Question about Yamaha RX-V663 Receiver
Yamaha RX-V663 - HDMI doesn't work.
Total newbie with problem.
I have 46" Schaub Lorenz LCD (3 wks old), Pioneer DV-410V (2 wks old), and Yamaha RX-V663 (purchased Thursday evening).
RX-V663 does not recognise HDMI connection from DVD (no response,
no GUI(OSD), no HDMI indicator). LCD displays "no signal".
HDMI connection from LCD to DVD works flawlessly (both cables checked).
Have rigged RCA jack from DVD "Audio Out" to Rcvr "CD in", so have
sound from all five speakers whilst playing DVD, but the HDMI connection has me stumped.
Have reviewed all manuals seeking solution without success. I note
the Yamaha manual seems to presume you have a GUI(OSD) to
begin with, and I can't get that far.
Any help would be welcome.
Best regards.
  • Anonymous Mar 16, 2014
    Rx-v663 no sound
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 20, 2008
Yamaha rx-v663. Want to watch cable tv while listening to cd (blue ray).
Don't think there is a way to make that happen with your setup
Dec 31, 2012 | Yamaha RX-V663 Receiver
Yamaha rx-v663 no video from hdmi out
Unfortunately the most common cause of this is the HDMI transmit IC on the digital board. Sometimes replacing this IC will work, but most of the time you will need to replace the digital board - this is expensive. If you don't have a warranty that is still valid, it may cost more than a new receiver.
Dec 23, 2012 | Yamaha Audio Players & Recorders
Yamaha rx-v663 is there a firmware update to get hdmi 1.4a support ?
Unfortunatly there is not any firmware to upgrade your unit to a higher HDMI format. There is a firmware though that corrects the following symptoms.
1. In case of playback of some DTS-HD Master Audio stream, pop noise may be generated.
2. Test tone may not be output under specific YPAO condition.
3. When test tone is output from presence channel, surround R channel is simultaneously output when speaker settings are PRESENCE SP "EXIST" and SWFR "NONE".
4. Multi channel input setting will be reset after power off the unit, in case of setting "INPUT CH" to "8CH" and "FRONT" to "VCR" or "V-AUX".
Apr 10, 2012 | Yamaha RX-V663 Receiver
Yamaha rx v663 video signal skipping
I'd leave it that way if it was me.
Jan 28, 2010 | Yamaha RX-V663 Receiver
Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Dec 29, 2009 | Yamaha RX-V663 Receiver
Verizon Fios connection issue with RX-V663 Receiver
I had the same problem with RXV3900, was told by verizon and yamaha it's a software issue with the box. Verizon is suppose to be working on a new update, but no time frame for now. I'm using component to receiver, and hdmi to tv with no issues.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Cannot get my yamaha rx-v663 to decode DolbyTrueHD audio of get my SBL/SBR speakers to work without turning the bi-amp on.
You should always connect with HDMI when using and decoding HD sound formats. If you use the normal digital option it will use PCM. Also check if your source is set to HD formats via HDMI connections.
Mar 06, 2009 | Yamaha RX-V663 Receiver
Xbox 360 dashboard will not show using Yamaha RX-V663
I had this issue once before, recheck all the conenctions on the tv, and make sure that the HDMI plug in for the TV * if its the older model * make sure it is placed to HDMI not TV.
Please let me know how it goes,
Thanks
Justin
Please rate me
Jan 07, 2009 | Yamaha RX-V663 Receiver
Have tried a chat session with "classyexpert" re: Yamaha RX-V663 a/v reciever a number of hours ago. Session was terminated due power failure other end. Was invited to wait for further assistance but...
Have seen a lot of similar issues here at the site and on the field.
I have posted in your original problem, excerpt below:
Then the non functional HDMI could be attended to at your convenience. Technically, it would appear to the the HDMI signal processor of the receiver.
Dec 20, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V663 Receiver Logo
594 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
