Question about Lexmark E232 Laser Printer
Doesn't recognise draw full of paper.
The original problem was that the printer would not properly pick up paper, & the jam light came on almost immediately (The paper was bent into a horseshoe, but did not pass the first roller) I found no stray paper anywhere in the system, but I gave the red lever a few flicks in case the rollers it controlled were sticking. When I go to print the test sheet now, the "Out of Paper" light comes on. The printer performs perfectly in manual feed mode.
  • Jeremy Buxton Apr 01, 2007
    I have now discovered that if I hold the red switch down with a paperclip, the printer functions properly. What should I do to effect a permanent cure?
I had exactly the same problem. It is caused by the paper feed rollers becoming shiny and failing to get a grip on the paper. The cure is easy. Disconnect the cables, remove the paper tray and turn the printer upside down. Carefully peel off the two rubber 'tyres' on the ends of the feed roller, turn them inside out, and refit them. Reassemble the printer and it should work perfectly. Obviously, you can only do this once......!
Posted on Apr 19, 2007
Clean rubber with alcohol
Posted on Apr 20, 2007
Funny noise indicating that there is a paper jam while there is nothing what to do to clear that noise.
instead of paper jam might had a miss feed which is the paper cant be picked up. which draw all draws? broken gear (s)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 14, 2015 | Konica Minolta Bizhub C652 Color Copier,...
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
Samsung CLP-300 picking up too many pages
Hi
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Samsung CLP 300 Laser Printer
Paper led light wont stop flashing
Pull the tray out and make sure the back guide is pushed against the paper. The back guide tends to move easily on these models
Jul 15, 2009 | Brother HL-2040 Laser Printer
My canon ip 2600 keeps popping up paper is jammed
hmmm...
I think the paper pick mechanism has failed..
try to add some paper to it..so the paper pick can easily pick it...
if the problem still exist ..try to full out all the paper in the tray and put it again..
May 12, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Paper tray is full and the paper light keeps flashing.
First check the machine for paper jams. If not, remove the paper from the paper tray and reinstall it. Then try to print from the MP tray.If this works, check paper size settings on the printer driver, or the small black arm which hangs down next to the paper pick up roller, and is the paper sensor.
Feb 09, 2009 | Brother HL 5040 Laser Printer
HP laserjet P2015D , JAM LED in a solid state ??
Dear gentlemen,
Hope this helps you sort out the problem. Please check paper jammed pieces of paper remains from paper in to out paper path. Check if the paper is properly picked-up, else check rubber roller pick-up and the solinoid motors that control to fed on and off the tray to engage pick-up. Check paper path sensors if possible. If you can determine when is the paper Jam happens please advice. Other means you can also refer your manual and machine diagnostic menu which part of the operation the paper will jam.
Best regards,
Rosener Guyano
Jan 10, 2008 | HP LaserJet P2015dn Printer
HP C3180 all in one printer won't realign
We've encountered several problem like this. Hope this gives an idea; I understand the cartridge will not moved back to park tray or flash ink tray back and forth because the return pick-up guide were not properly placed into each original position. It will block the ink tray moving back and forth. You can roll back the roller into the original place by removing the back cover if it has, then turn the pick-up roller slowly allowing the roller to turn and backed to its original position. Removed also remains of jammed paper pieces.
Best regards,
Rosener Guyano
Nov 29, 2007 | HP Photosmart C3180 All-In-One InkJet...
Lexmark E232 Laser Printer Logo
338 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
