plug needs to be removed ( Unscrewed ) in order for the cap to properly snap on to the plug,
Good luck
Dec 28, 2014 | Motorcycles
Sounds like it is only running on 2 cylinders smell petrol runs raggy
Check, your spark plugs first, and if you have a spark at them. It can be a spark plug, plug cap, coil... I once had a similar problem with a broken spring in one of the cv carb diaphragm.
Franck
Sep 09, 2014 | 2001 Triumph Legend TT
I got power to coil nothing comes out of coil
if you have power to the coil the only things that can be wrong are: -
1. the coil is duff.
2. The HT lead is broken.
3. the plug cap is duff, broken.
Remove plug cap and see if there is a spark from the wire core when the lead is placed near the engine/frame.
If it sparks OK replace the plug cap,. no spark means either the coil or the lead are duff. If you can replace the lead try testing again without the cap. Hope this helps.
Jul 31, 2014 | 2005 Yamaha V Star 1100 Classic
After changing the distributor cap rotor button plugs and wires due to a miss the car cranked up and ran 15 minutes then shut off. i now have no spark from the cap to the plug wires. any ideas?
It sounds like something is improperly installed or broken under the distributor cap. Take the cap back off and check for damaged/misaligned/broken parts or electrical connectors that are loose. If you see nothing obviously wrong, the igniter may have given up the ghost. This is part of the distributor assembly and you have to buy a complete distributor to get it. The igniter can be destroyed by improperly gapped plugs, a broken or damaged cap or rotor, etc.
Jan 16, 2011 | 1992 Honda Accord
I have a 1999 Yamaha Zuma Scooter, It starts and runs perfectly at idle but will not rev up, It was running perfectly but one day going down the road it was like someone flicked a switch and now it will...
Try a new spark plug and a new spark plug cap. The spark plug cap has a resister that can corrode or burn out causing spark issues. NGK makes an inexpensive cap for around $5. Make sure your intake manifold is not cracked, separated , or does not have a leaking gasket. Also check that you do not have a broken reed valve.
Jan 02, 2011 | Yamaha G5 Motorcycles
My 98 exployer is misfiring on all 6 cycdeers but runs fine after warmed up
Misfires across all 6 cylinders could indicate the following:
Priority Action Part Type Cause 1 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 2 Inspect Distributor Cap Loose, Burned or Cracked Distributor Cap. 3 Inspect Distributor Cap and Rotor Kit Loose, Burned or Cracked Distributor Cap and Rotor. 6 Inspect Spark Plug Fouled, Damaged, Broken, or Incorrectly Gapped Spark Plug(s). 7 Inspect Coil - Ignition Faulty Ignition Coil. 8 Inspect Condenser-Ignition Faulty Condenser-Ignition. 9 Inspect Point Set Burned, Worn or Incorrectly Set Ignition Points. 15 Inspect Timing Specification Incorrect Ignition Timing. 19 Inspect Fuel Injector Dirty or Worn Fuel Injectors. 21 Inspect Intake Manifold Gasket Leaking, Worn, or Damaged Intake Manifold Gasket. 22 Inspect Distributor Worn, Damaged or Faulty Distributor. 24 Inspect Valve Burned, Worn, or Sticking Exhaust Valves.
Nov 03, 2010 | 1998 Ford Explorer
95 chevy blazer - engine turning over but not turning. replaced cap & rotor + fuel filter.
3 things make an engine run, fuel, electrics and gearing, first thing, remove the cap and crank the engine, determine if the rotor is moving, this will eliminate a broken cam, sprockets, chain or broken teeth on the distributer. next with the ignition lights on rotate the roter button by hand in between contacts, you should hear and see small spark, replace the cap and crank engine with a plug lead off, ask a friend to see if it is sparking onto metal nearby. Next remove fuel line and crank engine to see if fuel pushes from the line. then that leaves gearing, timing must be correct, check the lead numbers are in correct firing order and timing is right. Hope this guide helps you, Good luck
Nov 19, 2009 | 1988 Acura Legend
Car spudered and die know it won't start
1 Inspect Battery Damaged or faulty battery and/or connections. 2 Inspect Coil - Ignition Damaged or faulty ignition coil or ignition coil circuit. 3 Inspect Fuel Filter Clogged or dirty fuel filter 4 Inspect Fuel Injector Pressure Regulator Faulty fuel injector pressure regulator or circuit. 5 Inspect Fuel Pump Improperly functioning fuel pump or circuits. 6 Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). 7 Inspect Control Module-Ignition Faulty ignition control module or circuit. 8 Inspect Solenoid Switch Damaged or faulty solenoid switch or solenoid switch circuit. 9 Inspect Starter Damaged, worn, defective, or faulty starter or starter related circuit. 10 Inspect Neutral Safety Switch Damaged or faulty neutral safety swittch or circuit. 11 Inspect Fuse Corroded, burned, or shorted fuse may be interupting power source. 12 Inspect Fusible Link Corroded, burned, or shorted fusible link may be interupting power source. 13 Inspect Battery Cable Corroded, broken or poorly connected battery cable. 14 Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor. 15 Inspect Distributor Cap Loose or cracked distributor cap 16 Inspect Distributor Cap And Rotor Kit Loose, cracked, or worn distributor cap and ignition rotor. 17 Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. 18 Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector. 19 Inspect Ignition Switch Worn, damaged or faulty ignition switch or circuit. 20 Inspect Spark Plug Fouled, damaged or broken spark plug(s). 21 Inspect Belt Incorrectly routed, adjusted(tensioned), missing or worn drive belt(s). 22 Inspect Timing Belt Slipped or broken timing belt. 23 Inspect Timing Set Slipped timing chain or worn timing gear(s). 24 Inspect Fuel Tank Contaminated fuel from rusted or deteriorated fuel tank. 25 Inspect Ignition Timing Incorrectly adjusted engine timing.
Dec 08, 2008 | 1995 Buick Park Avenue
94 Aerostar won't start. No fire
1 Inspect Battery Damaged or faulty battery and/or connections. here is a list of things u can check hope this helps Shaun 2 Inspect Coil - Ignition Damaged or faulty ignition coil or ignition coil circuit. grey_line.gif 3 Inspect Fuel Filter Clogged or dirty fuel filter grey_line.gif 4 Inspect Fuel Injector Pressure Regulator Faulty fuel injector pressure regulator or circuit. grey_line.gif 5 Inspect Fuel Pump Improperly functioning fuel pump or circuits. grey_line.gif 6 Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). grey_line.gif 7 Inspect Control Module-Ignition Faulty ignition control module or circuit. grey_line.gif 8 Inspect Solenoid Switch Damaged or faulty solenoid switch or solenoid switch circuit. grey_line.gif 9 Inspect Starter Damaged, worn, defective, or faulty starter or starter related circuit. grey_line.gif 10 Inspect Neutral Safety Switch Damaged or faulty neutral safety swittch or circuit. grey_line.gif 11 Inspect Fuse Corroded, burned, or shorted fuse may be interupting power source. grey_line.gif 12 Inspect Fusible Link Corroded, burned, or shorted fusible link may be interupting power source. grey_line.gif 13 Inspect Battery Cable Corroded, broken or poorly connected battery cable. grey_line.gif 14 Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor. grey_line.gif 15 Inspect Distributor Cap Loose or cracked distributor cap grey_line.gif 16 Inspect Distributor Cap And Rotor Kit Loose, cracked, or worn distributor cap and ignition rotor. grey_line.gif 17 Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. grey_line.gif 18 Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector. grey_line.gif 19 Inspect Ignition Switch Worn, damaged or faulty ignition switch or circuit. grey_line.gif 20 Inspect Spark Plug Fouled, damaged or broken spark plug(s). grey_line.gif 21 Inspect Belt Incorrectly routed, adjusted(tensioned), missing or worn drive belt(s). grey_line.gif 22 Inspect Timing Belt Slipped or broken timing belt. grey_line.gif 23 Inspect Timing Set Slipped timing chain or worn timing gear(s). grey_line.gif 24 Inspect Fuel Tank Contaminated fuel from rusted or deteriorated fuel tank. grey_line.gif 25 Inspect Ignition Timing Incorrectly adjusted engine timing. grey_line.gif
Nov 23, 2008 | 1994 Ford Aerostar Extended
Electrical Supplies Logo
52 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
