Question about StarView SV211K 2-port KVM Switch
Eurovoxtx software new
Have eurovoxtx need new software as old software isn t working thankyou
  • 22 Answers
All new software, updates manuals and everything else to do with eurovox is here
Download my toolbar for free and there is eurovox tab on it that will give u access to everthing.
Posted on Sep 01, 2009
I have a three year old Kwikset series 909 Smart Code which is having software problems. Some programing functions work, others not. Can I repair this myself? Do I have to by a complete new unit? The...
Here is the link to the installation instructions:
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
There isn't a whole lot of "programming" to be done with this lock. If it isn't performing correctly, contact Kwikset 1-800-677-5625 USA & CANADA
or visit,
Sep 15, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I lost my boston acoustics ba735 software from my old computer and is there any other way that i can set them up on my new computer
The BA735 system used to come with some models of Gateway computers as part of the package. Unfortunately, they are a digital speaker and had to be used with the sound card provided so they would work. They won't work with the analog output that most computers provide. No special driver software is necessary, but you need a digital output from the computer.
Depending on the sound circuitry of the new computer, digital output may be available. Some higher-end systems with integrated sound may offer it, and it's often available on expansion audio boards that you can install in desktop systems. Check the audio settings menu in your system to see if digital output is provided.
These speakers sounded pretty good. Several times when people who had these systems upgraded, I installed the sound card from their old Gateways into the new computer so they could keep using the speakers. That doesn't work with the latest versions of Windows, though, because the hardware isn't compatible. But if you can find a digital audio source they'll still work for you.
Jun 29, 2011 | Computers & Internet
Guitar will not play through amp the amp is working
This could be caused by multiple different things. The most common one is that your input cable is broken. The input cable which you are using is old or has been stored in a way that may have damaged the wiring inside. This would cause a weaker signal or none at all and could stop working. What I'd suggest is to find a friends input cable or test a different one out at a music store through an amp to find out if it is (or isn't) the cable. If it was the cable, then buy a new cable and toss the old one. If it isn't the cable that stopped working you may be forced to open up the back and re-install the wiring and the jack-in. In most cases, it would be advised for you to take the guitar to a guitar tech in your area and pay for them to fix it because it's a very long process where experience is needed in soldering circuits in order to avoid hurting the guitar. Other-wise, if you decided to fix it yourself you will need a soldering gun, flux, new electronics (depending on what isn't working. It could be the pickups, the jack-in, old wiring inside, etc.) and a lot of spare time. You will be forced to solder the connection between the pickups, the knobs that control bass/treble/mid/volume (etc.) and the new electronics. In order to do this, you must first heat up the circuit, then melt the flux and connect the new circuit quickly to flux before it oxidizes (to be simplified).
Jun 18, 2011 | Audio Players & Recorders
I transfered my magic jack from my old computer to my new one and it doesn't
which is the new operating system
if it is windows 7 then try the compatbility mode and also check whether they have any upgraded software for your operating system
Apr 06, 2011 | Computers & Internet
1987 jeep yj 6 cyl manual trans. New fly wheel, clutch, presure plate, and batt. Starter is one month old on old worn flywheel with bad ring gear. Inspected starter gear before reinstalled on the new fly...
check to make sure the starter is seated correctly to the bell housing also check for a cracked! nose cone on the starter as well and make sure the front nose casting bushing isn;t worn out and make sure they sold you the correct tooth count flywheel
Jan 19, 2010 | 1987 Jeep Wrangler
There is no new s.w. at this time for tx box, you will have to manally input keys until new s.w. is released.
Dec 20, 2008 | StarView SV211K 2-port KVM...
Lost download disc
I couldn't find any software that could make your mp4 works, but if you have windows XP you don't need to have a Cd.
The computer by itself recognize it.
Also if you have the cable just plug it in the new computer and he will recognize it if it is windows XP. but if you have Windows Vista you will have to buy the Disc.
I hope my answer helped you .. Thank you
Jan 29, 2008 | Sears TGE MP3 Player
Not finding what you are looking for? StarView SV211K 2-port KVM Switch Logo
Alun Cox
