Question about Plumbing
Drain pop-up funnction not working
I have a new grohe 20.069 atrio wideset faucet. the pop-up drain isn't going up and down. the pop up extension down into the drain slips past the rod that pushes the pop-up whenever the rod goes down. there seems to be a gap down there?
    Problem Solver:
  • 5 Answers
The stopper portion of the drain should have an adjustable threaded leg with a small nut to secure the setting after you have adjusted its lenght to open and close the drain. Make sure you adjust the lenght to the highest setting for better drainage. The linkage must be connected and tight between the vertical lift rod and the horizontal rod that enters the drain to make the stopper move up and down.
Posted on Dec 20, 2008
Grohe concetto faucet, 34270, leaking at lever handle when moving lever up and down.
It's a complete cartridge that you need to replace. Contact Grohe and they should send you out a new cart. under their limited lifetime warranty
Feb 16, 2015 | Grohe 3427 Concetto Single Hole Bathroom...
Grohe bidet arden faucets
Look under the sink you will see the linkage you a un screw the rod from the trap and slide the rod out and remove the pop up drain . Also take off the trap on the bottom just unscrews that could be blocked . Put a bucket under it as there will be water in it that will smell .
Dec 26, 2017 | Plumbing
Grohe ladylux cafe kitchen faucet: new item, the pull out spray piece does not set firmly into neck so that it falls out easily
check and see if the weight is on the hose going to the handle, also check to see if the hose is free to fall down and that it is not hanging up on piping down under the sink
Best of Luck
Richard
Sep 06, 2011 | Grohe Plumbing
Hi wondering how to clean my grohe atrio faucet it has been flowing very very slowly
the tip of the faucet has a removable tip with a filter on it remove and clean it. should unthread by hand.
Jan 06, 2010 | Grohe Atrio High Spout Lav. Wideset ...
Is their a way to tighten the spout on a Grohe Atrio kitchen/bar faucet? It seems a little loose, but is not leaking
try to tighten collar at base of spout if that dosent work o-ring could be bad
Aug 20, 2009 | Plumbing
Grohe pull out kitchen faucet the inner tube ripped
go to the store you bought it and see if they carry parts. if not , try the internet under grohe.com.
Jun 11, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe Atrio Bath Shower Mixer Flow Problem
Check for a flow restrictor in the showerhead, also a clogged intake screen or filter in the showerhead. or hose or pipe...
Nov 25, 2008 | Plumbing
Plumbing Logo
593 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
