Computers & Internet Logo
Posted on Dec 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to delete antiviruse 2009 from my computer
Anonymous
Level 2:
  • Expert 53 Answers
  • Posted on Mar 31, 2009
Anonymous
Expert
Level 2:
Answers
53
Questions
0
Helped
13737
Points
124
You should be able to do this by going to "Start", then select "Control Panel", then select "Add or remove..". A list of the programs on you computer will appear. Just go down that list until you find out the antiviruse 2009 and than clack the remove option... i hope u got it..
Anonymous
Level 2:
Sergeant:
  • Expert 324 Answers
  • Posted on Dec 20, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
324
Questions
Helped
202625
Points
697
You should be able to do this by going to "Start", then select "Control Panel", then select "Add or remove..". A list of the programs on you computer will appear. Just go down that list until you find the one that you want to remove and select it!
Hope this heps.
Ron
Anonymous
Level 2:
  • Expert 55 Answers
Anonymous
Expert
Level 2:
Answers
55
Questions
0
Helped
29523
Points
123
Try using spybot search and destroy by safer-networking. http://www.safer-networking.org/index2.html This will normally eliminate any spyware you have accidentally installed on your computer. Also try installing AVG antivirus is you are looking for a free anti virus program. http://free.avg.com/
Im using kaspersky antivirus 2009 and need help
Disable Kaspersky Antivirus & use a data recovery program to recover the photos. One of the best freeware data recovery program is Restoration.
You can download it at the following link: http://www.snapfiles.com/get/restoration.html
6helpful
4answers
I have the 2009 antivirus virus which causes problems connecting to the internet
There is 2 option for you.
1 is download malwarebytes. just use the free version.
http://www.malwarebytes.org/mbam.php
2 is manually removing it. Dont try unless you know what regedit is
  1. Press Ctrl + Alt + Del then find and End the following processes:
    • av2009.exe
    • AV2009Install.exe
    • Antivirus2009.exe
  2. Delete the following files from your PC:
    • %UserProfile%DesktopAntivirus 2009.lnk
    • %UserProfile%Application DataMicrosoftInternet ExplorerQuick LaunchAntivirus 2009.lnk
    • %UserProfile%Local SettingsTemporary Internet FilesContent.IE5S96PZM7Vwinsrc[1].dll
    • %UserProfile%Start MenuAntivirus 2009
    • %UserProfile%Start MenuAntivirus 2009Antivirus 2009.lnk
    • %UserProfile%Start MenuAntivirus 2009Uninstall Antivirus 2009.lnk
    • c:Program FilesAntivirus 2009
    • c:Program FilesAntivirus 2009av2009.exe
    • c:WINDOWSsystem32ieupdates.exe
    • c:WINDOWSsystem32scui.cpl
    • c:WINDOWSsystem32winsrc.dll
  3. Click Start > Run, type regedit, Find and delete the following registry entries:
    • HKEY_CURRENT_USERSoftware
      75319611769193918898704537500611
    • HKEY_CLASSES_ROOTCLSID
      {037C7B8A-151A-49E6-BAED-CC05FCB50328}
    • HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows
      CurrentVersionExplorerBrowser Helper Objects
    • HKEY_CURRENT_USERSoftwareMicrosoftWindows
      CurrentVersionRun "75319611769193918898704537500611"
      CurrentVersionRun "ieupdate"
1helpful
Installed Norton 2009, now only boots BSoD 0x00000024
1 delete norton from your hard
2 run tune up utilities 2008 and execute the registry cleaner
3 open the registry and search anything which have relation with norton for exp : norton 2009 enter
delete the left keys and search them by pressing f3 then delete
reboot the computer instal the antivirus and everything will be allright
rate this if its helpful ;)
5helpful
7answers
Want to delete ms antispyware 2009
Can you try to delete in "Control panel" "Add and Remove Program" .
2answers
Trying to remove Internet Security to install Norton AntiVirus
Click on Start button
Click on Control panel
Double Click on Add and Remove program
Look for Norton Internet Security and Uninstall it.
Checking on regisrty
Clcik on Start
Click on run
type regedit
Double click on HKEY_LOCAL_MACHINE
Double Click on software
Look for Symantec Folder then delete that folder
Restart your computer.
Try installing your new program.
4answers
Antivirus 2009
I see these every day, note: also fixes AV 2008 and many others.
This Malware is known as "Rogue anti-virus" software.
This program will remove it: http://www.majorgeeks.com/downloadget.php?id=5360&file=10&evp=2e0d43eb67e1e71c0b31e62c003599c0
the website that has it also has a really good antispyware program called malwarebytes
once you run a full scan in this program run this program:
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE
it's another free antispyware. these are both professional grade removal software for free. I remove this stuff about 3 times a day. It seems this outbreak is the largest I've ever seen.
If you want a good protection suite that will keep it out buy a copy of NOD32 (www.nod32-av.com) another you may not have heard of, it will block this and many others before it even gets on your computer.
Antivirus 2009 HELP!
The following process will help you remove Antivirus 2009 from your system easily and safely.
Antivirus 2009 Manual Removal Process:
1. Click on the Start Menu button, then click on the Control Panel option, and then Double-click on the Add or Remove Programs icon.
2. Locate Antivirus 2009 and double-click on it to uninstall Antivirus 2009. Follow the screen step-by-step screen instructions to complete uninstallation of Antivirus 2009. Do not worry about this if you cannot find it in Add/Remove window. Simply skip to #5.
3. Restart the computer.
4. When it has completed uninstalling you can close Add or Remove Programs and your Control Panel.
5. Close all programs.
6. Search and delete the following infected entries in registry. If you do not know how to edit registry, click here to read more.
HKEY_LOCAL_MACHINE\SOFTWARE\Antivirus
HKEY_CURRENT_USER\Software\Antivirus
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\
“Antivirus” = “%ProgramFiles%\Antivirus 2009\Antvrs.exe”
7. Stop Antivirus 2009 process. If you do not know how to stop a running process, click here to read more.
8. Find and delete the following infected files from your system. Don’t worry if you don’t find these files. Just proceed to next step.
shlwapi.dll
wininet.dll
Antivirus 2009.lnk
av2009.exe
Antivirus2009.exe
If you do not know how to find it or having difficulties locating the file, click here to read more.
9. Rename the files that you found above to “foundbadfile1.dll” and “foundbadfile2.dll” (if you can not rename this file, then try to restart your computer in safe mode then try to rename this file.) If you don’t know how to start the computer in safe mode, click here to read more.
10. Go to C:\Program Files\ folder and delete the “Antivirus 2009′ folder (if you can’t delete it, reboot your computer to safe mode then delete the folder. Do not worry about it if you can’t find this folder.)
11. Click here to bookmark this page (you will need to comeback to this page after reboot)
(If you are using Firefox click on Ctrl+D on your keyboard to bookmark this page)
12. Restart your computer
13. Go to your computer and delete the “foundbadfile1.dll” and “foundbadfile2.dll” file
14. You have just removed Antivirus 2009 from your computer manually.
Remove Antivirus 2009 with SmitfraudFix:
SmitfraudFix is a free tool that S!Ri created to remove fake anti-spyware programs. It can be risky so we cannot guarantee the result. Please use it with reservations. We would never recommend to purchase anything unless it’s necessary. That’s why we produce this free removal process.
1. Download SmitfraudFix tool and save it to your desktop.
2. Restart your computer and boot into Safe Mode. If you don’t know how to start the computer in safe mode, click here to read more.
3. Double-click on the SmitfraudFix.exe icon then follow the screen instructions. Option #2 should be selected in this case.
4. When you are prompted with “Do you want to clean the registry ?”, simply answer “Y”.
5. Reboot.
6. You should have removed Antivirus 2009 from your computer. Sometimes it might take more than once to work properly. If SmitfraudFix removal tool does not work, which is in no-guarantee due to the nature of spyware, please refer to the manual removal steps above or purchase a legitimate removal tool if necessary.
Antivirus 2009 has overwhelmed Google; cannot get into internet and no systems remove. Need to get rid of immediately. Help!!!
shlwapi.dll
wininet.dll
Antivirus 2009.lnk
av2009.exe
Antivirus2009.exe
5. Reboot.
2answers
Antivirus 2009 is overpowering Google; cannot get into internet. HELP!!!
shlwapi.dll
wininet.dll
Antivirus 2009.lnk
av2009.exe
Antivirus2009.exe
5. Reboot.
Grand Canyon Tech
Grand Canyon Tech
