Question about Dacor EHD3618SS Kitchen Hood
How do you change the dacor hod fan light balbs
  • berry_patch1 Jan 22, 2009
    how do I change the light bulb in the dacor mhd3609s vent hood? I' ve tried everything, but I am afraid to pull on the rings that are around the halogen bulbs. any ideas?
  • 528 Answers
Using your finger nail or a small flat-head screwdriver, gently depress lens retainer tabs. and take the balbs out...
Posted on Jan 23, 2010
  • 911 SERVICE TODAY
    911 SERVICE TODAY Jan 23, 2010
    or Remove Filter. Reach inside hood and depress light socket retaining tabs.
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: how do you take out light ballbs from dacor hod fan
To replace the light bulb:
1. Remove the right filter and turn off the main power
switch.
2. Gently push the suction cup on the light replacement
tool A (provided with you range hood)
onto the lens of the light bulb B .
3. Turn the tool counter-clockwise until the bulb
comes loose.
4. Remove the tool from the bulb and put it on the
lens of the replacement bulb.
5. Screw the new bulb into the light fixture clockwise
until it is tight. Turn on power at the fuse or junction
box. Turn on the main power switch and touch
the light key to make sure it is working.
6. Replace the filter.
You can download the manual here.
Good Luck And please Rate FixYa!
Posted on Dec 20, 2008
My 2009 taillight won't come on but my brake lights is working ok
hi.check balb can be blown it can have a double contact balb in that has two lights in it one can be blown
Jan 17, 2016 | Cars & Trucks
Rookie mistake... Resetting Dacor? Or replacing fuse?
when you turned the light cover you turned the whole socket and the power connection shorted and blew relay board
you need relay board and light socket
Jun 24, 2017 | Dacor Preference RSE30 Electric Kitchen...
My DACOR + ECS 130 covection oven light relay keeps clicking.....
I have the same problem and sent an e-mail to DACOR. A James Carlos responded and advised that DACOR could not provide DYI info because of liability problems, pure BS in my opinion. I've had problems with a DACOR microwave (manuf. by Sharp), my DACOR wall oven Model ECS103 and my DACOR Raised Vent system and told Mr. Carlos so. I don't know how to fix the blinking oven light other than cutting power at the circuit breaker panel or removing the two light bulbs which other have advised but suspect a new front control panel is required. If you find a fix, please advise me at bsquared37@yahoo.com. I think DACOR products are overpriced and junk.
Thanks, Bill 12/10/2009
Aug 27, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dashboard lights wont come on
you could have fried a wire take a es ligh and pull the dash apart and test were the balbs go in oher wise check check the balbs they could have went out
Apr 17, 2009 | 2000 Hyundai Accent
How do you take out light ballbs from dacor hod fan
switch.
comes loose.
Dec 19, 2008 | Dacor EHD3618SS Kitchen Hood
TV LED lights in front are blinking at the same time and picture is out. Cannot turn off. The booklet says to check the fan, but with no directions on where the fan is.
The fan is on the inside of the tv chasis on the back inside the small door located on the right when looking at the tv on the front.
Apr 26, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Dacor ECD230 Sabbath Mode
You don't need to do anything special.
Quoting from Daco.com FAQ
"In our ovens, the cooling and convection fans do not turn off when the oven door opens. The lights also do not turn on. There is no timed shutoff on our ovens, either, meaning that once they are turned on, they will stay on until you manually turn them off. Both of these would be considered violations. Our ovens do not have a special Sabbath button because our ovens already adhere to the laws. When the oven door is opened, there are no changes to the control panel, which would also be a violation. It is best to wait for the small "On" light with the circle around it to go on before opening the oven door, though. This light indicates that the element has gone on, as the oven cycles on and off to maintain the selected temperature. Opening the oven door without this light going on may trigger the element to go on, which can be a violation."
Mar 25, 2008 | Dacor ECD230 Epicure Stainless Steel...
Display reads U60 Cooling Fan - oven won't heat
The code is telling you that the oven has sensed a fault in the coling fan circuit of the upper oven. Dacor has had a few problems with the cooling fans in these new ovens since theyve been out, so most likely you will have a bad fan motor. If that is the case, be prepared to have the repair person have to pull the oven out of the wall to get to it and change it. If its a realy board problem (less likely) than that can be changed from the front. Call up Dacor and find an authorized servicer in your area since it will still be under warranty. Good Luck!
Feb 05, 2007 | Dacor Millennia MOV130 Electric Single...
Dacor EHD3618SS Kitchen Hood Logo
230 people viewed this question
Top Dacor Kitchen Ranges Experts
Oloyede Monsuru
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
